1 2 3 4 Previous Next 223 Replies Latest reply on Oct 21, 2012 1:00 PM by Chris Cox Go to original post
      • 40. Re: Your disk copy of image was changed since last opened or saved
        - JM - Level 3
        I use FAP.
        My assumption has always been that this was due to the temporary naming via Photoshop of "Vector Smart Objectx.ai". I believe that the file once it is placed into PS is then reopened for the first time in AI and possibly the reuse of the naming is at issue?
        FAP auto-activation works with AI/PS quite well and I don't see this notice unless it comes from an SO, and then it's not consistent and/or repeatable.
        • 41. Re: Your disk copy of image was changed since last opened or saved
          Level 7
          The modification notice in Illustrator is a miscommunication between Illustrator and Photoshop teams.  Photoshop needs to trim off extra pages, but AI expects the whole file intact.  We're still working on it.
          • 42. Re: Your disk copy of image was changed since last opened or saved
            - JM - Level 3
            thanks Chris
            what's the appropriate response? discard or keep?
            and what am I discarding or keeping?
            • 43. Re: Your disk copy of image was changed since last opened or saved
              Level 7
              We're still not entirely sure what the Illustrator team means by that message.
              Photoshop has removed pages and unused parts of the file, but we can't trim or modify the Illustrator custom information and it detects that the file has been modified.
              What part are they keeping or discarding?  We don't know.
              • 44. Re: Your disk copy of image was changed since last opened or saved
                - JM - Level 3
                I've always gone with the default for the dialog which is to discard the changes.... sounds counterintuitive but I haven't noticed any problems or lost data.
                no problem, it's easy to dismiss the dialog. Have a great weekend.
                • 45. Re: Your disk copy of image was changed since last opened or saved
                  Pink Tree Studio Level 1
                  Have "sort of" been following this thread and I just saw something interesting on a Peach Pit TV video.
                  Check it out  at 3:05:
                  http://www.youtube.com/watch?v=7Rv4f554C6s&feature=player_embedded#at=10
                  I looks like Matt gets the same dialog box that we do and it LOOKS like he ignores it. What do you all think?
                  Elaine
                  • 46. Re: Your disk copy of image was changed since last opened or saved
                    caligula1 Level 1
                    From that video, it looks like Matt Kloskowski has the same issue as us. I think the issue is more common than Adobe believes.
                    • 47. Re: Your disk copy of image was changed since last opened or saved
                      Exactly! I was so surprised when I saw that, especially when he made no comment about it and just seemed to ignore it, as I do :~) It hadn't happened for a while, but it did last night!
                      • 48. Re: Your disk copy of image was changed since last opened or saved
                        Level 5
                        What does it matter if it is more common?
                        That video shows the alert displayed out of context. We cannot tell if Matt already had the file open in Photoshop. We cannot tell if the screencast was unedited.
                        • 49. Re: Your disk copy of image was changed since last opened or saved
                          Oy vey. I guess it's just me being clueless again :~) But why do you think it's out of context?
                          • 50. Re: Your disk copy of image was changed since last opened or saved
                            caligula1 Level 1
                            If the issue is more common than Adobe currently believes, than maybe Adobe will devote some resources to investigating it. I wouldn't care  about getting an annoying message about the disk copy being changed if I knew that the changes were just the wrong time date stamp, but I would like to know what the actual changes are since none are visible to my eye. Having lived with this issue for over two months I feel like there is some poltergeist that lives in my computer making unknown changes to my files. Neither Apple or Adobe seems to know what is modifying my files.
                            If the file was already open in photoshop and then opened and modified in camera raw, it shouldn't trigger a message about the disk copy being changed, right?
                            • 51. Re: Your disk copy of image was changed since last opened or saved
                              Level 5
                              There does not seem to be an unwillingness from Adobe to look at the problem. Adobe cannot investigate something it cannot see. Those in this discussion that see this problem have been unable to report what process is tweaking their file. Unless you want to send your system to Adobe, there is not much that they can do.
                              This topic is not new. There have been many others like it that are unfortunately hidden with this forum's malfunctioning search. Try Google for much more explanation on the topic.
