Show 2 replies
1. Re: 60p footage - slow mo. - How to correctly set up a sequence ?
Harm Millaard May 11, 2011 11:14 AM (in response to David Zeno)Make sure that the sequence matches your footage exactly, so 60p footage in a 60p sequence. Then create slomo's using speed/duration or time remapping.
2. Re: 60p footage - slow mo. - How to correctly set up a sequence ?
Colin Brougham May 11, 2011 12:12 PM (in response to David Zeno)Just decide what your editing frame rate will be--for example, 24p or 30p--and then use the Interpret Footage command on your source clip. Set the frame rate of the clip to match the frame rate of the sequence. The clip will play back with really smooth slow motion and no unnecessary frame blending or interpolation.
