recently joined adobe and faced a similar problem....
dunno if u found the solution by now, but here goes anyway...
The magic answer is CTRL+SHIFT+D
try it and tell me if it worked for you...
I just tried to deauthorize using CTRL-SHIFT-D and it worked perfectly for me.
Igor
Can you tell me where you are when you do the CTRL Shift D ? Are you in the program and if so where. Hate to sound so dumb, Your help is really appreciated.
I got it. Thanks. You just open Adobe Digital Editions and then go CTRL Shift and D (not delete) It worked great!
Hi.. I run in to a different issue, I was unable to open the application at all. the program works just fine few weeks ago, but now when I open the application just get the white blank screen. really frustrated.. Any trick or idea are great appreciated, I already try to un-install and re-install a couple of times still run into the same problem.
Thank you for this tip! My 'blank screen' problem has now been resolved and I can view my books again in ADE 1.8.3.
I had same problem, and CTRL-SHIFT-D did give me a screen to deauthorize. Many thanks for the info.
BTW -- where was this info found? I see nothing in the DigEditions help guide.
It's in there.... Look in Help, under 'Shortcut Keys'.
Have read through the "Shortcut Keys" Help section several times, and darned if I can find the sequence listed anywhere. Should be in the "Application-Wide Keyboard Shortcuts" table but its not. Neither can I find the companion Ctrl+Shift+E combination (crucial for deauthorizing an attached e-reader, as explained elsewhere in these forums). Where exactly did you find this in Help? Maybe our Helps are at a different level - I'm using A.D.E version 1.7.2.1131.
Actually, I went back and looked for the deactivate shortcut and couldn't find it either. Figured I must be losing it ....
Thanks for the additional tidbit (shift ctrl E)
How does one find the listing of ADE authorized devices?
ADE Help has it: http://blogs.adobe.com/digitalpublishing/supported-devices
Make sure caps lock is off when you do this, otherwise it doesn't work.
Anybody knows how to deactivate a PC that does not boot anymore or has been destroyed?
Alas you can't.
You have to wait till you run out of activations, then contact Adobe to get them to cancel ALL your activations, then reactivate the ones you still want.
Unfortunately, Adobe do not provide a web page for viewing/changing activations.
Hi, how do I contact Adobe regarding Adobe Digital Editions? I contacted Adobe support as I reached maximum devices, but they said they cant help here, only the forum might halt, end sent me the link to this thread..
J'ai atteint la limite du nombre d'activation. Comment est ce que je peux faire un reset.