                              • 52. Re: Your disk copy of image was changed since last opened or saved
                                - JM - Level 3
                                I agree, but there are bugs that Adobe can reproduce that have been overlooked for the past couple releases, so it's reasonable to think that they do need to allocate resources to bigger bugs, new features and new releases. This would be true of any business. It would be great to think that any bug that can be reproduced is going to be fixed but that hasn't been the case.
                                Fixing bugs doesn't generate as much money as maintaining a constant release schedule. But generating new dollars keeps the guys/gals around to fix the old bugs.
                                • 53. Re: Your disk copy of image was changed since last opened or saved
                                  caligula1 Level 1
                                  I have not accused Adobe of being unwilling to look at the problem. I would be willing to have Adobe look at my system if they are interested.
                                  • 54. Re: Your disk copy of image was changed since last opened or saved
                                    Level 7
                                    We have investigated, and found that the file was modified by applications outside of Photoshop just like the message says.
                                    When we test it on our systems without those other applications, we never get the warning because nothing else is modifying the files.
                                    That depends on your settings in ACR. Yes, it could change the file on disk with the right settings.
                                    • 55. Re: Your disk copy of image was changed since last opened or saved
                                      MuggeGHQ Level 1
                                      Last night i did a full install from scratch because i was fet op with this error and now its back
                                      Fresh 10.6.7 install and only Adobe Suite CS4 and Suite CS5.5 and now its back..
                                      So nothing in my system other that Apples and Adobes in there now. Not even a plugin ?
                                      • 56. Re: Your disk copy of image was changed since last opened or saved
                                        - JM - Level 3
                                        Hi Mugge
                                        > It only happen when working over network. Not on the local disk.
                                        If you cleaned off your working drive and have the same problems, what are the specs for this network drive that you are saving to?
                                        On a clean install why are you reinstalling CS4?
                                        Do you have the problem if Bridge is not running?
                                        • 57. Re: Your disk copy of image was changed since last opened or saved
                                          MuggeGHQ Level 1
                                          Hi there.
                                          It is not a network drive. We have 3 computers (Mac Pro) connected in a network and the internal drives in one of the computers are the storage drive.
                                          Lets call them. Computer 1,2 and 3 and computer 1 is the main computer with all the files on a internal drive (2TB SATA II HD)
                                          So we work on the files from all 3 computers and when i sometimes work on computer 2 or 3 with a images. I get this error message when saveing.
                                          Ofcause no one else is touching the file i work on (Then that would be why it comes) so thats not the reason.
                                          Then some days ago i bought a external Firewire 800 Raid 0,1,5 case and moved the storage drives in to that case for safety (Raid mirror now) and
                                          it works great but we still have the same error message. So both on the old internal system and also now with external drives.
                                          I just installed both CS4 and CS5 so i could keep on working if something happen or CS5 woulden work right.
                                          Actually i never tried working with out Bridge running also. Photoshop and Bridge is always running together when i work because it is so much easier
                                          to located the image i need in Bridge instead of in photoshop (Open file) and before we upgraded the computers to 10.6.x from 10.5.x i never saw this
                                          error. It all started after 10.6 Snow Leo. I dont think its because of Snow Leo because others also have the problem on 10.5.x Leopard.
                                          Specs.
                                          3 Mac Pro 8-Core 2008 with internal drives. 16GB of ram. Mac OS X 10.6.7 in 2 and 10.5.8 in the third.
                                          All 3 computers are attached to a 10/100/1000 switch so everyone have access to the files/images.
                                          Before last week the files was stored on the internal drive on Computer 1 but now the files are stored on a external firewire 800 case (Raid Mirror)
                                          No matter what i do i get this message ones in a wile. The funny thing is. It is not every day. Yesterday i was working all day and it never came.
                                          Today it did ??? Really weird.
                                          • 58. Re: Your disk copy of image was changed since last opened or saved
                                            - JM - Level 3
                                            >then some days ago i bought a external Firewire 800 Raid 0,1,5 case and moved the storage drives in to that case for safety
                                            this new RAID is directly connected to your computer via Firewire, or attached to the networked computer?
                                            you may have already mentioned this... does the save error occur on the other computers too?
