1 2 Previous Next 57 Replies Latest reply on Dec 4, 2018 7:12 AM by c.pfaffenbichler
    Export Groups to Files?
    808eatz Level 1
      Is there a way to export multiple GROUPS into individual files, such as jpg?  If I run the File > Scripts > Export LAYERS To Files, each LAYER becomes a jpeg, but i'd like each GROUP to be flattened and exported as a jpg. Is there a script or funtion that performs this task?
        • 1. Re: Export Groups to Files?
          c.pfaffenbichler Level 9
          Are all the groups on the topmost hierarchical level or are there groups within groups?
          • 2. Re: Export Groups to Files?
            You could try attached Script, You’d have to adapt it to jpg, currently it saves pdfs.
            I have not tested it very extensively and only in CS4 though.
            2 people found this helpful
            • 3. Re: Export Groups to Files?
              808eatz Level 1
              Yes, the Groups are all at the top level, and YES! your script worked wonderfully!  I'll need to figure out the jpg instead of pdf portion, but you definitely solved the difficult part. Thank you!!
              • 4. Re: Export Groups to Files?
                You could replace the pdfOptions with
                var jpgopts = new JPEGSaveOptions();
                jpgopts.embedColorProfile = true;
                jpgopts.formatOptions = FormatOptions.STANDARDBASELINE;
                jpgopts.matte = MatteType.NONE;
                jpgopts.quality = 10;
                and edit that according to Your needs.
                Then replace »pdfOpts« and ».pdf« in the saveAs-line with »jpgopts« and ».jpg«.
                1 person found this helpful
                • 5. Re: Export Groups to Files?
                  mazmax Level 1
                  Thanks for this, it works really well. I've tried making 2 changes to the script but it doesn't seem to work right
                  • Use ExportOptionsSaveForWeb with JPEG 80% but it's giving me just 1 bad quality file
                  • Have the script elaborate only the top level groups to reduce the time it takes to load up and show the dialog box. At the moment it's picking up every group in the file.
                  What is wrong in this code?
                  • 6. Re: Export Groups to Files?
                    mazmax Level 1
                    • Use ExportOptionsSaveForWeb with JPEG 80% but it's giving me just 1 file name "filename-#0.jpg" with the contents of the lowest group
                    // creates pdf-copies of layersets with dialog to select layers and suffix;
                    // be advised: existing files of identical names will be overwritten without warnings;
                    // 2009, pfaffenbichler, use it at your own risk;
                    #target photoshop
                    if (app.documents.length > 0) {
                    // get document-path and -title;
                    var myDocument = app.activeDocument;
                    var myDocName = myDocument.name.match(/(.*)\.[^\.]+$/)[1];
                    var myPath = myDocument.path;
                    var theLayerSets = collectLayerSets(myDocument);
                    ////// filter for checking if entry is numeric, thanks to xbytor //////
                    numberKeystrokeFilter = function() {
                    this.text = this.text.replace(",", "");
                    this.text = this.text.replace(".", "");
                    if (this.text.match(/[^\-\.\d]/)) {
                    this.text = this.text.replace(/[^\-\.\d]/g, "");
                    if (this.text == "") {
                    this.text = "0"
                    // create the dialog;
                    var dlg = new Window('dialog', "pdfs from layersets", [500,300,930,840]);
                    //create list for layer-selection;
                    dlg.layerRange = dlg.add('panel', [21,20,279,445], "select layersets to create pdfs of");
                    dlg.layerRange.layersList = dlg.layerRange.add('listbox', [11,20,240,405], '', {multiselect: true});
                    for (var q = 0; q < theLayerSets.length; q++) {
                    dlg.layerRange.layersList.add ("item", theLayerSets[q].name);
                    dlg.layerRange.layersList.items[q].selected = true
                    // entry for suffix;
                    dlg.suffix = dlg.add('panel', [290,20,410,85], "enter suffix");
                    dlg.suffix.suffixText = dlg.suffix.add('edittext', [11,20,99,40], "", {multiline:false});
                    // entry for number;
                    dlg.number = dlg.add('panel', [290,100,410,165], "start with #");
                    dlg.number.startNumber = dlg.number.add('edittext', [11,20,45,40], "1", {multiline:false});
                    dlg.number.addNumber = dlg.number.add('checkbox', [55,20,105,40], "add", {multiline:false});
                    dlg.number.startNumber.onChange = numberKeystrokeFilter;
                    // field to add layer-name;
                    dlg.layerName = dlg.add('panel', [290,180,410,270], "layer-name");
                    dlg.layerName.doAddName = dlg.layerName.add('radiobutton', [11,20,120,40], "add it");
                    dlg.layerName.dontAddName = dlg.layerName.add('radiobutton', [11,45,120,65], "don’t add it");
