Siince I updated to the latest Flash activeX player. The flash plugin gives a black screen with one line of colored pixels on top when switching to fullscreen mode in both the 32bits and 64bits vrsions of IE9. Reinstaling does not help.In normal mode it seems to work, the plugin version for all other browsers does work in both normal and fullscreen mode. Anyone else experiencing this issue or an idea on how to fix it?
FYI: i'm running Win7 professional x64 on an Intel Quadcore Q6600 2.4Ghz CPU and a Gforce 8400 GS GPU
Have you tried to disable Hardware Acceleration (Flash Player Settings)?
Also, are your Gforce drivers up to date?
P.S. also try to disable Hardware Acceleration in IE9; see http://forums.adobe.com/thread/853591
Disabling Hardware Acceleration in IE9 is a workaround and fullscreen mode is working. However the point of these updates is just the ability to use hardware acceleration.
My graphics drivers are defenitely up to date (it is the latest Beta Release for the Gforce 8 series). I saw there is a new release already and I will see tonight if the issue also presents itself with hardware acceleration enabled with the new release.
