I have an application which was running fine last night as I was doing debugging and what not but this morning its not running - well it is but its not. See when i click run or debug I get the process Adobe Air Debug Launcher.
When i wait for 5 minutes nothing happens so I click run or launch again and it sais: If the program is already running, close it before attempting to run.
When I kill the Adobe Air Debug Lancher Process it allows me to run the program with the exsact same out put as stated above.
I tried shutting down the application (FB) and it doesnt matter - I still get the errors.
Flash Builder 4.5
Windows 7 64 bit
Can I get some help on this - its really starting to piss me off.
basically I try and luanch an application as an adobe air desktop app and I get the task manager that states the Adobe Air Debugger launcher has started (I am not debugging the app) and then when I click end process after it ends Flash builder throws a pop up stating If the program is already running, close it before attempting to run.
HELP!!!!!!1111
HELP!!!!!
Please see http://forums.adobe.com/message/3720114#3720114
-Anirudh
the suggestion in the above mentioned post helped me with a similiar problem -
I deleted the line
PreloadSWF=C:\Users\<USERNAME>\AppData\Roaming\Mozilla\Firefox\Profiles\9us94hs0.default\extensions\flashfirebug@o-minds.com\chrome\content\flashfirebug\flashfirebug.swf
from the "mm.cfg" file:
and it now works
thanks