                    dlg.layerName.doAddName.value = true;
                    // field to select target-folder;
                    dlg.target = dlg.add('panel', [290,285,410,445], "target-folder");
                    dlg.target.targetSel = dlg.target.add('button', [11,20,100,40], "select");
                    dlg.target.targetField = dlg.target.add('statictext', [11,50,100,155], String(myPath), {multiline:true});
                    dlg.target.targetSel.onClick = function () {
                    var target = Folder.selectDialog("select a target folder");
                    dlg.target.targetField.text = target.fsName
                    // ok- and cancel-buttons;
                    dlg.buildBtn = dlg.add('button', [220,460,410,475], 'OK', {name:'ok'});
                    dlg.cancelBtn = dlg.add('button', [21,460,210,475], 'Cancel', {name:'cancel'});
                    dlg.warning = dlg.add('statictext', [21,490,410,530], "be advised: existing files of the same name will be replaced without prompting", {multiline: true});
                    dlg.center();
                    var myReturn = dlg.show ();
                    // in case of OK;
                    if (myReturn == true && dlg.layerRange.layersList.selection.length > 0) {
                    // get the number instead of the name;
                    var theLayerSelection = new Array;
                    var theColl = dlg.layerRange.layersList.items;
                    for (var p = 0; p < dlg.layerRange.layersList.items.length; p++) {
                    if (dlg.layerRange.layersList.items[p].selected == true) {
                    theLayerSelection = theLayerSelection.concat(p);
                    // collect the rest of the variables,
                    var theSuffix = dlg.suffix.suffixText.text;
                    var theNumber = Number (dlg.number.startNumber.text) - 1;
                    var theLayerNameAdd = dlg.layerName.doAddName.value;
                    var theDestination = dlg.target.targetField.text;
                    var theNumbering = dlg.number.addNumber.value;
                    // pdf options
                    var jpgopts = new ExportOptionsSaveForWeb();
                    jpgopts.format = SaveDocumentType.JPEG;
                    jpgopts.includeProfile = true;
                    jpgopts.quality = 80;
                    // create the pdf-name;
                    if (theSuffix.length > 0) {
                    var aSuffix = "_" + theSuffix
                    else {
                    var aSuffix = ""
                    // create a flattened copy;
                    var theCopy = myDocument.duplicate("thecopy", true);
                    // do the operation;
                    for (var m = theLayerSelection.length - 1; m >= 0; m--) {
                    app.activeDocument = myDocument;
                    var theLayer = theLayerSets[theLayerSelection[m]];
                    if (theNumbering == true) {
                    theNumber = bufferNumberWithZeros((Number (theNumber) + 1), 2);
                    theNumberString =  "_" + theNumber
                    else {
                    theNumberString = ""
                    // get the layername for the pdf-name;
                    if (theLayerNameAdd == true) {
                    var aLayerName = "_" + theLayer.name.replace("/", "_")
                    else {
                    var aLayerName = ""
                    // transfer layerset over to the copy;
                    theLayer.duplicate (theCopy, ElementPlacement.PLACEATBEGINNING);
                    app.activeDocument = theCopy;
                    // hide the llast added layer;
                    theCopy.layers[1].visible = false;
                    theCopy.exportDocument(new File(theDestination+"/"+myDocName+aSuffix+aLayerName+theNumberString+".jpg"), ExportType.SAVEFORWEB, jpgopts );
                    theCopy.close(SaveOptions.DONOTSAVECHANGES);
                    else {alert ("no document open")};
                    ////// buffer number with zeros //////
                    function bufferNumberWithZeros (number, places) {
                    var theNumberString = String(number);
                    for (var o = 0; o < (places - String(number).length); o++) {
                    theNumberString = String("0" + theNumberString)
                    return theNumberString
                    ////// function collect all layersets //////
                    function collectLayerSets (theParent) {
                    if (!allLayerSets) {
                    var allLayerSets = new Array}
                    else {};
                    for (var m = theParent.layers.length - 1; m >= 0;m--) {
                    var theLayer = theParent.layers[m];
                    // apply the function to layersets;
                    if (theLayer.typename == "ArtLayer") {
                    // allLayerSets = allLayerSets.concat(theLayer)
                    else {
                    // this line includes the layer groups;
                    allLayerSets = allLayerSets.concat(theLayer);
                    allLayerSets = allLayerSets.concat(collectLayerSets(theLayer))
                    return allLayerSets
                    • 7. Re: Export Groups to Files?