                                            thanks
                                            • 59. Re: Your disk copy of image was changed since last opened or saved
                                              caligula1 Level 1
                                              Apple engineering had me track a PSB file in terminal that was open in photoshop. During the time period that the file was being tracked, I did not open the file in any other applications. When I received the message about the disk copy being modified, I sent Apple the Terminal Saved Output as well as Capture. Engineering has come back to me and told me that the only process to set attributes on the file being tracked was setattrlist and that process occurred about 10 times during the seven hour time period that the file was open.
                                              Attached are selections of the logs from around 15:34:36 when setattrlist first starts appearing. Also attached is a selection from the log from around the time that I received the message that the disk copy was changed.1.jpg
                                                      The file was saved periodically about every half hour or so while it was open.  I did not receive a message about the disk copy being modified until many  hours after the settattr first starts showing up on the list.
                                              I have also noticed that dropbox shows up about 16 times on the log although I did not put this file or any other file in dropbox while the log was running.
                                              Does it mean anything that dropbox shows up on the log? I started  receiving the message about the disk copy being changed before I installed dropbox on my system.
                                              Thanks for your help, Chris.
                                              • 60. Re: Your disk copy of image was changed since last opened or saved
                                                Level 7
                                                The setattrlist calls only happen when Photoshop is saving the file. Setattrlist is not a process, but a function in the OS that sets files attributes.
                                                That's how the file system sets things like the file name, file type, etc.
                                                You were using fs_usage, and the format of the report is:
                                                time_stamp     file_operation     file path     time_taken     Flags     Process_Name
                                                It sounds like your apple technician confused the file operation with the process name.
                                                Yes, the Dropbox calls are disturbing -- it is getting info on files that are nowhere near it's directories.
                                                dbfseventsd also appears to be a Dropbox related service, and also getting info on files nowhere near the Dropbox directory.  (are you sure you didn't set Dropbox to use the whole disk by mistake?)
                                                The MacOS spotlight (mds) code is also getting info on the temporary file.
                                                Dropbox and spotlight should be ignoring all files in the /tmp and /TemporaryItems directories.  Those are bugs, but probably not causing this issue.
                                                And Bridge opens the file to create a thumbnail after it has been closed by Photoshop, but does not write to the file.
                                                Unfortunately, what you show here is just the time around the Photoshop save (between open and rename), and not much of what happens AFTER Photoshop saves the file when changes are being made.  In the second log, we can see backupd open the file, but we don't see everything it did with the file.
                                                Also, it would be much easier to read if we had the text version instead of downsampled screen captures.
                                                • 61. Re: Your disk copy of image was changed since last opened or saved
                                                  caligula1 Level 1
                                                  Thanks for your help, Chris. I  tried attaching the entire log in both docx. and txt. formats and both times  got a message about the content type not being allowed and the attachment exceeding 2.0 MG so I have done a copy and paste of the entire document below.
                                                  Password:
                                                  14:59:40  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  14:59:40  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  15:01:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000041   Adobe Photos
                                                  15:01:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000035   Adobe Photos
                                                  15:01:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  15:01:09  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000022   Adobe Photos
                                                  15:34:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000037   Adobe Photos
                                                  15:34:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  15:34:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  15:34:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  15:34:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  15:34:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  15:34:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  15:34:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  15:34:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  15:34:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  15:34:11  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000012   Adobe Photos
                                                  15:34:25  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907   14.345821 W Adobe Photos
                                                  15:34:25  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000026   Adobe Photos
                                                  15:34:25  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000010   Adobe Photos
                                                  15:34:25  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000111 W Adobe Photos
                                                  15:34:25  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000008   Adobe Photos
                                                  15:34:25  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000012   Adobe Photos
                                                  15:34:25  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000007   Adobe Photos
                                                  15:34:25  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000045   Adobe Photos
                                                  15:34:25  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.008609 W mds
                                                  15:34:25  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.008352 W Dropbox
                                                  15:34:25  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000013   Adobe Photos
                                                  15:34:25  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000011   Adobe Photos
                                                  15:34:25  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000028   Adobe Photos
                                                  15:34:25  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000006   Adobe Photos
                                                  15:34:25  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000022   Adobe Photos
                                                  15:41:36  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000030   Adobe Photos
                                                  15:41:36  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  15:41:36  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000009   Adobe Photos
                                                  15:41:36  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000009   Adobe Photos
                                                  15:41:36  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  15:41:36  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000015   mds
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000035   Adobe Photos
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  15:41:36  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000017   Adobe Photos
                                                  15:41:36  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000021   dbfseventsd
                                                  15:41:36  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.000064   Dropbox
                                                  15:41:36  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.005649 W Adobe Photos
                                                  15:41:36  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603129907    0.030882 W Adobe Photos
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000038   Adobe Photos
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  15:41:36  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  15:41:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Bridge
                                                  15:41:39  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000020   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000020   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Bridge
                                                  15:41:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000030   Adobe Bridge
                                                  15:41:39  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000024   Adobe Bridge
                                                  15:51:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000036   Adobe Photos
                                                  15:51:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  15:51:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  15:51:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  15:51:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  15:51:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  15:51:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000040   Adobe Photos
