Hey all,
I am working off the google API put together by Ray Camden to allow interactions with google docs. I am attempting to build a function to upload documents, but I am not quite sure how to put together the HTTP request. I just keep getting rejected no matter what I do. I've tried having the file content as a form field param and in the body of the request, both get rejected.
The docs for uploading are here
http://code.google.com/apis/documents/docs/2.0/developers_guide_protocol.html#UploadingDocs
This is my function as it stands. I keep getting bad request errors (error 400)
<cffunction name="upload" access="public" returnType="any" hint="I upload the document." output="false"> <cfargument name="myFile" type="string" required="false" hint="file to upload."> <cfset var result = ""> <cfset theUrl = "https://docs.google.com/feeds/documents/private/full HTTP/1.1"> <cffile action="read" file="C:\website\xerointeractive\testing\test.txt" variable="theFile"> <cfset fileSize = createObject("java","java.io.File").init("C:\website\xerointeractive\testing\test.txt").length()> <cfhttp url="#theURL#" method="post" result="result" charset="utf-8" > <cfhttpparam type="header" name="Authorization" value="GoogleLogin auth=#getAuth()#"> <cfhttpparam type="header" name="Content-Type" value="text/plain"> <cfhttpparam type="header" name="Slug" value="test file"> <cfhttpparam type="header" name="Content-Length" value="#fileSize#"> <cfhttpparam type="body" name="file" value="#theFile#"> </cfhttp> <cfreturn result> </cffunction>
You can see a what it is doing here
http://xerointeractive.com/testing/docstest.cfm
(may change as I am working on it)
I also built a page to print out the headers and data sent to it on request, and pointed my uploader to it. These are the results I got.
All in all the request looks good to me. I'm not real sure what I'm doing wrong. Any insight would be useful. Thanks!
Woot, I got it. I had to send the gData version number, and change the URL.
Here is the working function.
<cffunction name="upload" access="public" returnType="any" hint="I upload the document." output="false"> <cfargument name="myFile" type="string" required="false" hint="file to upload."> <cfset var result = ""> <cfset theUrl = "https://docs.google.com/feeds/default/private/full"> <cffile action="read" file="C:\website\xerointeractive\testing\test.txt" variable="theFile"> <cfset fileSize = createObject("java","java.io.File").init("C:\website\xerointeractive\testing\test.txt").length()> <cfhttp url="#theURL#" method="post" result="result" charset="utf-8" > <cfhttpparam type="header" name="Authorization" value="GoogleLogin auth=#getAuth()#"> <cfhttpparam type="header" name="Content-Type" value="text/plain"> <cfhttpparam type="header" name="Slug" value="test file"> <cfhttpparam type="header" name="GData-Version" value="3"> <cfhttpparam type="header" name="Content-Length" value="#fileSize#"> <cfhttpparam type="body" value="#theFile#"> </cfhttp> <cfreturn result> </cffunction>
