Robohelp7- Video does not work in compiled chm
Jun 01, 2011 Jun 01, 2011
I added a swf file in one of my topic. When i preview the topic or generated chm, swf works fine. But when copy the chm on another location and try to the same, a cross appears instead of the video.
831
Jun 02, 2011 Jun 02, 2011
This sounds like the path you are using for the video is not available from the other user's PC. Check that you are not using a relative path and that the path is available elsewhere.
  The RoboColum(n)   @robocolumn   Colum McAndrew
The swf file is on the root of the project. I have not given any relative path to embed this video. Even when i copy the chm on my desktop, i am unable to view the video through the chm.
Have you added the .SWF to your project's baggage files?
yep, I have added that too. But no luck
Hi there
Sorry to chiime in late here. Is the CHM by chance being viewed on a 64 bit system? If so, the link below will be of interest.
Click here to view
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Thanks for the link. It was very informative.
But the video embedded in the chm works fine through robohelp and also when i preview the topic. When i open the same chm directly from the SSL folder, the video doesn't play . Same is the problem with Window Vista, only it works fine with Window XP.
If i am not wrong is this a problem because of ActiveX check in Window Vista or higher.
Jun 03, 2011 Jun 03, 2011
Hello again
Sort of hard to explain. When you decide to open a CHM on a 64 bit machine, it opens using the Windows 64 bit version of the CHM viewer. Because the CHM viewer relies on elements of Microsoft Internet Explorer for display of objects, and because there is no 64 bit version of the Flash Player yet for browsers, it fails.
For some reason, when you preview or launch the CHM directly from RoboHelp (not by double-clicking it) it is launched using the 32 bit version of the CHM viewer and it knows how to present SWFs just fine. That's why you see the difference.
This is totally an issue with the Flash Player add in and has nothing whatsoever to do with ActiveX. Unless, of course, you meant that the Flash Player is an ActiveX object.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
I installed a Flash addin for window 7 64-bit. The video works fine now .
Thanks again.
But one more question? Is there a work around. i mean can the video work without the installation of Flash, if I use Robohelp 9 or something?
Looking forward for your valauable help
Hello again
I'd like to know what add in you added! Unless Adobe has finally made an add-in available for 64 bit systems it would have to be a third party add-in.
Please advise.
You also asked:
Sorry, but the cold hard fact remains here. The video is in SWF format. The operating system always uses the Flash Player to present content in SWF format. I'm unaware of any other player for that format. If you don't wish to involve the Flash Player, you will need to consider converting your SWF to perhaps a movie format such as FLV, MOV, F4V, MPG or other. But if you do this you may face other issues.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
RoboHelp Documentation
Download Adobe RoboHelp
