Hi Paul
I'll be happy to add what I know and hopefully others will
also chime in.
1. Is it possible for me to generate my project as Flash Help ?
What are the assets and flaws of WebHelp vs. Flash Help?
This is really a two part question. So I'll try to answer in
two parts.
Part 1.
Absolutely! Really, this is one of the beautiful features of
RoboHelp HTML and the Single Source Layouts. You can typically
generate any output at any time.
Part 2.
FlashHelp Pros:
* Flash Player is pretty much universal, giving your projects
a consistent interface regardless of the operating system used
* More modern interface
FlashHelp Cons:
* Currently not able to create merged output like WebHelp can
* Can't easily edit skins
* Fewer skins available
* If deploying by running on the local PC, if Flash Player 8
is installed, you must tweak security settings to enable
WebHelp Pros:
* You can merge WebHelp systems
* You can easily edit skins
* Content is easily viewable on almost any browser used
WebHelp Cons:
* If deploying by running on the local PC, if Windows XP SP2
* Interface may look and behave slightly different when
viewed on different platforms.
3. Is there a way to automatically generate the release version
of the online help without having to go through the RH interface
(i.e: through a command line ran on the VSS / Perforce server)?
Sorry, no way to easily automate this. However, some folks
claim to be able to achieve a certain amount of automation by using
an additional application such as Macro Express
http://www.Macros.com
Hopefully some of this was helpful. Also hope others offer
other insights into the WebHelp/FlashHelp comparison that didn't
immediately come to mind. (I'm still working on that first
cuppa...)
Cheers... Rick