                      Michael L Hale Level 5
                      I have seen others report this filename issue when scripting SFW on MacOS. I think the fix is to go into make sure your Filename Compatibility is set to Unix in the Saving Files section of the Output Settings in the flyout menu of the SFW dialog.
                      Another option is to let SFW do it's thing and have the script rename the file to the desired name after the export.
                      • 8. Re: Export Groups to Files?
                        mazmax Level 1
                        Yep you're right Mike!
                        I added jpgopts.byteOrder = ByteOrder.MACOS; and it works fine
                        • 9. Re: Export Groups to Files?
                          luxuz2 Level 1
                          Great skript!
                          Is there a way to export Groups to png?
                          • 10. Re: Export Groups to Files?
                            Nils M Barner Level 1
                            Groups to .png is what I*m searching for, too.
                            Any ideas? Anyone?
                            • 11. Re: Export Groups to Files?
                              Paul Riggott Level 6
                              You could try this..
                              #target photoshop
                              function main(){
                              if(!documents.length) return;
                              var doc = activeDocument;
                              var oldPath = activeDocument.path;
                              for(var a=0;a<doc.layerSets.length;a++){
                              activeDocument.activeLayer = activeDocument.layers.getByName(doc.layerSets[a].name);
                              dupLayers();
                              var saveFile= File(oldPath +"/"+doc.layerSets[a].name +".png");
                              SavePNG(saveFile);
                              app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
                              main();
                              function dupLayers() {
                                  var desc143 = new ActionDescriptor();
                                      var ref73 = new ActionReference();
                                      ref73.putClass( charIDToTypeID('Dcmn') );
                                  desc143.putReference( charIDToTypeID('null'), ref73 );
                                  desc143.putString( charIDToTypeID('Nm  '), activeDocument.activeLayer.name );
                                      var ref74 = new ActionReference();
                                      ref74.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                                  desc143.putReference( charIDToTypeID('Usng'), ref74 );
                                  executeAction( charIDToTypeID('Mk  '), desc143, DialogModes.NO );
                              function SavePNG(saveFile){
                                  pngSaveOptions = new PNGSaveOptions();
                                  pngSaveOptions.embedColorProfile = true;
                                  pngSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
                                  pngSaveOptions.matte = MatteType.NONE;
                               pngSaveOptions.PNG8 = false;
                                  pngSaveOptions.transparency = true;
                              activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
                              • 12. Re: Export Groups to Files?
                                jvdh.net Level 1
                                Great script Paul!
                                I've added
                                     activeDocument.trim(TrimType.TRANSPARENT,true,true,true,true);
                                before
                                so the PNG files are trimmed before saving.
                                • 13. Re: Export Groups to Files?
                                  Aboyne99 Level 1
                                  Paul, This looks like a life saver script to me, but I am having a problem.
                                  When I run it, it asks to save each group/file as a PSD.
                                  I am an old time programmer, so I get the logic, but I don't know any of the syntax of photoshop scripting.
                                  If i did I would try to sort this out myself.
                                  Is there some overriding setting in preferences I need to change that won't just allow the script to save the group as a PNG (without my interaction) as the script seems to be telling it to do?
                                  Thank you SO much.
                                  Ed
                                  • 14. Re: Export Groups to Files?
                                    There were a fewmistakes in that code, could you please try this now...
                                    #target photoshop
                                    function main(){
                                    dupLayers();
                                    activeDocument.mergeVisibleLayers();
                                    SavePNG(saveFile);
                                    main();
                                    var pngOpts = new ExportOptionsSaveForWeb;
                                    pngOpts.PNG8 = false;
                                    pngOpts.transparency = true;
                                    pngOpts.interlaced = false;
                                    pngOpts.quality = 100;
                                    activeDocument.exportDocument(new File(saveFile),ExportType.SAVEFORWEB,pngOpts);
                                    • 15. Re: Export Groups to Files?
