Hi I was wondering if maybe it is not common practice to create a workspace and project in a Network Drive? When I do this Flash Builder runs extremely slow ( build workspace slow, saving slow, code hinting slow, undo slow, etc, etc, etc). Very painful!
When I place the same project locally on my C drive everything runs fine. So should I not be running things off the network? I would really like to since all my files are on the network with backup system. Can anyone offer some advice? Or maybe I need to optimize something? Thanks
- D
Hi.
Having your workspace and project on a network drive is not recommended as Flash Builder writes and reads a lot from the workspace and that will be slow.
A version control system such as svn or git with a repository hosted on your network drive should be perfectly fine. (You only take the hit when you check in and check out)
-Anirudh
