I have a pdf with multiple signature fields. When somebody signs it in 9.x everything is fine, but when somebody signs it in a version earlier than 9.0 it does not work. The signature fields do not even show up. Somebody signed the pdf in 8.x and sent it back to me. I opened in 9.x, and I could not see the signature fields. Is there a compability issue between these versions. The pdf contains javascript and is a dynamic pdf if that matters. Thanks in advance.
Total Likes
I've also enabled reader rights, and the pdf was developed in livecycle.
Total Likes
I've also got all the lock fields after signing information taken care of.
Total Likes
What version of Designer was uset to create the form, and what was the Reader\Acrobat "Target Version" (File > Form Properties) (see attached screen shot) set to?
Steve
I have it set to "Acrobat and Adobe Reader 8.1 or later." Should I set it back to 8.0 or 7.0?
Total Likes
You could definately try this as a test. I don't know for sure if this is the cause but it could be related.
Steve
Total Likes
It works on my computer when I dropped the target version to 7.x. However, I don't know if it will work on a true 8.0 version of Acrobat. I have sent it to a person who has Version 8.x, and I will let you know how it works. When you change that target version does that mean it will be compatible with the version or later you set it to?
Total Likes
Unfortunately, it appears that this solution did not work. I guess I will have to keep testing it.
Total Likes
I would suggest you contact Adobe Technical Support as they may know if whatyou are experiencing is a known issue.
Regards
Steve
How might I get into Contact with them??
Total Likes
Likes
Likes
