I have a project. When I hit CTRL+F11 it runs it creates a bunch of swf files and what not in the bin-debug folder.
If I move (copy) those files to a diffrent location they stop working, wont load not even the main.swf or the main.html
If I click on the main.swf or the main.html in the bin debug folder it works. everything works. How do I make it so I can use the swf out side the debug folder
and on other pages either on a server or local host?
I didnt have this problem before but now I do...
Can some one please give me a soution to this issue?
theres an example here: http://blackandwhite.web44.net/adventure-game the whole thing requests for a "upgrade in flash" I have the latest version
this is what results when I try and move the files from the debug to the server
hello can some one help this is a pressing issue
please respond
Can you try doing an Export release and copy all the contents of bin-release over to your server?
Is this a Flex or actionscript project? Do you have all the js, html and SWF/SWZ files in bin-debug copied over? (Specifically you need swfobject and history.js)
A difference between bin-debug and other folders is flash player security. Flash Builder automatically adds the bin-debug folder of a project to a "trusted folders" list so that you can make networking calls which you normally wouldn't be able to unless you host the SWF on that domain.
-Anirudh
I coppied everything but the history folder (which may be the reason). I didnt know you could do an export release. Ill try this out once the server starts acting nice again. Thanks
Ya its not working. I coppied everything over to the server the page is: http://blackandwhite.web44.net/adventure-game/
hello
Will some one please respond already like whats the hold up?
Hi Adrien,
There's a wordpress login page barring my way.
-Anirudh
Thats really awkward. Let me just investigate this quickly......(moments later)..Its not any more. Thank you for pointing that out. It was a plugin that was blocking you. ANY WAYS. please i beg of you (with desperation) help me.
I did what you suggested I coppied eveything in that folder and posted it to my server and linked the main.swf into the page and I get that error.
Sorry if the page fails to load - just keep trying my hosting service is doing upgrades
Thats odd - have you tried looking at the page source? youll see this:
<script type="text/javascript" src="http://blackandwhite.web44.net/Flash/swfobject.js"></script>
<param name="movie" value="http://blackandwhite.web44.net/Flash/Main.swf" />
<object type="application/x-shockwave-flash"
data="http://blackandwhite.web44.net/Flash/Main.swf" width="800" height="533">
so I am kinda confused.
there was no modified js file....so Dont know what that means and adventure game is a page not a directory....yourchrome is treating it like a directory
If you're using SWFObject, you have to update the embedSWF() function with the path, not the param tag (that is a fallback).
Btw, your game is starting up fine now. Looks like you sorted out the problem yourself - good going!
-Anirudh
