I have Java Enterprice Application with BlazeDS installed there and Flash client (created in pure Flash -not Flex). Now I want to send my custom Java object over the wire.
On The java side i have method:
public void echo1(Dupa dupa){
System.out.println("--");
System.out.println(dupa.dup);
On the Flash side:
var myDupa:Dupa = new Dupa();
myDupa.dup = "www";
var rooms:Object = remoteObject.echo1(myDupa);
Where object's 'Dupa' definition is:
Java:
package test;
public class Dupa {
public String dup;
Flash:
package test {
[Bindable]
[RemoteClass(alias="test.Dupa")]
public class Dupa {
public var dup:String;
And I always receives error:
[FaultEvent fault=[RPC Fault faultString="Cannot invoke method 'echo1'." faultCode="Server.ResourceUnavailable" faultDetail="The expected argument types are (test.Dupa) but the supplied types were (flex.messaging.io.amf.ASObject) and converted to (null)."] messageId="2EEB750E-240E-9AE3-9AE4-284E56C81B89" type="fault" bubbles=false cancelable=true eventPhase=2]
When i change me Java method signature to:
public String echo2(flex.messaging.io.amf.ASObject test){...}
Everything work fine. But it this situation I have ASObject which i have to convert to test.Dupa.
The question is:
How can i force Flash to convert sent content to my custom object (test.Dupa)?
If its not possible, how can I convert ASObject object to test.Dupa (or whatever I want).
Thx fo replies.
Total Likes
Looks like RemoteClass tag did not have any effect. Can you try the following: Within the Dupa AS class, decare a constructor and explictly call the flash.net.registerClassAlias("test.Dupa", test.Dupa) in it.
Rohit
It helped! Thank You very much.
But there is another question (or two):
Why the "RemoteClass" metadata is not recognized by the Flash Player?
Do I need some import statement in my AS class or some liberaries are missing?
And there is another one problem. Everything work fine for this function call:
But for this function call:
var rooms:Dupa = remoteObject.echo1(myDupa);
I receives this error:
TypeError: Error #1034: Type Coercion failed: cannot convert mx.rpc::AsyncToken@2708d041 to test.Dupa.
It means, in my opinion, that received object's type is :AsyncToken. How can i get my Dupa object from it.
Total Likes
Total Likes
The Flex compiler ultimately converts the metadata tags into AS code during compilation. In case of [RemoteClass], it rougly gets converted to the what I wrote in my earlier response.
As regards the second question, here you can get access to the result of the RemoteObject.
var token:AsyncToken = remoteObject.echo1(myDupa);
token.addAsyncResponder(resultFunc, faultFunc));
public function resultFunc(r:ResultEvent, t:Object = null) {
room = r.result as Room;
public function faultFunc(f:FaultEvent, t:Object = null) {
Rohit
Total Likes