                                      MortenSJ00 Level 1
                                      Great scripts.
                                      I have no idea how Photoshop scripts work, but i would be very happe if someone could tweak the script so it only selects the root groups and esports if for jpgs.
                                      • 16. Re: Export Groups to Files?
                                        anthony_abraira Level 1
                                        Or if someone can have one that saves it as PSD... trimmed... can someone hook me up with that script? I'll send you some Paypal beer donation. Thanks in advance!
                                        • 17. Re: Export Groups to Files?
                                          This should now save as a PSD ...
                                          #target photoshop
                                          function main(){
                                          dupLayers();
                                          var saveFile= File(oldPath +"/"+doc.layerSets[a].name +".psd");
                                          SavePSD(saveFile);
                                          main();
                                          function SavePSD(saveFile){
                                          psdSaveOptions = new PhotoshopSaveOptions();
                                          psdSaveOptions.embedColorProfile = true;
                                          psdSaveOptions.alphaChannels = true;
                                          activeDocument.saveAs(saveFile, psdSaveOptions, true, Extension.LOWERCASE);
                                          • 18. Re: Export Groups to Files?
                                            Hey thanks for the quick reply. However I am getting an error message and I am not getting prompted with the dialogue box to choose which ones I want to extract ...
                                            here is the error message
                                            • 20. Re: Export Groups to Files?
                                              This script isn't written for selected layersets, it does them all.
                                              If you want to save selected layers/layersets this script might do the job as it support layers and layerset and persistant Top/Background layers.
                                              #target photoshop
                                              function main(){
                                              var LSets = activeDocument.layerSets.length;
                                              var ArtLayers = activeDocument.artLayers.length;
                                              var NoOfLayers = activeDocument.layers.length;
                                              var Back = hasBackground();
                                              var hasTop = false;
                                              var selLayers =getSelectedLayersIdx();
                                              var selGroups=[];
                                              if(LSets>0){
                                                  for(var s in selLayers){
                                                 if(isLayerSet(selLayers[s])) selGroups.push(selLayers[s]);
                                              if(activeDocument.layers[0].typename == 'ArtLayer') hasTop = true;
                                              var win = new Window('dialog','Layer Saver');
                                              g = win.graphics;
                                              var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.99, 0.99, 0.99, 1]);
                                              g.backgroundColor = myBrush;
                                              win.p1= win.add("panel", undefined, undefined, {borderStyle:"black"});
                                              win.p1.preferredSize=[500,20];
                                              win.g1 = win.p1.add('group');
                                              win.g1.orientation = "row";
                                              win.title = win.g1.add('statictext',undefined,'Layer Saver');
                                              win.title.alignment="fill";
                                              var g = win.title.graphics;
                                              g.font = ScriptUI.newFont("Georgia","BOLDITALIC",22);
                                              win.g5 =win.p1.add('group');
                                              win.g5.orientation = "column";
                                              win.g5.alignChildren='left';
                                              win.g5.spacing=0;
                                              if(LSets == 0){
                                              win.g5.rb1 = win.g5.add('radiobutton',undefined,'Save selected layers');
                                              win.g5.rb2 = win.g5.add('radiobutton',undefined,'Save selected layers along with the top layer');
                                              win.g5.rb3 = win.g5.add('radiobutton',undefined,'Save selected layers along with background layer');
                                              win.g5.rb4 = win.g5.add('radiobutton',undefined,'Save all layers');
                                              win.g5.rb5 = win.g5.add('radiobutton',undefined,'Save all layers along with the top layer');
                                              win.g5.rb6 = win.g5.add('radiobutton',undefined,'Save all layers along with background layer');
                                              win.g5.rb3.enabled=Back;
                                              win.g5.rb6.enabled=Back;
                                              win.g5.rb4.value=true;
                                              }else{
                                              win.g5.rb1 = win.g5.add('radiobutton',undefined,'Save selected layerSets');
                                              win.g5.rb2 = win.g5.add('radiobutton',undefined,'Save selected layerSets along with the top layer');
                                              win.g5.rb3 = win.g5.add('radiobutton',undefined,'Save selected layerSets along with background layer');
                                              win.g5.rb4 = win.g5.add('radiobutton',undefined,'Save all layerSets');
                                              win.g5.rb5 = win.g5.add('radiobutton',undefined,'Save all layerSets along with the top layer');
                                              win.g5.rb6 = win.g5.add('radiobutton',undefined,'Save all layerSets along with background layer');
                                              win.g5.rb2.enabled=hasTop;
                                              win.g5.rb5.enabled=hasTop;
