3 Replies Latest reply on Jul 28, 2006 6:59 AM by kglad
    fscommand, geturl in flash 8
    saraswati_wadnal Level 1
      The fscommand doesn't work in flash 8. The example in flash Technotes from Site works but if published with flash 8 doesn;t work.
      ExternalInterface.call also doesn't work with flash 8....even if import statement is used.
      The same case with getURL.
      All functions I just want to use with FLASH 8.
      It works with previous versions very fine.
        • 1. Re: fscommand, geturl in flash 8
          Level 7
          Flash 8 ExternalInterface works fine for me. Perhaps a little more detail
          would get you a better answer?
          Thanks.
          John G.
          "saraswati_wadnal" <webforumsuser@macromedia.com> wrote in message
          news:eaco7c$eh7$1@forums.macromedia.com...
          > Site
          > statement is used.
          • 2. Re: fscommand, geturl in flash 8
            |~aryan~| Level 1
            Though i myself very much new to flash (mainly a designer) and now i m working with Flash 8(actionscript) and so far i din face any problem as u mentioned.. can u explian lil more about ur probs.
            thanks...
            cheers!!
            • 3. Re: fscommand, geturl in flash 8
              kglad Adobe Community Professional & MVP
              you're probably seeing a security issue because you're testing locally. upload your files to your server and retest.
