I'm using FB4.5 on a PC. Here's what I'm trying to do:
I have a simple Actionscript Mobile project that I have completed debugging with no problems. Now I need to export my release build to get my .apk file for the Android Market.
When I go through all the steps of Export Release Build, FB builds the set, then seems to delete the /bin-release folder containing all the files it just created and I get no .apk file anywhere.
The only reason I know the files are being created in the first place, is that I watched the folder in explorer as soon as it was created. Any thoughts? Is there a better way to do this? I know there are command line tools to do the packaging, but it seems like all I need is right in FB4.5, it just doesn't work quite properly?
Is nobody else packaging for Android on FB4.5? Bump.
After much more testing, I can see now that the Export Release Build always deletes the /bin-release folder when it is complete. IMHO this is a bug, since you have no opportunity to edit the X-app.xml build file before it gets incorporated into the .apk unless you cancel the build process before its complete, edit the app.xml and then restart the Export Release Build process.
bin-release is a temporary folder used prior to packaging. Removal of bin-release is expected behavior (though I understand that this does not play well with you wanting to edit app.xml).
Can you post the contents of your Flash Builder log file here? (workspacedir/.metadata/.log; workspacedir by default is c:\users\xxx\Adobe Flash Builder 4.5)
-Anirudh
!SESSION 2011-05-03 20:41:52.851 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Users\TB\Desktop\Development\~Projects\flash\.metadata\.bak_0.log
Created Time: 2011-05-04 08:53:22.543
!ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.543
!MESSAGE Unhandled event loop exception during blocked modal context.
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Graphic is disposed)
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.disconnectFromWorkspace(IDEWorkbenchAdvisor.java:460)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.postShutdown(IDEWorkbenchAdvisor.java:316)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:2732)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:939)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:856)
at org.eclipse.ui.internal.Workbench$23.run(Workbench.java:1100)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1098)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1070)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:721)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:700)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:816)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:814)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:92)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:308)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1645)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3948)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:342)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1578)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2010)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2405)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:492)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4036)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2410)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3471)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java:109)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: org.eclipse.swt.SWTException: Graphic is disposed
at org.eclipse.swt.SWT.error(SWT.java:3770)
at org.eclipse.swt.graphics.Image.getImageData(Image.java:1199)
at org.eclipse.jface.resource.ImageDataImageDescriptor.<init>(ImageDataImageDescriptor.java:36)
at org.eclipse.jface.resource.ImageDescriptor.createFromImage(ImageDescriptor.java:104)
at com.adobe.flexide.editorcore.ui.FlexImageDatabase.getOverlayImage(FlexImageDatabase.java:251)
at com.adobe.flexide.editorcore.ui.SharedImages.getProblemDecoratedImage(SharedImages.java:169)
at com.adobe.flexide.editorcore.editor.AbstractFlexEditor$6.run(AbstractFlexEditor.java:1454)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
... 73 more
... 73 more
!ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.555
!STACK 0
... 73 more
!ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.556
!STACK 0
... 73 more
!ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.557
!STACK 0
... 73 more
!ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.558
!STACK 0
... 73 more
!ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.559
!STACK 0
... 73 more
!ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.560
!STACK 0
... 73 more
!ENTRY org.eclipse.jface 4 0 2011-05-04 08:53:22.561
!STACK 0
... 73 more
Also note that if this is expected behavior, then why does the bin-release folder NOT get removed when I package a
regular Actionscript project? I've only see this happen with the Actionscript Mobile project for Android/AIR.
> why does the bin-release folder NOT get removed when I package a regular Actionscript project?
If you create an ActionScript AIR project, bin-release does get removed (it did for me, I just tried it).
If you create a web project, then bin-release stays.
In your case, if bin-release did not get cleaned up, *that* is unexpected.
Getting back to your problem, your log file only showed errors when shutting down Eclipse. Nothing to do with Export release. I have two more things for you to try out:
* Create a totally new mobile project, copy the sources over and try an export release build.
* If that also fails, try packaging your mobile project as a "Signed AIR package" and see if that works.
If the above steps don't help, email your project over and I'll take a look.
-Anirudh
Computer Scientist,
Flash Builder Engineering