                                                  15:51:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  15:51:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  15:52:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  15:53:28  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  15:53:28  getattrlist       c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000100   backupd
                                                  15:53:28  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   backupd
                                                  15:53:28  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   backupd
                                                  15:53:28  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   backupd
                                                  15:53:28  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000057   backupd
                                                  15:53:28  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   backupd
                                                  15:53:28  open_extended     -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000108   backupd
                                                  15:53:28  getattrlist       -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000046   backupd
                                                  15:55:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000042   Adobe Photos
                                                  15:55:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  15:55:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  15:55:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  15:55:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  15:55:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  15:55:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  15:55:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  15:55:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000013   Adobe Photos
                                                  15:55:55  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.047860 W Adobe Photos
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000015   Adobe Photos
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000007   Adobe Photos
                                                  15:55:55  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000032   Adobe Photos
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000008   Adobe Photos
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000006   Adobe Photos
                                                  15:55:55  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000009   Adobe Photos
                                                  15:55:55  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000030   Adobe Photos
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000011   Adobe Photos
                                                  15:55:55  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000010   Adobe Photos
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000009   Adobe Photos
                                                  15:55:55  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000013   Adobe Photos
                                                  15:55:55  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000046   mds
                                                  15:55:55  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000014   Dropbox
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000033   Adobe Photos
                                                  15:55:55  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000046 W Adobe Photos
                                                  15:55:55  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000042   Adobe Photos
                                                  15:59:07  setattrlist       -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.111422 W backupd
                                                  15:59:07  stat              -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.101267 W dbfseventsd
                                                  15:59:08  setattrlist       -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.574887 W backupd
                                                  15:59:08  open              -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000060   backupd
                                                  15:59:08  stat64            -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000053   mds
                                                  15:59:08  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   mds
                                                  15:59:08  lstat64           /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   mdworker
                                                  15:59:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   mdworker
                                                  15:59:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000016   mdworker
                                                  15:59:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   mdworker
                                                  15:59:08  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000016   mdworker
                                                  15:59:08  getattrlist       c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.095850 W backupd
                                                  15:59:09  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   mdworker
                                                  15:59:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000016   mdworker
                                                  15:59:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   mdworker
                                                  15:59:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000020   mdworker
                                                  15:59:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb/.DS_Store         0.000008   mdworker
                                                  15:59:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   mdworker
                                                  15:59:09  stat64            -4779-9A78-1228D3268237/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000031   mds
                                                  15:59:21  getattrlist       c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000081   backupd
                                                  15:59:21  open              c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000041   backupd
                                                  15:59:21  open              c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000080   mds
                                                  15:59:21  stat64            c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000026   mds
                                                  15:59:25  stat64            c Pro/2011-06-04-145544/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000053   mds
                                                  16:00:15  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000030   backupd
                                                  16:00:15  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000011   backupd
                                                  16:00:48  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000010   backupd
                                                  16:00:48  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000006   backupd
                                                  16:00:48  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000006   backupd
                                                  16:00:48  getxattr          HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000004   backupd
                                                  16:00:48  getxattr          HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.420264 W backupd
                                                  16:00:48  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000012   backupd
                                                  16:00:49  open_extended     HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000087   backupd
                                                  16:00:49  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000036   backupd
                                                  16:03:20  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000062   backupd
                                                  16:03:20  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.050056 W backupd
                                                  16:03:20  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000042   backupd
                                                  16:03:20  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000043   mds
                                                  16:03:20  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000010   mds
                                                  16:03:20  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000009   backupd
                                                  16:04:11  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000043   Adobe Photos
                                                  16:04:11  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000015   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  16:04:11  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000008   Adobe Photos
                                                  16:04:11  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000009   Adobe Photos
                                                  16:04:11  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:04:11  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000016   Adobe Photos
                                                  16:04:11  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000028   mds
                                                  16:04:11  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000010   dbfseventsd
                                                  16:04:11  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000020   Dropbox
                                                  16:04:11  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.016557 W Adobe Photos
                                                  16:04:11  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.064186 W Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000049   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  16:04:11  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000016   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000024   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  16:04:11  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Bridge
                                                  16:04:12  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000019   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Bridge
