I made a post yesterday about a web service function I was
writing, as it turns out my post was extremly incorrect for my
problem. With this web service function I can return an array just
fine, I can return one instance of an object just fine, however,
when I try to return an array of the object I keep getting the
error:
Could not perform web service invocation "SelectGames"
because AxisFault faultCode: {
http://schemas.xmlsoap.org/soap/envelope/}Server.generalException
faultSubcode: faultString: [org.apache.axis.AxisFault : ; nested
exception is: coldfusion.xml.rpc.CFCInvocationException:
[java.lang.IncompatibleClassChangeError : Dependent CFC type(s)
have been modified. Please refresh your web service client.]];
nested exception is: coldfusion.xml.rpc.CFCInvocationException:
[org.apache.axis.AxisFault : ; nested exception is:
faultActor: faultNode: faultDetail: {
http://xml.apache.org/axis/}stackTrace:
have been modifie..
which basically means that the CF server needs restarted.
However if I restart the CF server, no matter how many times I am
still getting this error. If I change up my web service function to
return just a normal array of integers or strings, or I change it
to return one instance of the arbritrary complex type it all works
just fine. I am still a little new on this subject and any
enlightenment would be great. If anyone has found a way around this
please let me know.
Here is my complex type:
<cfcomponent>
<cfproperty name="Game_id" type="numeric">
<cfproperty name="gameDate" type="date">
<cfproperty name="Starttime" type="string">
<cfproperty name="Place" type="string">
<cfproperty name="Level" type="string">
<cfproperty name="Sport" type="string">
<cfproperty name="Gender" type="string">
<cfproperty name="Opponent" type="string">
<cfproperty name="Type" type="string">
<cfproperty name="Link" type="string">
</cfcomponent>
I loop trhough a query and set a cfobject of the types above,
then I append that object to an array and try t o return the array.
Here is the basics of the loop:
<cfset theArray = arrayNew(1)>
<cfobject component = "games" name = "test>
<cfloop query ...>
<!--- set values to test ---->
<cfset arrayApend(theArray, test)>
</cfquery>
<cfreturn theArray>
my return type is array, I think the problem is I need to
specify the return type to be an array of arbritray complex types
which is impossible to do in CF. Anyone find a way to get around
this?? Any feed back at all would be greatly appreciated.
