2 Replies Latest reply: May 17, 2011 5:01 PM by barpos RSS
    Can't swap symbol -- Flash exits w/out warnings
    barpos Community Member
      I have this background picture on its own layer that I'm trying to swap with another graphic symbol, but as I click on the new file, Flash exits with no return on its own.
      Any ideas why?
        • 1. Re: Can't swap symbol -- Flash exits w/out warnings
          Rob Dillon CommunityMVP
          Did you save before you tried the swap? If you place the image that you want to swap in on the stage, does it show up correctly and without error? Can you swap the image on the stage with any other image in the Library?
          • 2. Re: Can't swap symbol -- Flash exits w/out warnings
            >Did you save before you tried the swap?<
            No.
            >If you place the image that you  want to swap in on the stage, does it show up correctly and without  error?<
            Yes and w/out errors.
            >Can you swap the image on the stage with any other image in the  Library?<
            Nope.
            Anyhow, I ended up ...
            1. deleting the existing image symbol on the stage
            2. deleting the new image symbol in the library
            3. dragging the new [raw] image (jpg) onto the stage
            4. converting that stage image as a graphic symbol
            So, everything is fine now ...
            Ronald
