1. Re: Hard drive filling up - could there be ppro files that I could delete
Todd_Kopriva Jun 2, 2011 3:39 PM (in response to lisaellensegal)You can clean out the media cache.
2. Re: Hard drive filling up - could there be ppro files that I could delete
lisaellensegal Jun 2, 2011 4:01 PM (in response to Todd_Kopriva)Just to double check, here are Adobe's instructions for manually removing files:
"Cleaning the database and cache with the Clean button does not remove files that are associated with footage items for which the source files are still available. To manually remove conformed files and index files, navigate to the media cache folder and delete the files."
I am fairly certain that these files are the ones causing the bloat in my hard drive. The Media Cache Files folder contains approximately 146gb worth of files. My question is, will removing these files negatively affect any of my ppro projects? My interpretation is that once I delete, Adobe will recreate when I re-open a project. Before I break something, is this correct?
Lisa
3. Re: Hard drive filling up - could there be ppro files that I could delete
joe bloe premiere Jun 2, 2011 4:12 PM (in response to lisaellensegal)Your interpretation is correct.
The only consequence is the time it will take to
re-generate the cache files for your current project.edit:
You can also remove the files in your Adobe Premiere Pro Preview Files folder
to regain more disk space
Delete preview files
4. Re: Hard drive filling up - could there be ppro files that I could delete
Todd_Kopriva Jun 2, 2011 4:34 PM (in response to lisaellensegal)To confirm:
Using the Clean command will just remove cache files associated with assets not that are not currently available---i.e., not on the drive, or on a drove that isn't connected. This cleaning alone can be quite valuable and has no negative result for your current project.
If you want to go a step further, you can manually remove/delete the rest of the contents of the cache. This will cause a regeneration of cache files the next time that you load those assets, and this can take some time.
5. Re: Hard drive filling up - could there be ppro files that I could delete
lisaellensegal Jun 2, 2011 7:12 PM (in response to lisaellensegal)Thanks to everyone! My hard drive is now half empty! I dumped almost 150gb of files! Much better.
Lisa
