1. Re: Can I create a keyboard shortcut to go to start and/or end of work area?
Colin Brougham May 20, 2011 10:11 AM (in response to Mark Morreau)Can I create a keyboard shortcut to take the CTI to the beginning or end of the work area in the Timeline panel?
No.
Also, can I remap the keyboard shortcut (~) that maximises the current panel?
In CS5, it's under Application and called "Maximize or Restore Frame." In CS5.5 it's also under Application, but you have two choices: "Maximize or Restore Active Frame" and "Maximize or Restore Frame Under Cursor." The latter is how CS5 works; the former is a new addition, and will only maximize/restore whatever frame is currently outlined in yellow, e.g. active.
2. Re: Can I create a keyboard shortcut to go to start and/or end of work area?
Mark Morreau May 20, 2011 10:41 AM (in response to Colin Brougham)Thanks, Colin.
I'll file a FR for that work area shortcut.
Cheers
Mark
3. Re: Can I create a keyboard shortcut to go to start and/or end of work area?
Colin Brougham May 20, 2011 10:56 AM (in response to Mark Morreau)You're welcome, and good idea. As a more immediate workaround, you could consider dropping sequence markers, or even just marking an in and out point where you need to have quick(er) access.
4. Re: Can I create a keyboard shortcut to go to start and/or end of work area?
shooternz May 20, 2011 4:57 PM (in response to Mark Morreau)New Terminology for CS5.5
The CTI is now called the "Play Head"
