As a follow up to the note below, I would really appreciate any help as of how to get the SOM expression of a field dynamically, by this, I mean how to get the SOM expression of a field at running time using JavaScript.
Isis
That does make things clearer. You will have to save the change information in the XML. I realize that you don't want to save an xml node for every field, but there is a better way. You can use scripting to add data nodes to the XML data in the form. I'm thinking of the following:
Include an empty container node in your XML schema: <HighlightedFields></HighlightedFields>
When a field is changed, in the field's change event call a common script: HighlightChangedField, passing in the object. The script will highlight the field (set the border a certain color or whatever). It will also add node underneath the HighlightedFields data node with the SOM expression of the field. The SOM expression is the "path" of the object in the form heirarchy, sort of like an xpath. So if you have a subform named Subform1 and you change the Name and Address textfields, you might end up with something like:
<HighlightedFields>
<HighlightedField>
<SOMExpression>xfa[0].form[0].myform[0].Subform1[0].Name[0]</SOMExpre ssion>
</HighlightedField>
<HighlightedField>
<SOMExpression>xfa[0].form[0].myform[0].Subform1[0].Address[0]</SOMEx pression>
</HighlightedField>
</HighlighedFields>
The upside of this is that you only store XML nodes for what is changed instead of needing a specific XML node for each field. The downside is that you will need a call to the common script in every field's change event: HighlightChangedField(this);
Now, to make this work when a form is loaded the next time, in the initialize event at the topmost subform in the hierarchy you add a script that walks the HighlightedFields data node, and for each HighlighedField entry you highlight the contained object. You can get a reference to an object using its SOM expression, so just take the SOM expression from each entry and do an xfa.resolveNode(SOMExpression) to get the object, then set whatever attributes you want to highlight the field.
The big issue I see with this would be if you have dynamically added objects on your form. In that case you would probably need to store the instance index along with the SOM expression for each changed object, then use that instance number when highlighting on form load.
Total Likes
Objects have a "somExpression" property on them. For example, in javascript you can use:
var exp = this.somExpression;
You can use the command "this.somExpression" to get the SOM Expression of the current field at run time..
For example if you want to pass the somExpression of the current field to your function,
Place this in the change event of your field.
HighlightChangedField(this.somExpression);
Srini
As a follow-up, I had said I would try to put together an example for you. The setting of the change indications and the highlighting of the fields is not a problem, but I did have an issue that perhaps one of the experts on the forum can help with:
The problem is how to detect a change in a text field without a lot of overhead. You can't just place a call to the highlight method in the Exit event without checking for a change, since the user can just tab from field to field without changing anything. Unfortunately the properties that show the old text and new text of a field are not valid on the Exit event. An alternative is to use the Change event, but with a text field the event fires for every character typed. This seems like a lot of extra processing..
Anyone know a better way? I went as far as using the extras collection on fields to hold the last value, but that adds a lot of complexity since it needs to be set to the initial raw value when the form is first loaded. I'd like to find a solution that doesn't require a lot of code to be added to every field on the form.
Total Likes
