0 Replies Latest reply: May 9, 2011 10:39 AM by NathanStryker RSS
    PDF + PowerPoint dimensions issue
    NathanStryker Community Member
      Hi All-
      I have come across a weird bug today, when a PPT is saved as a PDF, the dimension attribute for the slide is a portrate mode (540x720), the actual slide is 720x540, and although it will preview properly, when this PDF is uploaded to an iOS device, the device displays the image rotated 90 degrees.
      The issue can be solved by opening the PDF and rotating it 360 degreees (this appears to reset the dimensions), but that is a pain. Is there some setting when th PDF is created to set it to Landscape view?
      Below you can see the dimensions of my PPT before and after rotating the same slide....
      Thanks for taking the time to look, and for your help.
