Show 2 replies
1. Re: Position and Scale Moves Question
Mylenium May 17, 2011 10:37 PM (in response to thanser)Not sure what exactly you want, but most people would simply adjust the Bezier tangents of the path. Simply use the Convert Anchor Point tool to convert the points, then adjust the tangents.
Mylenium
2. Re: Position and Scale Moves Question
thanser May 18, 2011 8:20 AM (in response to Mylenium)D you mean In the graph editor? Or directly on the stage?
I have both position and scale keyframes (well, four in this case. Two for position and two for scale.) that need to be altered to produce a smooth, arcing movement.
I'll have to experiment here to get it right but I see this move all the time.
