I have just installed flash player 10.3 debug ax and plugin, and replaced the original builder and catalyst player files with 10.3 in both:
C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.5\player\win\10.3
C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\player\win\
Everything works so far if i keep min flash player version at 10.2 in the project properties.
I then copied the flashplayer_inc_playerglobal_051211.swc to both:
C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.5\sdks\4.5.0\frameworks\libs\player\10.3\playerglobal.swc
C:\Program Files (x86)\Adobe\Adobe Flash Catalyst CS5.5\sdks\4.5.0\frameworks\libs\player\10.3\playerglobal.swc
If I change the project properties to a minimum player version of 10.3, and add -swf-version=12 to the compiler args,
I get a Flash Catalyst Incompatibility error:
Configuration problem: The library path must include the following entry: ${PROJECT_FRAMEWORKS}/libs/player/10.2/playerglobal.swc
MyApplication Unknown Flash Catalyst Project Incompatibility
Any input is greatly appreciated.
Message was edited by: rjp421
This seems to be a bug, I have filed http://bugs.adobe.com/jira/browse/TH-13654 for you to track.
If you are not able to open the project in FC, then I would recommend you to fallback to 10.2 and when packaging agian change it to 10.3 as a workaround for now.
Am I the only one with this problem?
How am I supposed to correctly target 10.3 in a flash catalyst compatible project?
Thanks.
A simple yes or no would be helpful, so I can stop this wild goose chase.
Thanks.
I just noticed the 10.3 release playerglobal swc was released finally.
http://download.macromedia.com/pub/labs/flashplatformruntimes/flashplayer10-3/flashplayer10-3_playerglobal_052011.swc
The problem seems to be with setting the minimum flash player version in the project properties.
10 2 0 works.
10 3 0 does not work, and gives the catalyst incompatibility warning.
What's the deal?
This problem still exists in FB 4.5.1.
That bug tracker link does not work, it says permission violation.
I did delete my .metadata, .fxpTemp, and cascaded folders in my workspace before launching FB.
Any updated info is appreciated, thanks.
The bug link does not work, is there any update to this problem?
Is there any config file or anything that i can change, to allow it to look for the /10.3/ folder,
instead of /10.2/ like in the compatibility error?
Is there a new link for this bug??
Thanks.
