Locked
DataService reading but not writing
Jun 07, 2011 Jun 07, 2011
I have set up some basic CRUD services, the reading part works fine but create, update and delete dont' seem to do a bean. I have been using the network monitor to see what is happening and can see my read services woking fine but the others dont do a thing when called.
<fx:Declarations>
<customcategoryservice:CustomcategoryService id="customcategoryService"
              fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)"
              showBusyCursor="true"/>
<s:CallResponder id="createCustom_categoryResult"/>
<s:CallResponder id="getCustom_categoryByAuthorIDResult2" result="getCustom_categoryByAuthorIDResult2_resultHandler(event)"/>
<s:CallResponder id="updateCustom_categoryResult" result="updateCustom_categoryResult_resultHandler(event)"/>
<s:CallResponder id="deleteCustom_categoryResult" result="deleteCustom_categoryResult_resultHandler(event)"/>
</fx:Declarations>
<fx:Script>
protected function cat_dg_creationCompleteHandler(event:FlexEvent):void
    getCustom_categoryByAuthorIDResult2.token = customcategoryService.getCustom_categoryByAuthorID(current_user, image_target);
   protected function getCustom_categoryByAuthorIDResult2_resultHandler(event:ResultEvent):void
    // TODO Auto-generated method stub
    arr_custom_categories = event.result as ArrayCollection;
   protected function update_button_clickHandler(item:Custom_category):void
    updateCustom_categoryResult.token = customcategoryService.updateCustom_category(item);
   protected function delete_button_clickHandler(itemID:int):void
    deleteCustom_categoryResult.token = customcategoryService.deleteCustom_category(itemID);
   protected function createCustom_categoryResult_resultHandler(event:ResultEvent):void
    arr_custom_categories.addItem(event.result);
    custom_category = event.result as Custom_category;
    cat_dg.scrollToIndex(arr_custom_categories.length);
   protected function updateCustom_categoryResult_resultHandler(event:ResultEvent):void
    trace('Updated successfully');
   protected function deleteCustom_categoryResult_resultHandler(event:ResultEvent):void
    arr_custom_categories.removeItemAt(cat_dg.selectedIndex);
</fx:Script>
The services work fine when I use the sevices test operation in flash builder, just nothing when testing on the build.
Pete
PHP
715
Jun 11, 2011 Jun 11, 2011
I'm having exactly the same problem (see http://forums.adobe.com/thread/863061).  Can read, can see read network traffic, cannot write, Do not see any network traffic.
Either there is a real bug here or we both have the same, very wrong, configuration parameter somewhere.
Anyone out there that has seen this and solved it?  Adobe? Zend?
Jun 16, 2011 Jun 16, 2011
Ok, I've got a workaround.
It involves hacking the generated _Super_NameService.as which I realise isn't ideal. I've included relevant section below with all the changes commented out.
* This is a generated class and is not intended for modification.  To customize behavior
* of this service wrapper you may modify the generated sub-class of this class - SubjectService1.as.
package services.subjectservice1
import com.adobe.fiber.core.model_internal;
import com.adobe.fiber.services.wrapper.RemoteObjectServiceWrapper;
//import com.adobe.fiber.valueobjects.IValueObject;
import com.adobe.serializers.utility.TypeUtility;
//import mx.collections.ListCollectionView;
//import mx.data.DataManager;
//import mx.data.IManaged;
//import mx.data.ItemReference;
//import mx.data.ManagedAssociation;
//import mx.data.ManagedOperation;
//import mx.data.ManagedQuery;
//import mx.data.RPCDataManager;
//import mx.data.errors.DataServiceError;
import mx.rpc.AbstractOperation;
import mx.rpc.AsyncToken;
import mx.rpc.remoting.Operation;
import mx.rpc.remoting.RemoteObject;
import valueObjects.Subject;
import mx.collections.ItemResponder;
import com.adobe.fiber.valueobjects.AvailablePropertyIterator;
[ExcludeClass]
internal class _Super_SubjectService1 extends com.adobe.fiber.services.wrapper.RemoteObjectServiceWrapper
//    private var _subjectRPCDataManager : mx.data.RPCDataManager;
//    private var managersArray : Array = new Array();
//    public const DATA_MANAGER_SUBJECT : String = "Subject";
//    public function getDataManager(dataManagerName:String) : mx.data.RPCDataManager
//        switch (dataManagerName)
//             case (DATA_MANAGER_SUBJECT):
//                return _subjectRPCDataManager;
//            default:
//                return null;
//     * Commit all of the pending changes for this DataService, as well as all of the pending changes of all DataServices
//     * sharing the same DataStore.  By default, a DataService shares the same DataStore with other DataServices if they have
//     * managed association properties and share the same set of channels.
