SOLVED
Table rows-autoflow text from one row to the next
Avatar
Level 2
can anyone help me with a formatting issue with tables;
I would like to set up a table with multiple rows and have the text automatically flow in the next row as you type once one is full...any help would be greatly appreciated
1 Accepted Solution
Avatar
Correct answer by
Level 5
hey there,
I just did the 1st row.
At the FULL event, I changed the Language to Javascript and put the following code:
xfa.host.setFocus(xfa.resolveNode("form1.#subform.Table1.Row3[1].Cell1"));
Now it's working. You can do it for the rest.
Tip: when coding, if you hold Ctrl+Shift and click on any field, you get the name of the field instantly.
Diego
Avatar
Level 5
hey buddy,
Let's say that each row is a textfield, right? So when the user reaches the end of the field, automatically jumps to the next row (textfield). Is that correct?
I think you can achieve this by using the FULL event of each row. So when the cursor reaches the end of the field, just put the focus to the next field.
Avatar
Level 2
Thank you!! I'd almost given up on this :)
would you be able to give me instructions on how to do this?
Avatar
Level 5
Yes, take a look on my blog. It's in Portuguese but I think Google can help on that
http://diegosi.wordpress.com
Or you can download a sample file directly: http://diegosi.wordpress.com/?attachment_id=232
hope it helps
Diego
Avatar
Level 2
Thanks Diego, I looked at the example & tried translating your blog but it's too complicated for a novice to work out! I'll cross my fingers & hope that someone can provide instructions in english
Avatar
Level 5
don't worry, the PDF file I posted above is funcional. You can open it in your LC Designer and see how I did
Avatar
Level 2
Yes I did try that but couldnt get it to work in my form, no idea what I was doing
wrong
Avatar
Level 5
Well... if you want to, just post your form here so we can have a look.
Avatar
Level 2
Thanks Diego, below is the form I have taken all my attempts at the script in the tables out that weren't working!
https://acrobat.com/#d=ndP6cfebt6nEOuRQB4cW1g
Avatar
Level 5
I cannot open it, it says doesn't exist or I don't have rights to see it.
Avatar
Level 2
Hi Diego,
I've attached it to the email hope that’s ok
Avatar
Level 5
oops, didn't work, I cannot see it.
Try to upload here in the forum.
Avatar
Correct answer by
Level 5
hey there,
Diego
Avatar
Level 2
Fantastic, thanks so much for your help!!
