1. Re: as3 - load mp4 with flvplayback extract sound
kglad Jun 7, 2011 7:02 AM (in response to oeann)you can play them both simultaneously. is that what you want?
2. Re: as3 - load mp4 with flvplayback extract sound
oeann Jun 7, 2011 1:27 PM (in response to kglad)yes i think that ismore simple than extract sound from my video...
but then i play my background music and my video i dont hear my music.. only the sound of my video and i would like both
excuse me for my english im french...
my code use:
function preview_recording()
{//Change mode
pmode = "p";//Load le vidéo and mp3
var music:Sound = new Sound(new URLRequest("http://localhost/krv/music/" + nid + ".mp3"));
mc_videoPlayer.videoPlayer.source = "rtmp://xxxxxxxxxxxx.rtmphost.com/krv/" + fileName;
mc_videoPlayer.videoPlayer.play();
mc_videoPlayer.videoPlayer.addEventListener(VideoEvent.READY, onFlvPlayback_READY);
music.play();}
if you are any solution for thisi appreciate...
I would like to make this because when i record my microphone with sound in background with fms the sound background is bad
and i think ii play my original music with my video record,this resolve my problem?
thanks a lot
Oeann
3. Re: as3 - load mp4 with flvplayback extract sound
kglad Jun 7, 2011 1:54 PM (in response to oeann)you probably want to use a relative path to your sound file. in any case, test without your video to ensure you're using a correct path/file name:
{//Change mode
mc_videoPlayer.videoPlayer.addEventListener(VideoEvent.READY, onFlvPlayback_READY);*/
music.play();}
do you hear your mp3? if not, you have an incorrect path/file name: use the trace() function to debug:
trace("http://localhost/krv/music/" + nid + ".mp3"); -
4. Re: as3 - load mp4 with flvplayback extract sound
oeann Jun 7, 2011 2:05 PM (in response to kglad)hello,
yes my path is ok.. when i start the video and mp3 at the same time, and stop video i hear my music ad if i dont start video i hear mp3 to.
But when play both, i listen only the video, do you think that the problem is volume from mp3??
because if i play mp3 only, is not high
my method is ok in the code below?
thanks lot to respond me.
oeann
5. Re: as3 - load mp4 with flvplayback extract sound
kglad Jun 7, 2011 2:25 PM (in response to oeann)your code is ok. reduce the volume on your video. do you hear your mp3?
6. Re: as3 - load mp4 with flvplayback extract sound
oeann Jun 7, 2011 3:11 PM (in response to kglad)i hear but the sound is not high than i would like.
if i play the mp3 on vlc for exemple, the sound is more high than in flash
and with the video, and mp3, i feel that i hear only the video because it have the same music in.
i have add thisto mycode but same result
//Load le vidéo
mc_videoPlayer.videoPlayer.source = "rtmp://xxxxxxxxx.rtmphost.com/karaoke/" + fileName;
//music.play();
var trans:SoundTransform = new SoundTransform(1);
music.play(0, 1, trans);to you have any idea to play my mp3 more high?
AND the sound isnot synchro
thanks again
oeann