//     * @see mx.data.DataManager
//     * @see mx.data.DataStore
//     * @param itemsOrCollections:Array This is an optional parameter which defaults to null when
//     *  you want to commit all pending changes.  If you want to commit a subset of the pending
//     *  changes use this argument to specify a list of managed ListCollectionView instances
//     *  and/or managed items.  ListCollectionView objects are most typically ArrayCollections
//     *  you have provided to your fill method.  The items appropriate for this method are
//     *  any managed version of the item.  These are any items you retrieve from getItem, createItem
//     *  or using the getItemAt method from a managed collection.  Only changes for the
//     *  items defined by any of the values in this array will be committed.
//     * @param cascadeCommit if true, also commit changes made to any associated
//     *  items supplied in this list.
//     *  @return AsyncToken that is returned in <code>call</code> property of
//     *  either the <code>ResultEvent.RESULT</code> or in the
//     *  <code>FaultEvent.FAULT</code>.
//     *  Custom data can be attached to this object and inspected later
//     *  during the event handling phase.  If no changes have been made
//     *  to the relevant items, null is returned instead of an AsyncToken.
//    public function commit(itemsOrCollections:Array=null, cascadeCommit:Boolean=false):mx.rpc.AsyncToken
//        return _subjectRPCDataManager.dataStore.commit(itemsOrCollections, cascadeCommit);
//     * Reverts all pending (uncommitted) changes for this DataService, as well as all of the pending changes of all DataServics
//     * In case you specify a value for itemsOrCollections:Array parameter, only pending (uncommitted) changes for the specified
//     * managed items or collections will be reverted.
//     * when you want to revert all pending (uncommitted) changes for all DataServices
//     * managed by this DataStore. If you want to revert a subset of the pending changes use
//     * this argument to specify a array of managed items or collections
//     * @return true if any changes were reverted.
//     * @throws DataServiceError if the passed in array contains non-managed items or collections
//    public function revertChanges(itemsOrCollections:Array=null):Boolean
//        if (itemsOrCollections == null)
//            // Revert all changes
//            return _subjectRPCDataManager.dataStore.revertChanges();
//        else
//            // Revert passed in items
//            var anyChangeItemReverted:Boolean = false;
//            // Iterate over array and revert managed item or collection as the case may be
//            for each (var changeItem:Object in itemsOrCollections)
//                if (changeItem is com.adobe.fiber.valueobjects.IValueObject)
//                    var dataMgr:mx.data.DataManager = getDataManager(changeItem._model.getEntityName());
//                    anyChangeItemReverted ||= dataMgr.revertChanges(mx.data.IManaged(changeItem))
//                else if (changeItem is mx.collections.ListCollectionView)
//                    anyChangeItemReverted ||= _subjectRPCDataManager.dataStore.revertChangesForCollection(mx.collections.ListCollectionView(changeItem));
//                else
//                    throw new mx.data.errors.DataServiceError("revertChanges called on array that contains non-managed items or collections");
//            return anyChangeItemReverted;
    // Constructor
    public function _Super_SubjectService1()
        // initialize service control
        _serviceControl = new mx.rpc.remoting.RemoteObject();
        // initialize RemoteClass alias for all entities returned by functions of this service
        valueObjects.Subject._initRemoteClassAlias();
        var operations:Object = new Object();
        var operation:mx.rpc.remoting.Operation;
        operation = new mx.rpc.remoting.Operation(null, "getAllSubject");
         operation.resultElementType = valueObjects.Subject;
        operations["getAllSubject"] = operation;
        operation = new mx.rpc.remoting.Operation(null, "getSubjectByID");
         operation.resultType = valueObjects.Subject;
        operations["getSubjectByID"] = operation;
        operation = new mx.rpc.remoting.Operation(null, "createSubject");
         operation.resultType = int;
        operations["createSubject"] = operation;
        operation = new mx.rpc.remoting.Operation(null, "updateSubject");
