1. Re: prining a QR code (OT)
Jeffrey_Smith May 13, 2011 1:05 PM (in response to phyllisj9)QR codes vary in physical size, relative to the data (amount of characters) contained within the code. Here is a link to i-nigma with their specs. Although companies may have specifications for reproducing a code, I have found as long as you can capture the entire code on your smart phone screen it will work properly.
As for background: For most readers/smart phones, the code can be reversed to white and placed on a dark background. But I have had some readers not work.
As for verbage, I have used taglines similiar to this: "Scan QR code with a free code reader on your smart phone to go directly to..."
2. Re: prining a QR code (OT)
phyllisj9 May 13, 2011 1:21 PM (in response to Jeffrey_Smith)Hey thanks! The code they sent me is about 3.5" square (huge!). I was thinking of printing it at around 1" square. I've actually never scanned a QR code (I guess I need to get with the times!). Does that sound reasonable for scanning with a phone?
Thanks for the verbage. I guess I should look for one of those readers myself and install it so I know what's going on with this.
Thanks, Phyllis
3. Re: prining a QR code (OT)
Jeffrey_Smith May 13, 2011 1:27 PM (in response to phyllisj9)Without seeing the code, I would say you probaly could safely scale it down to 1 inch.
If you go to www.i-nigma.mobi with your phone, the site will detect the type of phone you are using and download the appropriate reader
4. Re: prining a QR code (OT)
phyllisj9 May 13, 2011 1:29 PM (in response to Jeffrey_Smith)Thanks so much!!! You've been a huge help!
5. Re: prining a QR code (OT)
Jeffrey_Smith May 13, 2011 1:44 PM (in response to phyllisj9)For the most part, QR codes are just glorified hyperlinks for smart phones. And if the code doesn't take you to a mobile-device-friendly destination, then it is a real waste of time. QR codes can be useful, like a contact card that can be exported and saved to address book.
6. Re: prining a QR code (OT)
phyllisj9 May 13, 2011 1:49 PM (in response to Jeffrey_Smith)Good to know, thanks. I'll check it out on my smartphone & see if it's reasonably usable on there...
7. Re: prining a QR code (OT)
Mr. Met May 13, 2011 3:09 PM (in response to phyllisj9)reasonably usable
It either works or it doesn't. Should be fine at 1". Be sure to download a QR reader for your phone so you can scan the code for testing.
8. Re: prining a QR code (OT)
Eugene Tyson May 14, 2011 1:41 AM (in response to phyllisj9)Didn't read everything so just throwing out random wild thoughts here.
Test the QR code at various sizes using 2 or 3 different scanners and models of phone.
They can be test on the monitor. In InDesign press CTRL/CMD 1 to view "actual size" it's approximate but it will do. And scan it. And also print it out.
Check these out http://mashable.com/2011/04/18/qr-code-design-tips/
