SpaGeek,
Thanks for bringing this technique to our attention. I
decided to try it.
I started a new project with First_topic.htm,
Second_topic.htm, Third_topic.htm, Fourth_topic.htm, and so on.
Using your example above,
<h1>Title</h1>
<!-- #include file="path/filename" -->
I inserted the include line in Third_topic.htm in RoboHelp
TrueCode to refer to First_topic.htm. I closed and reopened the RH
project, looked at the TrueCode, and RH was content enough with the
line that it inserted a return before and after it.
However, when I generated WebHelp, RH completely ignored the
inserted code. It did not appear in the output, but it remained in
the RH TrueCode through several closings and reopenings of the
project.
In fact, isn't it the purpose of the !-- and -- tags to
insert a code comment that will be ignored?
The result was the same whether I inserted the code outside
of RoboHelp, with the project closed in RH or with the project open
in RH. After saving one in Notepad while RH was still running, I
refreshed the screen in RH and the code was there, untouched.
I don't have DreamWeaver, so perhaps there's where your
problem lies.
Still, if RH is going to ignore it on output, what's the
point?
Maybe a different example will show the problem. Would you
like to post one?
With respect,
Harvey
