I've inherited a project from a previous user and she incorporated the "Expand/Collapse All" button. The button is used to expand and collapse images in the topics. They expand properly, but when you "collapse all", the tables that come directly after the image are also collapsing, i.e. disappearing. This does not happen if you expand/collpase the drop-downs individually.
Hi Thomas,
What version of RoboHelp are you using? Are you using the default RoboHelp drop downs or do you have some custom method? Also, there are several methods of creating show/hide buttons: In the topic or in the toolbar. There are also several methods for either type of buttons. (See http://www.grainge.org/pages/authoring/twisty/twisty.htm) Do you know which method you are using?
My guess is that the JavaScript you are using for the buttons needs some fixing, but I can't say without looking at a topic and the script you are using. Could you create an example project with one or two topics that illustrate your problem?
Greet,
Willam
Thanks for your response. I'm using RH8 and am somewhat new at this. A previous employee set this up and I've merely been doing updates. Attached is a stripped down version of the .hlp (prp_hlp.htm is in the Webhelp folder). Access the following topic:
File Maintenance | Additional File Maintenance | Job Description Names
There are two tables on this screen - one is under the fieldname "Type", and the other is under the fieldname "Responsibility Type". When you click "Expand & Collapse", to show the screenshots, all is well. Click "Expand & Collapse" again, to hide the screenshots, and the trouble starts. The tables are missing. To re-surface the tables, click on another topic and then return to Job Description Names.
Does this help?
Tom Barclay
Welcome to our community, Thomas
And the URL to the help would be?...
Cheers... Rick
Help me out here Rick. Not sure I have a URL for this. It runs from our product. Can't this be run on your desktop? As I said, I'm kinda new at this. More of a print docs, Framemaker person.
You cannot post an attachement on the forum. So Rick assumed that you have placed the example project somewhere we can access it. If you can't do that, you can also send me the zipped project at contact [at] wvanweelden [dot] eu.
Greet,
Willam
Rick's asking for a path to your help because you can't attach files here in the forum (only screenshots). If you want to share it with everybody, put it on a sharing site like dropbox, etc. and post the URL to it here.
Solved this by deleting the old toolbar button and using the new toolbar button script:
Greet,
Willam
