Locked
Flash Player Videos Corrupt or in top left corner
May 26, 2011 May 26, 2011
I have rebuild my HP Laptop. It is Windows 7 64bit with IE9
When I go to a flash enabled site (such as bbc.co.uk) the flash animation is either on the top left corner or flickers when I move the mouse over it. For example on the BBC homepage the clock that is usually on the right of the graphics appears in the top left hand corner with half of it missing.
I am using Flash V10.3
Here is what I've done so far:
Uninstalled / reinstalled Flash
Uninstalled IE9, and it is fine with IE8, as soon as I reinstall IE9 it fails again
Tried firefox which is also fine.
Any help would be greatly appreciated.
2.6K
Deleted User
I don’t know if anyone has suggested this or not but what I did to make Flash 10.3 work on my IE9 (32 bit on a 64bit Windows 7) was to click on the gear icon, then click on “internet options”, then “advanced”, then finally check “use software rendering instead of GPU rendering” finally you must close IE9 for the settings to work.
See if that helps.
eidnolb
Guest
Same problem here, startet recently! Flash animations flickers in wrong positions.
Related to Flash 10.3 (.181.14)? Lenovo X201, Win7 32bit, IE9, Intel HD graphics 8.15.10.2312. Fully updated.
Guest
See if that helps.
eidnolb
That worked perfectly, thanks for your help
Guest
Hi, glad that worked. I wish I could remember the person that found that solution, but I've lost the thread!! Anyway, a lot of users have used this and it's been working.
eidnolb
Guest
May 27, 2011 May 27, 2011
That's a workaound where you lose some..
In another thread Adobe informs that they have released a new beta version of Flash fixing the problem.
http://download.macromedia.com/pub/labs/flashplatformruntimes/flashplayer10-3/flashplayer10-3_b3_activex_052311.exe
Regards
Steen
Guest
Thank you so much for reposting that!  I was coming here trying to figure out what was up b/c I had the same problem.
I appreciate it very much...thought I'd have an epileptic seizure b/c of this!  😉
Guest
Hi StephWoo, Glad this thread helped you also. I haven't experienced what you and the OP did, but can imagine one would think the worst!!
eidnolb
