1. Re: Illustration numbers using "chapter #" text variable
P Spier Oct 29, 2009 12:54 PM (in response to E Diane King)Untested, but you might be able to copy the variable to the clipboard, then use contents of clipboard in the change to field in your search and replace.
2. Re: Illustration numbers using "chapter #" text variable
E Diane King Oct 29, 2009 2:23 PM (in response to P Spier)If you'll read again my initial post, you'll see that I tried that. The result was page numbers instead of the chapter #. Not sure why.
3. Re: Illustration numbers using "chapter #" text variable
P Spier Oct 29, 2009 2:28 PM (in response to E Diane King)Oh Yes, I do see that now. Sorry.
I had in mind creating a text frame and putting in a chapter number variable, then copying that variable. Is that how you did it?
4. Re: Illustration numbers using "chapter #" text variable
P Spier Oct 29, 2009 2:32 PM (in response to P Spier)I just tested that, and it seems to work OK here.
5. Re: Illustration numbers using "chapter #" text variable
E Diane King Oct 29, 2009 2:33 PM (in response to P Spier)I did the first illustration number manually, inserting the variable in place of the manual lesson number. Then I copied the whole thing to the clipboard and did a a search for "Illustration ^9-" and replace with clipboard contents unformatted. I got "Illustration [page number]-" I thought that was really weird since the page number is a special character and not a variable--at least as far as I know. I don't know how ID handles it on the back end, but they are inserted from different menus.
6. Re: Illustration numbers using "chapter #" text variable
E Diane King Oct 29, 2009 2:36 PM (in response to P Spier)Hmm, are you in CS4? I'm in CS3 for this project. I have CS4 on my personal laptop, but at work I only have CS3. I didn't test it in CS4 because it would be difficult to do this project on my personal laptop. I'm working with a team that all use CS3. But it might be worth importing it in long enough to fix the variables and then back saving if it works in CS4.
7. Re: Illustration numbers using "chapter #" text variable
P Spier Oct 29, 2009 2:55 PM (in response to E Diane King)If I'm following your directions correctly, it's working in both CS3 and CS4 here. Are you sure you used a chapter number variable? If you copy and paste the variable into the find change dialog it should look like <0018>.
8. Re: Illustration numbers using "chapter #" text variable
E Diane King Oct 29, 2009 2:58 PM (in response to P Spier)I'll double check it in the morning. It would be great if it does work and I just messed something up. I've been known to do that.
9. Re: Illustration numbers using "chapter #" text variable
Alex J Whittingham May 26, 2011 4:34 AM (in response to E Diane King)I have exactly the same problem in CS4. I am trying to change illustration numbering from (text).(illustration number) to (chapter number variable). (illustration number) using find and replace. The find/replace dialogue box shows the code <0018> but, rather than chapter numbers, page numbers are inserted when I execute. Any ideas?
10. Re: Illustration numbers using "chapter #" text variable
John Hawkinson May 26, 2011 9:27 PM (in response to Alex J Whittingham)Export to IDML, unzip, find the story file, find/change in your favorite editor, re-zip, open the IDML.
Or since you're using CS4 you can use INX and you won't have to unzip/zip, but you might lose features that aren't in CS3 (not sure).
