I know how to do this using for loops but was wondering if it was possible with Xpath.
My xml isl like that:
<ROOT>
<Batch BatchID="19" >
<Order Swift="AUD" />
<Order Swift="USD" />
</Batch>
<Batch BatchID="22" ">
</Batch>
</ROOT>
I want to return an array like that:
<Order Swift="AUD" BatchID="19" />
<Order Swift="USD" BatchID="19" />
<Order Swift="AUD" BatchID="22" />
thanks gurus
Yep. What have you done by way of finding out how to do it?
For starters, there are some easy to follow tutorials here:
http://www.zvon.org/comp/r/tut-XPath_1.html
Adam
thanks,Ive doen research, this is my working code, works but is clunky
<cfscript>
getData(xmlFeed);
function GetData(xml)
allOrders = XmlSearch(xmlFeed, "ROOT/Batch");
var i = 0;
for(i = 1; i <= arraylen(allOrders); i = i + 1)
var children = allOrders.XmlChildren;
for(var j = 1; j <= arraylen(children); j = j + 1)
structInsert(allOrders.XmlChildren
writeDump(allOrders);
</cfscript>
here is my code ,fixed
<cfhttp method="get" url="http:/52.xml"
result="xmlFeed"/>
<cfset xmlFeed = xmlParse(xmlFeed.FileContent)>
<cfscript>
getData(xmlFeed);
var final = arrayNew(1);
arrayAppend(final,allOrders.XmlChildren
writeDump(final );
</cfscript>
You can simplify that a bit. You're after the orders but you're only xpathing as far as the batch. You can path it all the way to the orders: /ROOT/batch/order. That saves some horsing around.
Also don't forget to always VAR •all• your variables inside functions. Not just some of them.
Adam
thanks
I know about
/ROOT/batch/order
but that doesn't get the outer Batch ID in each of the corresponding children, I think my loops are the only way for that?
Oops... forgot to reply. Yeah, you're right. Sorry: didn't notice you needed stuff from the parent nodes too.
Adam
Have you considered applying an XSL transformation instead of trying to parse/write the data in CF?
