Locked
Unable to build Any AIR app with Flash Builder 4.0.1
Guest
May 23, 2011 May 23, 2011
Using Flash Builder 4.0.1 on Win 7 32bit under VM - running as Admin.
with the Flex 4.5.0 SDK
Any AIR app that I try to debug/build I get:
Launch Failed
Process terminated without establishing connection to debugger.
error while loading initial content
Launch command details:  "C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.5.0\bin\adl.exe" -runtime "C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.5.0\runtimes\air\win" C:\_win_work\[projectname]\bin-debug\[projectname]-app.xml C:\_win_work\[projectname]\bin-debug
Doesn't matter if it's a brand new project - or an old project - still get errors. Also doesn't matter if it's sdk 4.5.0 or 4.1.0; slightly different error with 4.1.0:
!AIRLaunchDelegate.AIRProcess.correctAppXMLProblem!
invalid application descriptor: descriptor version does not match runtime version
Launch command details:  "C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.1.0\bin\adl.exe" -runtime "C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.1.0\runtimes\air\win" "C:\Users\Adobe Flash Builder 4\test2\bin-debug\test2-app.xml" "C:\Users\Adobe Flash Builder 4\test2\bin-debug"
Please help.
-Will
2.9K
May 27, 2011 May 27, 2011
Check your output folder under "Flex Build Path" options in the properties. Make sure the folder is correct.
Guest
Everything is set up correctly with the path folder - as this error occurs with an empty, blank, default AIR app built via "new".
I believe this is an error with 4.0.1 - as when I installed 4.5 demo (on OS X); this problem doesn't exist and I had no problems building an AIR app.
So either there's a problem with my version/copy/install of Flash Builder or it has something to do with the AIR/FB/and VMWare/Win7.
-Will
Adobe Employee ,
Jun 01, 2011 Jun 01, 2011
Can you post the contents of C:\Users\Adobe Flash Builder 4\test2\bin-debug\test2-app.xml? The error seems to indicate that AIR did not like something about the application descriptor file.
P.S: 4.5 Builder with 4.5 SDK is the recommended setup.
-Anirudh