                                              if(selGroups.length <1){
                                                  win.g5.rb1.enabled=false;
                                                  win.g5.rb2.enabled=false;
                                                  win.g5.rb3.enabled=false;
                                              win.p2 = win.add("panel", undefined, undefined, {borderStyle:"black"});
                                              win.p2.preferredSize=[500,20];
                                              win.p2.st1 = win.p2.add('statictext',undefined,'Output details');
                                              win.p2.st1.graphics.font = ScriptUI.newFont("Tahoma", "Bold", 18);
                                              win.g10 =win.p2.add('group');
                                              win.g10.orientation = "row";
                                              win.g10.alignment='left';
                                              win.g10.et1 = win.g10.add('edittext');
                                              win.g10.et1.preferredSize=[350,20];
                                              win.g10.bu1 = win.g10.add('button',undefined,'Select Folder');
                                              win.g10.bu1.onClick=function(){
                                              var Folder1 = Folder(app.activeDocument.path);
                                              outputFolder = Folder.selectDialog("Please select the output folder",Folder1);
                                               if(outputFolder !=null){
                                                win.g10.et1.text =  decodeURI(outputFolder.fsName);
                                              win.g12 =win.p2.add('group');
                                              win.g12.orientation = "row";
                                              win.g12.alignment='left';
                                              win.g12.cb1 = win.g12.add('checkbox',undefined,'Merge Visible Layers?');
                                              win.g12.cb2 = win.g12.add('checkbox',undefined,'Trim Layer');
                                              win.g15 =win.p2.add('group');
                                              win.g15.orientation = "row";
                                              win.g15.alignment='left';
                                              var Options= ["Layer/Group Name","FileName + Sequence No.","FileName + Layer/Group Name ","User Defined with Sequence No."];
                                              win.g15.st1 = win.g15.add('statictext',undefined,'Save Options..');
                                              win.g15.dd1 = win.g15.add('dropdownlist',undefined,Options);
                                              win.g15.dd1.selection=0;
                                              win.g15.et1 = win.g15.add('edittext');
                                              win.g15.et1.preferredSize=[150,20];
                                              win.g15.et1.hide();
                                              win.g15.dd1.onChange=function(){
                                                if(this.selection.index==3){
                                                    win.g15.et1.show();
                                                    }else{
                                                        win.g15.et1.hide();
                                              win.g18 =win.p2.add('group');
                                              win.g18.orientation = "row";
                                              win.g18.st1 = win.g18.add('statictext',undefined,'Save as :');
                                              var Types = ["PNG","PSD","PDF","TIF","JPG"];
                                              win.g18.dd1 = win.g18.add('dropdownlist',undefined,Types);
                                              win.g18.dd1.selection = 0;
                                              win.g18.alignment='left';
                                              win.g20 =win.p2.add('group');
                                              win.g20.orientation = "row";
                                              win.g20.bu1 = win.g20.add('button',undefined,'Process');
                                              win.g20.bu1.preferredSize=[200,35];
                                              win.g20.bu2 = win.g20.add('button',undefined,'Cancel');
                                              win.g20.bu2.preferredSize=[200,35];
                                              win.g20.bu1.onClick=function(){
                                                  if(win.g10.et1.text == ''){
                                                      alert("No Output Folder has been Selected!");
                                                      return;
                                                  if(win.g15.dd1.selection.index==3){
                                                      if(win.g15.et1.text ==''){
                                                          alert("No FileName Has Been Entered!");
                                                          return;
                                                  win.close(1);
                                              Process();
                                              win.center();
                                              win.show();
                                              function Process(){
                                              if(LSets == 0){
                                              //Process layers only
                                              if(win.g5.rb1.value){//Save selected layers
                                              for(var b in selLayers){
                                                  selectLayerByIndex(Number(selLayers[b]));
                                                   var lName = activeDocument.activeLayer.name;
                                                  var saveFile= File(outputFolder+ "/" + getName(b,lName));
                                                  dupLayers();
                                                  if(win.g12.cb1.value){
                                                      try{activeDocument.mergeVisibleLayers();}catch(e){}
                                                   if(win.g12.cb2.value){
                                                       try{activeDocument.trim(TrimType.TRANSPARENT,true,true,true,true);}catch(e){}
                                                  SaveDOC(saveFile);
                                                  }//End Save selected layers
                                              if(win.g5.rb2.value){//Save selected layers along with the top layer
                                                  activeDocument.activeLayer= activeDocument.layers[0];
