1. Re: What the best approach to colour matching clips?
Ann Bens May 31, 2011 1:51 PM (in response to Mark Morreau)The Color Match effect went out the door with CS5.
You might want to look at this to get a certain colors adjusted.
2. Re: What the best approach to colour matching clips?
Mark Morreau Jun 1, 2011 10:39 AM (in response to Ann Bens)Thanks Ann.
That was useful, but not exactly what I was looking for.
Time for a feature request for the return of the Match Color effect?
Cheers
Mark
3. Re: What the best approach to colour matching clips?
Joe Riggs Oct 9, 2012 7:47 AM (in response to Mark Morreau)I started off using the reference monitor and vectorscope and waveform, but then wanted to be able to have two vectorscopes open at the same time for the "correct" clip and the one I was trying to match it to. I wanted to use one vectorscope as "reference" and use the fast colour corrector to adjust the other clip by looking at its vectorscope. But it doesn't seem that it's possible. Is it?
Is this still not possible in cs6?
4. Re: What the best approach to colour matching clips?
Fuzzy Barsik Oct 9, 2012 10:02 AM (in response to Mark Morreau)Open up your 'correct' clip in the Source Monitor and set the Output to whatever you like (e.g. to Vectorscope). Switch your workspace to Color Correction layout, and you'll get the Source Monitor, the Program Monitor and the Reference Monitor at hand.
5. Re: What the best approach to colour matching clips?
Mark Morreau Oct 9, 2012 10:14 AM (in response to Fuzzy Barsik)Thanks for your reply Fuzzy, but that still doesn't give you the ability to see two scopes side by side, which is what Joe Riggs and I want.
6. Re: What the best approach to colour matching clips?
Fuzzy Barsik Oct 9, 2012 10:30 AM (in response to Mark Morreau)Not sure I follow you...
How many monitors you eventually want to get opened and with which Output?
7. Re: What the best approach to colour matching clips?
Mark Morreau Oct 9, 2012 10:33 AM (in response to Fuzzy Barsik)Have you read the very first post in this thread? I thought I'd made it pretty obvious what I wanted.
8. Re: What the best approach to colour matching clips?
Fuzzy Barsik Oct 9, 2012 10:48 AM (in response to Mark Morreau)Normally I never read first posts and type something odd in the rush - that's my style.
However, if you need 3 (or even 4) monitors opened: one for the 'correct' clip Vectorscope, one for Vectorscope of the clip you're currently grading and one for the Composite Video of this clip, - I don't see anything that would prevent you from getting that.
Sorry for bothering you.
9. Re: What the best approach to colour matching clips?
shooternz Oct 9, 2012 12:51 PM (in response to Mark Morreau)FWIW: I have never seen dual vectorscopes in any CC Suite I have ever been in and never seen a colorist actually grade off the vectorscope. (only seen them used for set up , monitoring and QC checking)
I cant imagine how it would significantly help in your situation because you still have to get your hands on the correct "controls" to make the adjustments and the units in a vectorscope dont relate much to the controls.
If you can do that..you may as well CC "visually" to the image
Secondaries are the key to what you need.
10. Re: What the best approach to colour matching clips?
Mark Morreau Oct 24, 2012 1:56 PM (in response to shooternz)Just going back to this. The latest version of FCPX now give exactly what I want from Premiere: dual vectorscopes for doing exactly this kind of clip matching. Makes sense to me. And obviously make sense to the FCPX development team. FR time.
http://www.macrumors.com/2012/10/23/apple-releases-major-final-cut-pro-x-update/
"• Dual viewers, each with a video scope display, let you compare shots to match action and color"
11. Re: What the best approach to colour matching clips?
Fuzzy Barsik Aug 21, 2013 3:06 AM (in response to Mark Morreau)
