I"m using the following DDX to extract PDF attachments:
<?xml version="1.0" encoding="UTF-8"?>
<DDX xmlns="http://ns.adobe.com/DDX/1.0/">
<FileAttachments result="attachmentInfo.xml" nameKeys="*" extract="true">
<PDF source="inDoc"/>
<FilenameEncoding encoding="ISO-8859-1"/>
</FileAttachments>
</DDX>
After DDX execution I'm able to retrieve the attachments one by one using the syntax: /documents[@id='yan.pdf_attach.0000.0003']
Is there a way to assign to output map of documents variable the whole documents map without looping the attachments ?
My goal is to call the process from .Net and retrieve all the attachments of input doc.
Total Likes
Yes, in a setValue assign the /documents node to a map object.
Total Likes
Thanks Hodmi, it works!
Actually I tried this way but my map was not defined correctly.
Total Likes
