I'm using the latest version of the TCS with RH 9.0. I'm trying to create WebHelp Pro output
for a book produced originally in Framemaker. I've been following Rick's Skinny on skins
guide to tailor the look and feel, but am having real problems getting my browse sequence
to work. I've used Tools> Browse Sequence Editor and then Auto-create using Frame TOC,
selected the TOC from the drop-down list and chosen 4 as the depth that I want to browse.
The TOC that appears in Browse sequences is strange and doesn't represent the Frame TOC that
appears in the html, I left this 'as is'. Once I've generated the ouput the sequence browsing works
for the equivalent of top-level heading only. What am I doing wrong and what should I
be editing to make this fully functional?
I would also like to delete the Sync TOC from the toolbar, and it seems to be possible to
delete the image but not the entire field. I know it can be done, because Peter Grainge's
RH site doesn't have it. Between Peter and Rick I will somehow achieve this website for
my company...
Many thanks in advance for any ideas and help.
Best wishes,
Karen
Killing off the Search is done through the SSL layout's Navigation pane - that's where you select what elements you want to show (and in what order).
So you're using RH Server with this output right? That's what the "Pro" designation indicates. If you're not, then just create regular WebHelp.
Hi Jeff,
I have literally just realized that Pro isn't better it's different and not appropriate for our
customer base. Hoping to get this working this eve now. Still need help as to how to
remove the Search and Go from the toolbar though.
Many thanks,
Karen
Hi Jeff,
Killed off the search, now using Webhelp rather than Webhelp pro. Output all produced well,
but I cannot get next and previous topic buttons to do anything other than browse through
Heading 1. I've enable the browse sequence, but I'm still can't work out why the
sequence browsing won't work with the full contents.
Many thanks for all your help.
Best wishes,
Karen
Those are the ones in the top left? If so, they aren't the browse sequence controls from what I understand. They're more like web page forward & back buttons. From what I know (I've only enabled browse sequences in an AIRHelp project, not my WebHelp one) is that they appear in the top right corner of the topic page. You probably need to have a look at the browse sequence manager and mess around with how it thinks it's advancing.
Hi all
@Jeff - In WebHelp output a Browse Sequence is presented using the arrows that sit in the Navigation Mini-Toolbar. I've documented some of it at the link below:
@Karen - Are you wanting one single sequence that works to allow the user to traverse the TOC from top to bottom or bottom to top? If so, the way you do this is by creating one very long sequence in the Browse Sequence Editor. You might begin by specifying 0 as the level to use when auto creating. Normally that will be sufficient. However, it depends on your TOC as to how well that may actually work.
Cheers... Rick
Hi Rick,
Thanks again for another set of instructions for me to follow. You are absolutely right I do
just want to go back and forth through the TOC, so will go for using your approach on
Monday. I suppose the 'sequences' should have been a hint in browse sequences, but
I still expected the default sequence to be the TOC...
Best wishes,
Karen
Hi Jeff,
Finally understood this late last night, so many things to learn!
Many thanks for your continued help.
Best wishes,
Karen
