Exported Release Build Application fails to load over the web. You can reproduce using the following steps:
1. Create New Flex Project in Trial Flash Builder 4.5.
2. Use the default Flex 4.5 sdk.
3. Configure as a web application.
3. Place the following MXML code in the main application file:
<?xml version = "1.0" encoding = "utf-8"?>
<s:Application xmlns:fx = "http://ns.adobe.com/mxml/2009"
xmlns:s = "library://ns.adobe.com/flex/spark"
xmlns:mx = "library://ns.adobe.com/flex/mx"
minWidth = "955"
minHeight = "600">
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<s:TextArea text = "Hello World!" width = "100%" height = "100%">
</s:TextArea>
</s:Application>
3. Save the main application file and Export Release Build to bin-release.
4. Place all files in bin-release on IIS web server in a web accessible location.
5. Go to the web accessible location in any browser with newest flash player and view the application's html page.
Actual Results:
Flash movie appears blank. Context menu shows Movie Not Loaded. Network traffic shows application main swf downloaded. Framework dependent swfs not downloaded.
Expected Results:
Movie loads. Hello World! appears in text box. Context menu does not show Movie Not Loaded. Framework dependent swfs downloaded.
Workaround (if any):
Deploy on an Apache web server.
The tests were run on IIS 7.x (7.0 for one, and 7.5)
Flex application was built using Flex 4.5.0 SDK pre-bundled release (built-in flex 4.5 with Flash Builder 4.5 trial) on Mac OS X 10.6.7 (10J869)
Flash Player 10.3.181.14
Example failing website:
http://staging.ibenergy.com/Test.html
Any idea as to why my exported release build fails? Any help would be appreciated.
Just tried this out on an IIS server with Flash player 10.3.181.14 - it worked.
Are you using the release version of Flash Builder 4.5 with the release version of Flex SDK (not a prior SDK build)?
The URL you mentioned gives me a 403 forbidden error.
-Anirudh