                                                  16:04:12  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000016   Adobe Bridge
                                                  16:04:12  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000020   Adobe Bridge
                                                  16:09:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000035   Adobe Photos
                                                  16:09:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:09:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:09:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  16:09:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  16:10:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000046   Adobe Photos
                                                  16:10:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:10:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:23:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000039   Adobe Photos
                                                  16:23:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:23:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  16:23:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  16:23:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:23:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  16:23:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  16:23:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:23:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:23:32  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000012   Adobe Photos
                                                  16:23:32  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.019134 W Adobe Photos
                                                  16:23:32  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000010   Adobe Photos
                                                  16:23:32  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000007   Adobe Photos
                                                  16:23:46  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940   14.357960 W Adobe Photos
                                                  16:23:46  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000021   Adobe Photos
                                                  16:23:46  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000009   Adobe Photos
                                                  16:23:46  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000017   Adobe Photos
                                                  16:23:46  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000008   Adobe Photos
                                                  16:23:46  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000010   Adobe Photos
                                                  16:23:46  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000056   Adobe Photos
                                                  16:23:46  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.001349 W Dropbox
                                                  16:23:46  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.001606 W mds
                                                  16:23:46  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000020   Adobe Photos
                                                  16:23:46  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000016   Adobe Photos
                                                  16:23:47  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000032   Adobe Photos
                                                  16:23:47  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000006   Adobe Photos
                                                  16:23:47  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000023   Adobe Photos
                                                  16:24:21  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.016612 W dbfseventsd
                                                  16:24:21  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.016530 W mds
                                                  16:24:21  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000038   Adobe Photos
                                                  16:24:21  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000018   Adobe Photos
                                                  16:24:21  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000010   Adobe Photos
                                                  16:24:21  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.000009   Adobe Photos
                                                  16:24:21  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.017196 W Dropbox
                                                  16:24:21  unlink            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603263940    0.017284   Adobe Photos
                                                  16:24:21  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000030   Adobe Photos
                                                  16:24:21  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:24:21  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:27:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:27:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  16:27:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:32:52  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:32:52  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:32:52  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:32:52  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  16:32:52  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  16:32:52  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Bridge
                                                  fs_usage: buffer overrun, events generated too quickly: 479232
                                                  fs_usage: buffer overrun, events generated too quickly: 472479
                                                  16:42:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000037   Adobe Photos
                                                  16:42:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:42:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  16:42:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  16:42:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  16:42:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:42:17  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  16:42:17  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  16:42:17  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:42:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000016   Adobe Photos
                                                  16:42:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.026836 W Adobe Photos
                                                  16:42:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000034   Adobe Photos
                                                  16:42:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000007   Adobe Photos
                                                  16:42:17  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.006057 W Adobe Photos
                                                  16:42:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000021   Adobe Photos
                                                  16:42:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000006   Adobe Photos
                                                  16:42:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000011   Adobe Photos
                                                  16:42:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000040   Adobe Photos
                                                  16:42:17  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.010571 W mds
                                                  16:42:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000017   Adobe Photos
                                                  16:42:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000017   Adobe Photos
                                                  16:42:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000010   Adobe Photos
                                                  16:42:17  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000017   Dropbox
                                                  16:42:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000022   Adobe Photos
                                                  16:42:17  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000021   Adobe Photos
                                                  16:47:06  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000022   Adobe Photos
                                                  16:47:06  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  16:47:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  16:47:06  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000008   Adobe Photos
                                                  16:47:06  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000008   Adobe Photos
                                                  16:47:06  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:47:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  16:47:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:47:06  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000015   Adobe Photos
                                                  16:47:06  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000021   dbfseventsd
                                                  16:47:06  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000867 W Adobe Photos
                                                  16:47:06  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000237 W mds
                                                  16:47:06  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.000151 W Dropbox
                                                  16:47:07  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603396137    0.127046 W Adobe Photos
                                                  16:47:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000050   Adobe Photos
                                                  16:47:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000017   Adobe Photos
                                                  16:47:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  16:47:07  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000019   Adobe Photos
