Hi, Whenever I try to save a template or a topic based on the template in Robohelp, it crashes.. Any idea? Thanks.
Is this limited to using one template? if so, what happens when you import that template into another project and use it there? If it still causes issues, it sounds like it has become corrupted and will need recreating. Out of interest, what is inside it. It would also be useful if you told us the RoboHelp version you are using.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Hi, I am using RoboHelp 7 and this problem is not limited to just one template. Facing this issue for every project. Only png images in header and a bit of text are inside the template.
Have you downloaded and installed all the RH7 updates? You'll find them here.
