I used Captivate 5 to record my screen opeation . And I don't my name in the screen showed up. So I use the image to cover the area I don't want to show. However, the name still flash some time. It seems that I can't cover it all the time. So I want to know what goes wrong and How I could cover my name all the tiem. Thank you.
Hello and welcome to the forum,
What do you use to cover up: a drawing object like a rectangle perhaps? By default it will have a 'transition' set to Fade in/Fade out. Check this in its Properties panel, Transition accordion. Eventually you could also merge the object into the background.
Lilybiri
Lilybiri
Dear Lilybiri, Thanks.
Your answer is correct. Now I don't see the flashing image. Thank you.
