4 Replies Latest reply: Jun 5, 2011 7:28 AM by rollsnut RSS
    Enable Profile Correction Question
    rollsnut Community Member
      I am on a PC -Windows7 and Lightroom 3.4.1
      Is there a way to have, on startup or opening any catalog, have the Enable Profile Correction box automatically checked?
      I just find it a bit cumbersom to do one then have to sync all before I really get to work on my files.
      Thanks for any solution.
      Brad
        • 1. Re: Enable Profile Correction Question
          Ian Lyons CommunityMVP
          Yes it's possible. However, you'll need to repeat following steps for each camera model you use.
          1. Select file in Library module. The file should be one that Lr has a lens profile for, and without any develop adjustments (i.e an unedited file)
          2. Switch to Develop module
          3. Scroll down to Lens Corrections panel
          4. Check the box labelled Enable Profile Corrections. Make sure the Setup popup says Default.
          5. Go to Develop menu and choose Setup Default Settings
          6. When dialog opens hit the  Update to Current Settings button
          Above tells Lr to automatically apply default lens profile to any file that has an available profile.
          • 2. Re: Enable Profile Correction Question
            Ian:
            Thanks for responding. Quick clarification please, will this also automatically adjust for the lens I use? I do switch lenses depending upon the shoot.
            Brad
            • 3. Re: Enable Profile Correction Question
              assuming the appropriate profile is available, Lr above will apply it automatically.
              • 4. Re: Enable Profile Correction Question
                Ian:
                Thanks - get the gold star!
                Just another question if I may....My main camera is the Canon 5D MkII and the reset works well as I tried it on two new catalogues. I also have another camera the 40D. If I create a new catalog using 40D shots will I have to go to first photo, set camera info and sync all the rest for that catalog or will it find the 40D profile automatically?
                Sorry to bother you but it's great when one finds a "guru" on a question.
                Brad