        operations["updateSubject"] = operation;
        operation = new mx.rpc.remoting.Operation(null, "deleteSubject");
        operations["deleteSubject"] = operation;
        operation = new mx.rpc.remoting.Operation(null, "count");
        operations["count"] = operation;
        operation = new mx.rpc.remoting.Operation(null, "getSubject_paged");
        operations["getSubject_paged"] = operation;
        _serviceControl.operations = operations;
        _serviceControl.convertResultHandler = com.adobe.serializers.utility.TypeUtility.convertResultHandler;
        _serviceControl.source = "SubjectService1";
        _serviceControl.endpoint = "gateway.php";
//        var managedAssociation : mx.data.ManagedAssociation;
//        var managedAssocsArray : Array;
//        // initialize Subject data manager
//        _subjectRPCDataManager = new mx.data.RPCDataManager();
//        managersArray.push(_subjectRPCDataManager);
//        managedAssocsArray = new Array();
//        _subjectRPCDataManager.destination = "subjectRPCDataManager";
//        _subjectRPCDataManager.service = _serviceControl;
//        _subjectRPCDataManager.identities =  "subject_id";
//        _subjectRPCDataManager.itemClass = valueObjects.Subject;
//        var dmOperation : mx.data.ManagedOperation;
//        var dmQuery : mx.data.ManagedQuery;
//        dmQuery = new mx.data.ManagedQuery("getAllSubject");
//        dmQuery.propertySpecifier = "subject_id,subject_name,organisation_id,active_for_raptor,postcard_subject_name,description_text,master_subject";
//        dmQuery.parameters = "";
//        _subjectRPCDataManager.addManagedOperation(dmQuery);
//        dmOperation = new mx.data.ManagedOperation("createSubject", "create");
//        dmOperation.parameters = "item";
//        _subjectRPCDataManager.addManagedOperation(dmOperation);
//        dmOperation = new mx.data.ManagedOperation("deleteSubject", "delete");
//        dmOperation.parameters = "id";
//        dmOperation = new mx.data.ManagedOperation("updateSubject", "update");
//        dmOperation = new mx.data.ManagedOperation("getSubjectByID", "get");
//        dmOperation.parameters = "subject_id";
//        dmQuery = new mx.data.ManagedQuery("getSubject_paged");
//        dmQuery.countOperation = "count";
//        dmQuery.pagingEnabled = true;
//        dmQuery.positionalPagingParameters = true;
//        dmQuery.parameters = "startIndex,numItems";
//        _serviceControl.managers = managersArray;
         preInitializeService();
         model_internal::initialize();
    //init initialization routine here, child class to override
    protected function preInitializeService():void
        destination = "SubjectService1";
      * This method is a generated wrapper used to call the 'getAllSubject' operation. It returns an mx.rpc.AsyncToken whose
      * result property will be populated with the result of the operation when the server response is received.
      * To use this result from MXML code, define a CallResponder component and assign its token property to this method's return value.
      * You can then bind to CallResponder.lastResult or listen for the CallResponder.result or fault events.
      * @see mx.rpc.AsyncToken
      * @see mx.rpc.CallResponder
      * @return an mx.rpc.AsyncToken whose result property will be populated with the result of the operation when the server response is received.
    public function getAllSubject() : mx.rpc.AsyncToken
        var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("getAllSubject");
  var _internal_token:mx.rpc.AsyncToken = _internal_operation.send() ;
        return _internal_token;
      * This method is a generated wrapper used to call the 'getSubjectByID' operation. It returns an mx.data.ItemReference whose
      * @see mx.data.ItemReference
      * @return an mx.data.ItemReference whose result property will be populated with the result of the operation when the server response is received.
    public function getSubjectByID(itemID:int) : mx.rpc.AsyncToken // mx.data.ItemReference
        var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("getSubjectByID");
  var _internal_token:mx.rpc.AsyncToken /*mx.data.ItemReference*/ = _internal_operation.send(itemID);//as mx.data.ItemReference;
Hope this helps.
Message was edited by: pjlumby Warning!! If you add new services the changes are laible to be lost so if you've got it working, back it up.
