Is there a way to export the TOC for a multi-project Help system into a text/word/excel doc?
We are need to have the entire TOC put into a planning doc (ug), and we'd prefer not to have to manually type it if at all possible.
If you run the table of contents report - Tools > Reports - there is an option to save the report as a file. This can then be imported into Word or Excel. You may have to do a little tidy up but not that much.
The RoboColum(n) | @robocolumn | Colum McAndrew |
For a merged project you'd have to run the report on each project and cut / paste the data into a single file.
Thanks! I forgot about the report option and when I tried searching RH help it kept displaying importing options.
Jeffrey Arp
Technical Writer
JWS (a division of)
Command Alkon
10000 West 75th St., Suite 103
Shawnee Mission, KS 66204-2241
913-384-0880 EXT. 5780
www.commandalkon.com
Never mind! I was thinking of topic lists rather than TOC lists. Shoot!
Good luck,
Leon