                                                  selectLayerByIndex(Number(selLayers[b]),true);
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save selected layers along with the top layer
                                              if(win.g5.rb3.value){//Save selected layers along with background layer
                                                  activeDocument.activeLayer = activeDocument.layers[activeDocument.layers.length-1];
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save selected layers along with background layer
                                              if(win.g5.rb4.value){//Save all layers
                                              selectAllLayers();
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save all layers
                                              if(win.g5.rb5.value){//Save all layers along with the top layer
                                              selectAllLayers(1);
                                                  activeDocument.activeLayer = activeDocument.layers[0];
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save all layers along with the top layer
                                              if(win.g5.rb6.value){//Save all layers along with background layer
                                              selectAllLayers();
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save all layers along with background layer
                                                  }else{
                                              //Process LayerSets Only
                                              if(win.g5.rb1.value){//Save selected layerSets
                                                  for(var g in selGroups){
                                                      selectLayerByIndex(Number(selGroups[g]));
                                                      var saveFile= File(outputFolder+ "/" + getName(g,lName));
                                                      dupLayers();
                                                  SaveDOC(saveFile);
                                                 }//End Save selected layerSets
                                              if(win.g5.rb2.value){//Save selected layerSets along with the top layer
                                                  selectLayerByIndex(Number(selGroups[g]),true);
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save selected layerSets along with the top layer
                                              if(win.g5.rb3.value){//Save selected layerSets along with background layer
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save selected layerSets along with background layer
                                              if(win.g5.rb4.value){//Save all layerSets
                                                  for(var g =0;g<LSets;g++){
                                                       activeDocument.activeLayer = activeDocument.layerSets[g];
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save all layerSets
                                              if(win.g5.rb5.value){//Save all layerSets along with the top layer
                                                  var TopIDX =getSelectedLayersIdx();
                                                       selectLayerByIndex(Number(TopIDX[0]),true);
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save all layerSets along with the top layer
                                              if(win.g5.rb6.value){//Save all layerSets along with background layer
                                                       selectLayerByIndex(0,true);
                                                  dupLayers();
                                                  SaveDOC(saveFile);
                                                  }//End Save all layerSets along with background layer
                                              function getName(seq,lName){
                                              seq = zeroPad((Number(seq)+1), 3);
                                               var dName = decodeURI(activeDocument.name).replace(/\.[^\.]+$/, '');
                                              var Name ='';
                                              switch (Number(win.g15.dd1.selection.index)){
                                                  case 0: Name += lName; break;
                                                  case 1: Name += dName +"-"+seq; break;
                                                  case 2: Name += dName +"-"+ lName; break;
                                                  case 3: Name += win.g15.et1.text + "-"+seq; break;
                                                  default :break;
                                              return Name;
                                              function SaveDOC(saveFile){
                                                  switch(Number(win.g18.dd1.selection.index)){
                                                      case 0 : SavePNG(File(saveFile+".png")); break;
                                                      case 1:  SavePSD(File(saveFile+".psd")); break;
                                                      case 2:  SavePDF(File(saveFile+".pdf")); break;
                                                      case 3:  SaveTIFF(File(saveFile+".tif")); break;
                                                      case 3:  SaveJPG(File(saveFile+".jpg"),8); break;
                                                      default : break;
                                              main();
                                              function hasBackground() {
                                                 var ref = new ActionReference();
                                                 ref.putProperty( charIDToTypeID("Prpr"), charIDToTypeID( "Bckg" ));
                                                 ref.putEnumerated(charIDToTypeID( "Lyr " ),charIDToTypeID( "Ordn" ),charIDToTypeID( "Back" ));
                                                 var desc =  executeActionGet(ref);
                                                 var res = desc.getBoolean(charIDToTypeID( "Bckg" ));
                                                 return res
                                              function getSelectedLayersIdx(){
                                                    var selectedLayers = new Array;
                                                    ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                                                    if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                                                       desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                                                        var c = desc.count