                                                  16:47:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:47:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:47:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  16:47:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  16:47:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  16:47:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Bridge
                                                  16:47:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Bridge
                                                  16:47:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  16:47:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  16:47:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Bridge
                                                  16:47:08  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000018   Adobe Bridge
                                                  16:47:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000024   Adobe Bridge
                                                  16:47:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000039   Adobe Bridge
                                                  16:47:08  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000033   Adobe Bridge
                                                  16:50:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000027   Adobe Photos
                                                  16:50:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:50:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  16:50:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:50:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000034   Adobe Photos
                                                  16:50:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:50:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:50:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  16:50:13  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  16:50:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  16:50:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:50:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:50:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:50:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  16:50:39  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000012   Adobe Photos
                                                  16:50:39  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000219   Adobe Photos
                                                  16:50:39  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000008   Adobe Photos
                                                  16:50:39  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000006   Adobe Photos
                                                  16:50:39  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000027   Adobe Photos
                                                  16:50:39  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000007   Adobe Photos
                                                  16:50:39  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000008   Adobe Photos
                                                  16:50:39  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000039   Adobe Photos
                                                  16:50:39  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.005308 W mds
                                                  16:50:39  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.004957 W Dropbox
                                                  16:50:39  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000011   Adobe Photos
                                                  16:50:39  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000011   Adobe Photos
                                                  16:50:39  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000012   Adobe Photos
                                                  16:50:39  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000033   Adobe Photos
                                                  16:50:39  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000009   Adobe Photos
                                                  16:50:39  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000025   Adobe Photos
                                                  16:52:22  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000012   backupd
                                                  16:52:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  16:54:45  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000011   backupd
                                                  16:54:45  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000047   backupd
                                                  16:54:45  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000006   backupd
                                                  16:54:45  getxattr          HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000005   backupd
                                                  16:54:45  getxattr          HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000003   backupd
                                                  16:54:45  getxattr          HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000004   backupd
                                                  16:54:45  getxattr          HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000109   backupd
                                                  16:54:45  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000006   backupd
                                                  16:54:46  open_extended     HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000077   backupd
                                                  16:54:46  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000034   backupd
                                                  16:55:23  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000040   Adobe Photos
                                                  16:55:23  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Photos
                                                  16:55:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  16:55:23  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000007   Adobe Photos
                                                  16:55:23  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000007   Adobe Photos
                                                  16:55:23  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:55:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  16:55:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  16:55:23  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000015   Adobe Photos
                                                  16:55:23  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000018   mds
                                                  16:55:23  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000020   dbfseventsd
                                                  16:55:23  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000016   Dropbox
                                                  16:55:23  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.005314 W Adobe Photos
                                                  16:55:23  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.026141 W Adobe Photos
                                                  16:55:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000063   Adobe Photos
                                                  16:55:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   Adobe Photos
                                                  16:55:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  16:55:23  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000033   Adobe Photos
                                                  16:55:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  16:55:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Bridge
                                                  16:55:24  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000020   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000050   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Bridge
                                                  16:55:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000036   Adobe Bridge
                                                  16:55:24  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000024   Adobe Bridge
                                                  16:55:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   Adobe Photos
                                                  16:55:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  16:55:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000011   Adobe Photos
                                                  16:55:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000186   Adobe Photos
                                                  16:55:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000008   Adobe Photos
                                                  16:55:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000007   Adobe Photos
                                                  16:55:26  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000032   Adobe Photos
                                                  16:55:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000006   Adobe Photos
                                                  16:55:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000007   Adobe Photos
                                                  16:55:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000034   Adobe Photos
                                                  16:55:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000009   Adobe Photos
                                                  16:55:26  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000042   mds
                                                  16:55:26  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000031   Dropbox
                                                  16:55:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000022   Adobe Photos
                                                  16:55:26  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000021   Adobe Photos
                                                  16:58:43  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.531621 W backupd
                                                  16:58:43  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.075249 W backupd
                                                  16:58:45  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000073   backupd
                                                  16:58:47  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000053   mds
                                                  16:58:47  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.243346 W mds
