1. Re: audio stops playing after a few seconds when importing a HD clip
Harm Millaard May 18, 2011 7:45 AM (in response to Pedaling Duo Productions)Make sure you import the complete BPAV directory, not single clips.
2. Re: audio stops playing after a few seconds when importing a HD clip
Bill Hunt May 18, 2011 9:52 AM (in response to Pedaling Duo Productions)Along with Harm's suggestion, also wait until Conforming has completed 100%. This ARTICLE will give you more background.
Good luck,
Hunt
3. Re: audio stops playing after a few seconds when importing a HD clip
Pedaling Duo Productions May 18, 2011 10:25 AM (in response to Harm Millaard)Yes! I imported the entire BPAV in a file on my scratch drive under the specific project folder. From there I am using the media browser in CS4 to either preview the clip or import it into the project. The audio drops out whether it is previewed or imported. And as I have said, this behavior is not consistant. I have yet to find a repeatable cure.
Also as I have said if I import the offending clip, from the same folder, into Soundbooth using Bridge the waveform is fine. If I import the same clip into Soundbooth from the Premiere timeline the waveform goes flat where the audio stopped in Premiere.
Thanks for the quick replies.
I am readingthe article that was suggested soon.
4. Re: audio stops playing after a few seconds when importing a HD clip
Pedaling Duo Productions May 18, 2011 10:33 AM (in response to Pedaling Duo Productions)One more note. It is not always the same clips thathave this problem. It could
be one clip one time and another clip another time.
5. Re: audio stops playing after a few seconds when importing a HD clip
wayfarupnorth May 19, 2011 11:28 AM (in response to Pedaling Duo Productions)I had a similar issue with CS4 today. I initially thought it was a problem with the files, but after a bit more investigation, I don't think it was.
A couple of thoughts... save your project and then exit premiere pro and restart it.
make sure that you allow enough time for files that you are importing to finish "conforming". You can see this monitor this in the progress bar in the lower right hand side of your screen.
Hope that helps.