                                                        var selectedLayers = new Array();
                                                        for(var i=0;i<c;i++){
                                                          try{
                                                             activeDocument.backgroundLayer;
                                                             selectedLayers.push(  desc.getReference( i ).getIndex() );
                                                          }catch(e){
                                                             selectedLayers.push(  desc.getReference( i ).getIndex()+1 );
                                                     }else{
                                                       ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                                                       ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                                                       try{
                                                          selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1);
                                                       }catch(e){
                                                          selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
                                                    return selectedLayers;
                                              function isLayerSet(idx) {
                                                 ref.putIndex(1283027488, idx);
                                                 var type = desc.getEnumerationValue(stringIDToTypeID("layerSection"));
                                                 var res = typeIDToStringID(type);
                                                 if(res == 'layerSectionStart') return true;
                                                     return false;
                                              function selectLayerByIndex(index,add){
                                               add = (add == undefined)  ? add = false : add;
                                                  ref.putIndex(charIDToTypeID("Lyr "), index);
                                                  var desc = new ActionDescriptor();
                                                  desc.putReference(charIDToTypeID("null"), ref );
                                                     if(add) desc.putEnumerated( stringIDToTypeID( "selectionModifier" ), stringIDToTypeID( "selectionModifierType" ), stringIDToTypeID( "addToSelection" ) );
                                                    desc.putBoolean( charIDToTypeID( "MkVs" ), false );
                                                 try{
                                                  executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
                                              }catch(e){}
                                              function selectAllLayers(layer) {//does not select background layer
                                              if(layer == undefined) layer = 0;
                                              if(activeDocument.activeLayer.isBackgroundLayer)
                                              activeDocument.activeLayer = activeDocument.layers[activeDocument.layers.length-2];
                                              var BL = activeDocument.activeLayer.name;
                                              activeDocument.activeLayer = activeDocument.layers[layer];
                                                  var desc5 = new ActionDescriptor();
                                                      var ref3 = new ActionReference();
                                                      ref3.putName( charIDToTypeID('Lyr '), BL);
                                                  desc5.putReference( charIDToTypeID('null'), ref3 );
                                                  desc5.putEnumerated( stringIDToTypeID('selectionModifier'), stringIDToTypeID('selectionModifierType'), stringIDToTypeID('addToSelectionContinuous') );
                                                  desc5.putBoolean( charIDToTypeID('MkVs'), false );
                                                  executeAction( charIDToTypeID('slct'), desc5, DialogModes.NO );
                                              function zeroPad(n, s) {
                                                 n = n.toString();
                                                 while (n.length < s)  n = '0' + n;
                                                 return n;
                                              function SaveTIFF(saveFile){
                                              tiffSaveOptions = new TiffSaveOptions();
                                              tiffSaveOptions.embedColorProfile = true;
                                              tiffSaveOptions.alphaChannels = true;
                                              tiffSaveOptions.layers = true;
                                              tiffSaveOptions.imageCompression = TIFFEncoding.TIFFLZW;
                                              activeDocument.saveAs(saveFile, tiffSaveOptions, true, Extension.LOWERCASE);
                                              function SavePDF(saveFile){
                                              pdfSaveOptions = new PDFSaveOptions();
                                              activeDocument.saveAs(saveFile, pdfSaveOptions, true, Extension.LOWERCASE);
                                              function SaveJPG(saveFile, jpegQuality){
                                              jpgSaveOptions = new JPEGSaveOptions();
                                              jpgSaveOptions.embedColorProfile = true;
                                              jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
                                              jpgSaveOptions.matte = MatteType.NONE;
                                              jpgSaveOptions.quality = jpegQuality; //1-12
                                              activeDocument.saveAs(saveFile, jpgSaveOptions, true,Extension.LOWERCASE);
                                              • 21. Re: Export Groups to Files?
                                                Thank you! I'll tinker with this. Very nice interface. Kudos! Do you still want that beer money? Send me your Paypal email...
                                                • 22. Re: Export Groups to Files?
                                                  Everything is free here, enjoy!
                                                  • 23. Re: Export Groups to Files?
                                                    - JM - Level 3
                                                    very nice and helpful script!   thanks
                                                    • 24. Re: Export Groups to Files?