                                                  16:58:47  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000013   backupd
                                                  16:58:57  getattrlist       c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000070   backupd
                                                  16:58:57  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   backupd
                                                  16:58:57  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   backupd
                                                  16:58:57  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000003   backupd
                                                  16:58:57  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000052   backupd
                                                  16:58:57  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   backupd
                                                  16:58:57  open_extended     -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000089   backupd
                                                  16:58:57  getattrlist       -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000035   backupd
                                                  17:00:07  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000017   mds
                                                  17:00:07  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000038   Adobe Photos
                                                  17:00:08  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000019   dbfseventsd
                                                  17:00:08  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000012   Dropbox
                                                  17:00:08  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000015   Adobe Photos
                                                  17:00:08  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000008   Adobe Photos
                                                  17:00:08  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000010   Adobe Photos
                                                  17:00:08  unlink            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.082753 W Adobe Photos
                                                  17:00:08  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603527998    0.000022   Adobe Photos
                                                  17:00:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   Adobe Photos
                                                  17:00:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  17:02:47  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    3.010227 W backupd
                                                  17:02:47  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000076   backupd
                                                  17:02:47  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000027   mds
                                                  17:02:47  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000016   mds
                                                  17:02:48  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603196747    0.000019   mds
                                                  17:03:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Finder
                                                  17:03:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Finder
                                                  17:03:32  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000013   Finder
                                                  17:03:32  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000017   Finder
                                                  17:03:32  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000017   Finder
                                                  17:03:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000019   Finder
                                                  17:03:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000052   Finder
                                                  17:03:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Finder
                                                  17:03:38  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000017   Finder
                                                  17:03:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000027   Finder
                                                  17:03:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   Finder
                                                  17:03:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000043   Finder
                                                  17:03:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Finder
                                                  17:03:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Finder
                                                  17:03:53  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000023   Finder
                                                  17:03:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Finder
                                                  17:03:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Finder
                                                  17:03:55  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Finder
                                                  17:03:55  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000003   Finder
                                                  17:03:55  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Finder
                                                  17:03:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000015   Finder
                                                  17:03:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Finder
                                                  17:03:55  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000016   Finder
                                                  17:03:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Finder
                                                  17:03:55  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000008   Finder
                                                  17:03:55  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Finder
                                                  17:03:55  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   Finder
                                                  17:03:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Finder
                                                  17:03:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Finder
                                                  17:03:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   Finder
                                                  17:03:55  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   Finder
                                                  17:03:55  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000020   Finder
                                                  17:03:55  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000030   mds
                                                  17:03:55  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   mds
                                                  17:03:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000041   Finder
                                                  17:03:55  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Finder
                                                  17:03:55  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000016   Finder
                                                  17:03:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Finder
                                                  17:03:56  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000031   Finder
                                                  17:03:56  statfs64          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Finder
                                                  17:03:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Finder
                                                  17:03:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   Finder
                                                  17:03:56  statfs64          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000017   Finder
                                                  17:03:56  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Finder
                                                  17:04:06  stat              -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000023   dbfseventsd
                                                  17:04:06  setattrlist       -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    8.889458 W backupd
                                                  17:04:06  setattrlist       -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.064652 W backupd
                                                  17:04:06  open              -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000026   backupd
                                                  17:04:07  stat64            -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000063   mds
                                                  17:04:07  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   mds
                                                  17:04:07  getattrlist       c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000059   backupd
                                                  17:04:07  lstat64           /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000031   mdworker
                                                  17:04:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   mdworker
                                                  17:04:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000020   mdworker
                                                  17:04:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   mdworker
                                                  17:04:07  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000019   mdworker
                                                  17:04:07  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   mdworker
                                                  17:04:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   mdworker
                                                  17:04:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb/.DS_Store         0.000007   mdworker
                                                  17:04:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   mdworker
                                                  17:04:07  stat64            -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000016   mds
