I'd like to use a particular font in my topics but it's not in the font list in RH7. Is it possible to add it in?
From a previous thread, thanks to Mayank. http://forums.adobe.com/message/3480040#3480040
Please verify if the font sets in your project has been modified/deleted. (You can do so by creating a new RoboHelp project and verifying if the required font appears in the formatting tool bar fonts dropdown for the new project). If it appears, then close RoboHelp project. Go to new project folder on the disk and copy rhfontset.apj file from new project to your current project. PLEAE NOTE that this will ove
...Copy link to clipboard
You can just add fonts to your PC via the Control Panel. Once installed they should be available in all applications.
The RoboColum(n) | @robocolumn | Colum McAndrew |
That's what I thought but it doesn't seem to be happening. The font I want is in C:\Windows\Fonts and shows up in Word but not in RH.
Please verify if the font sets in your project has been modified/deleted. (You can do so by creating a new RoboHelp project and verifying if the required font appears in the formatting tool bar fonts dropdown for the new project). If it appears, then close RoboHelp project. Go to new project folder on the disk and copy rhfontset.apj file from new project to your current project. PLEAE NOTE that this will overwrite any existing modifications done in the font sets in your project.
Please note that if you use a custom font, the end user also needs to have the font installed on their system. If the end user does not have the specified font installed, the browser will show the backup font if you have specified this in your style sheet. If you have not supplied a backup font, the browser will use the default font.
You can ensure that everyone sees the correct font by using the @font-face rule: http://www.w3schools.com/css3/css3_pr_font-face_rule.asp. Take note of the example at the top of the page as Internet Explorer requires it's own font type.
Greet,
Willam
Thanks all, now sorted!