                                                      Dennybot13 Level 1
                                                      Paul, this script is GREAT, and has nearly everything I need. Very nice indeed. I'm just getting exposed to scripting and hope to dive in myself soo.
                                                      That said, I have a few things happening that I would greatly appreciate help with...
                                                      In Paul's above script (which I have not modified), the 'save to jpg' function is buggy for me. Once I choose my settings and destination folder and activate the script, the output JPG files are 'blackholing.' They are just not ending up anywhere. PNG works fine.
                                                      I wonder if anyone might take a look at this with me?
                                                      Beyond getting JPG outp[ut to work, I can see one modification that would really make this script that much more powerful: Being able to include top and/or bottom LAYERSETS, instead of just layers. How involved is that kind of mod?
                                                      But really, the script is great and quite powerful. I just need the JPG output to work iin the near term.
                                                      Help, anyone?
                                                      • 25. Re: Export Groups to Files?
                                                        Dennybot13 Level 1
                                                        Just to be clear, the script I'm referring to is Paul's from May 19, 2011 5:18 PM.
                                                        • 26. Re: Export Groups to Files?
                                                          Sorry about saving as jpg not working, I have now fixed that error and the new file can be downloaded from:-
                                                          http://www.scriptsrus.talktalk.net/
                                                          I will also have a look at adding the extra options as you have described.
                                                          • 27. Re: Export Groups to Files?
                                                            Dennybot13 Level 1
                                                            That is simply marvelous.
                                                            The saving of top and bottom groups would be quite helpful when it comes to baking in a flexible variety of fades and backgrounds into output images.
                                                            Very cool of you, and many thanks.
                                                            • 28. Re: Export Groups to Files?
                                                              I have just added those options and is ready to be downloaded.
                                                              All the best.
                                                              • 29. Re: Export Groups to Files?
        Dennybot13 Level 1
        Paul, that is great, great stuff.
        I know I'm likely teetering on the edge of asking for one too many favors, but something that would be quite useful is the addition of an option to:
        Save all layerSets along with the top and bottom layerSets
        That way, users could bake in a top effect, say, a fade or the like, along with a background.
        Possible?
        • 30. Re: Export Groups to Files?
        No Problem, it's done and ready to download
        • 31. Re: Export Groups to Files?
        MortenSJ00 Level 1
        Its not working on mac cs5
        • 32. Re: Export Groups to Files?
        nogreydes Level 1
        if you guys are still around, and can help I would love it. Exact same problems and needs to everyone here above. I have NO knowledge of editing scrips. The one for PDF worked but as you know really time consuming to then convert PDF to JPEGS. Can someone provide me the the script to download which works for converting the layer groups to .jpeg.
        I would very very much appreciate it. I tried to edit the code for the script but very shamefull unsuccessful
        Thank you
        • 33. Re: Export Groups to Files?
        The Script from which post are you referring to exactly?
        • 34. Re: Export Groups to Files?
        Have you tried this one?
        http://www.scriptsrus.talktalk.net/Layer%20Saver.htm
        This supports jpeg
        • 35. Re: Export Groups to Files?
        nogreydes Level 1
        You are an absolute legend. Thanks mate. You saved my life. thanks thanks thanks
        • 36. Re: Export Groups to Files?
        froalskiner Level 1
        Fantastic script!  Is there a way to have this script combine the exported JPG's or PDF's into a single PDF?
        • 37. Re: Export Groups to Files?
        Sorry but the option of creating multipage PDFs was removed in Photoshop CS4 and that functionality was moved to Bridge and that process is not scriptable.
        So if you have Photoshop CS2 or CS3 you could open all the JPGs and use File - Automate - PDF Presentation to create your pdf.
        • 38. Re: Export Groups to Files?
        Planktos1 Level 1
        After 30 mins on Google I found this thread and downloaded the script for Layer Saver
        I knew what I wanted to do, but not how to do it.
        I have 100s of files each with up to 100 layers that I need to export as separate trimmed psd files
        This script does it. It has saved me so much hassle and so a HUGE 'thank you' is due to you
        and of course,
        Seasons Greetings !
        • 39. Re: Export Groups to Files?
        hadelaar Level 1
        sounds great,but
        is this script also available for Illustrator?
        That would make our day and make you the person of the year!
        1 2 Previous Next
