problem with multiple cffile upload.
Jun 01, 2011 Jun 01, 2011
Hello;
I am trying to program a small manager that will allow someone to upload 3 files, an image, pdf, and vcf files. I don't get any errors, BUT when I upload, the pdf file writes in as true to the db, it does upload the file, but I can't figure out why It's writting true and not the file name. I think I only need anothe rpair of eyes.. I can't figure it out. Can anyone help me out, and maybe see what I missed? I'll put in the form fields from the edit page and the query for the upload. So you get the idea.
Edit page:
<cfform action="Action.cfm" method="post" name="projects" id="projects" enctype="multipart/form-data">
<cfif isDefined("URL.ID")>
    <cfinput type="hidden" name="ID" value="#variables.ProjectID#">
    <cfinput type="hidden" name="oldimage" value="#MYFile#">
    <cfinput type="hidden" name="oldPDF" value="#MYPdf#">
    <cfinput type="hidden" name="oldVCF" value="#MYVfile#">
  </cfif>
<cfinput type="file" name="MYFile" id="MYFile">
<cfinput name="MYPdf" type="file" id="MYPdf">
<cfinput name="MYVfile" type="file" id="MYVfile">
</cfform>
Action Page:
<!--- set file uploading vars --->
<cfparam name="fileuploaded" type="boolean" default="false">
<cfparam name="uploadedfile" default="">
<cfset pathToFile = "c:\websites\215296Kh8\images\contentfile\">
<cfif len(trim(form.MYFile))><!--- if a file has been selected --->
<!--- try uploading new file --->
<cftry>
<cffile Action="upload" filefield="MYFile" accept="image/gif,
image/jpg, image/jpeg, image/pjpeg"
destination="#pathToFile#" nameconflict="MAKEUNIQUE">
<cfset fileuploaded = true>
<cfset uploadedfile = cffile.serverfile>
<cfcatch type="any">
<!--- if upload did not suceed, reset file uploading vars --->
<cfset fileuploaded = false>
<cfset uploadedfile = "">
</cfcatch>
</cftry>
</cfif>
<cfparam name="PDFfileuploaded" type="boolean" default="false">
<cfparam name="PDFUploadedfile" default="">
<cfif len(trim(form.MYPdf))><!--- if a file has been selected --->
<cftry>
<cffile Action="upload" filefield="MYPdf" accept="application/pdf, application/msword" destination="#pathToFile#" nameconflict="MAKEUNIQUE">
<cfset PDFfileuploaded = true>
<cfset PDFUploadedfile = cffile.serverfile>
<cfset PDFfileuploaded = false>
<cfset PDFUploadedfile = "">
</cfcatch>
</cftry>
</cfif>
<cfparam name="VCFfileuploaded" type="boolean" default="false">
<cfparam name="VCFUploadedfile" default="">
<cfif len(trim(form.MYVfile))><!--- if a file has been selected --->
<cftry>
<cffile Action="upload" filefield="MYVfile" accept="text/x-vcard, application/vcard (Macintosh only), text/anytext, text/directory, application/x-versit (Eudora Plug-in), text/x-versit (Eudora Plug-in), text/x-vcalendar" destination="#pathToFile#" nameconflict="MAKEUNIQUE">
<cfset VCFfileuploaded = true>
<cfset VCFUploadedfile = cffile.serverfile>
<cfset VCFfileuploaded = false>
<cfset VCFUploadedfile = "">
</cfcatch>
</cftry>
</cfif>
<cfif form.id gt 0><!--- updating an existing record --->
<!--- if new file upload was successful and the feature has an file
associated with it - delete old file --->
<cfif fileuploaded is true AND len(trim(form.oldimage))>
<cfif FileExists(pathToFile & form.oldimage)>
<cffile action="delete" file="#pathToFile & form.oldimage#">
</cfif>
</cfif>
<cfif PDFfileuploaded is true AND len(trim(form.oldPDF))>
<cfif FileExists(pathToFile & form.oldPDF)>
<cffile action="delete" file="#pathToFile & form.oldPDF#">
</cfif>
</cfif>
<cfif VCFfileuploaded is true AND len(trim(form.oldVCF))>
<cfif FileExists(pathToFile & form.oldVCF)>
<cffile action="delete" file="#pathToFile & form.oldVCF#">
</cfif>
</cfif>
<cfquery name="UpdateDetails" datasource="#APPLICATION.dataSource#">
UPDATE Projects
SET
<cfif fileuploaded is true>
Projects.MYFile=<cfqueryparam cfsqltype="cf_sql_varchar" value="#uploadedfile#">,
</cfif>
Projects.mainPhone=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.mainPhone#">,
<cfif PDFfileuploaded is true>
Projects.MYPdf=<cfqueryparam cfsqltype="cf_sql_varchar" value="#PDFfileuploaded#">,
</cfif>
Projects.mainEmail=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.mainEmail#">,
<cfif VCFfileuploaded is true>
Projects.MYVfile=<cfqueryparam cfsqltype="cf_sql_varchar" value="#VCFfileuploaded#">,
</cfif>
Projects.position=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.position#">,
Projects.Body=<cfqueryparam cfsqltype="cf_sql_longvarchar" value="#form.PDSeditor#">,
Projects.CategoryID=<cfqueryparam value="#form.CategoryID#" cfsqlType="CF_SQL_INTEGER">
WHERE ProjectID = <cfqueryparam value="#form.ID#" cfsqlType="CF_SQL_INTEGER">
</cfquery>
<cflocation url="part-manager.cfm?ID=#Form.ID#" addtoken="no">
<cfelse>
<cfquery name="InsertDetails" datasource="#APPLICATION.dataSource#">
    INSERT INTO Projects
(MYFile, mainPhone, MYPdf, mainEmail, MYVfile, position, Body, CategoryID)
VALUES
(<cfqueryparam cfsqltype="cf_sql_varchar" value="#uploadedfile#" null="#NOT fileuploaded#">,
<cfqueryparam cfsqltype="cf_sql_varchar" value="#PDFUploadedfile#" null="#NOT PDFfileuploaded#">,
<cfqueryparam cfsqltype="cf_sql_varchar" value="#VCFUploadedfile#" null="#NOT VCFfileuploaded#">,
<cfqueryparam value="#form.CategoryID#" cfsqlType="CF_SQL_INTEGER">)
</cfquery>
<cfquery name="qFetchID" datasource="#APPLICATION.dataSource#">
     SELECT id
     FROM Projects
     WHERE mainEmail =<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.mainEmail#">
</cfquery>
<cflocation url="part-manager.cfm?id=#qFetchID.id#" addtoken="no">
</cfif>
I'm sorry it's so much code.. I commented it out a little so you can see what I'm doing... It's just writting to the database improperly on both the update and insert.
Thank you.
Advanced techniques
871
Participant ,
Jun 04, 2011 Jun 04, 2011
You have this (LOOK AT THE BOLD LETTERS) :
</cfif>
instead of
Projects.MYPdf=<cfqueryparam cfsqltype="cf_sql_varchar" value="#PDFUploadedfile#">,
</cfif>
maybe try to use less confusing names like :
PDF_UploadedfileName
AND
PDF_FileUploaded_YN
Documentation