                                                  17:07:53  getattrlist       c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    9.461580 W backupd
                                                  17:07:57  open              c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    4.485175 W backupd
                                                  17:07:57  open              c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000072   mds
                                                  17:07:57  stat64            c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000026   mds
                                                  17:07:58  stat64            c Pro/2011-06-04-160355/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000062   mds
                                                  17:10:06  getattrlist       -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000025   backupd
                                                  17:10:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   backupd
                                                  17:10:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  17:10:43  getattrlist       -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000026   backupd
                                                  17:10:43  getattrlist       -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000027   backupd
                                                  17:10:43  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   backupd
                                                  17:10:43  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   backupd
                                                  17:10:43  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000003   backupd
                                                  17:10:43  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000052   backupd
                                                  17:10:43  link              -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000145   backupd
                                                  17:10:43  getattrlist       -491D-8920-D23F278EEA40/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000032   backupd
                                                  17:10:49  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000018   backupd
                                                  17:10:49  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000013   backupd
                                                  17:10:49  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000024   mds
                                                  17:10:49  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000012   mds
                                                  17:10:53  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.000007   mds
                                                  17:11:35  unlink            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603462176    0.092651 W backupd
                                                  17:11:42  unlink            -4EB3-97DD-C21DBB520742/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000115   backupd
                                                  19:42:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000038   Adobe Photos
                                                  19:42:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  19:42:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  19:42:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  19:42:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  19:42:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  19:42:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  19:42:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  19:42:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  19:42:16  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000012   Adobe Photos
                                                  19:42:30  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544   14.363280 W Adobe Photos
                                                  19:42:30  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000023   Adobe Photos
                                                  19:42:30  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000010   Adobe Photos
                                                  19:42:30  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000131 W Adobe Photos
                                                  19:42:30  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000008   Adobe Photos
                                                  19:42:30  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000013   Adobe Photos
                                                  19:42:30  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000007   Adobe Photos
                                                  19:42:30  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000049   Adobe Photos
                                                  19:42:30  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.007490 W mds
                                                  19:42:30  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.007217 W Dropbox
                                                  19:42:30  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000013   Adobe Photos
                                                  19:42:30  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000012   Adobe Photos
                                                  19:42:30  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000009   Adobe Photos
                                                  19:42:30  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000031   Adobe Photos
                                                  19:42:30  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000006   Adobe Photos
                                                  19:42:30  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000021   Adobe Photos
                                                  19:47:16  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000034   Adobe Photos
                                                  19:47:16  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   Adobe Photos
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  19:47:16  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000007   Adobe Photos
                                                  19:47:16  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000007   Adobe Photos
                                                  19:47:16  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  19:47:16  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000015   Adobe Photos
                                                  19:47:16  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000051   dbfseventsd
                                                  19:47:16  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000019   mds
                                                  19:47:16  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.000026   Dropbox
                                                  19:47:16  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.005669 W Adobe Photos
                                                  19:47:16  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603603544    0.030867 W Adobe Photos
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000032   Adobe Photos
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  19:47:16  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000015   Adobe Photos
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Bridge
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Bridge
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Bridge
                                                  19:47:16  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000019   Adobe Bridge
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000015   Adobe Bridge
                                                  19:47:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000041   Adobe Bridge
                                                  19:47:16  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000025   Adobe Bridge
                                                  19:52:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  19:55:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   backupd
                                                  19:55:43  getattrlist       c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.020556 W backupd
                                                  19:55:43  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  19:55:43  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   backupd
                                                  19:55:43  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   backupd
                                                  19:55:43  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   backupd
                                                  19:55:43  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000063   backupd
                                                  19:55:43  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   backupd
                                                  19:55:43  open_extended     -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000114   backupd
                                                  19:55:43  getattrlist       -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000036   backupd
                                                  20:00:37  stat              -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    3.276815 W dbfseventsd
                                                  20:00:37  setattrlist       -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    4.125817 W backupd
                                                  20:00:37  setattrlist       -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.030814 W backupd
                                                  20:00:37  open              -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000035   backupd
                                                  20:00:37  stat64            -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000059   mds
                                                  20:00:37  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   mds
                                                  20:00:37  getattrlist       c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000069   backupd
                                                  20:00:37  lstat64           /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000017   mdworker
                                                  20:00:37  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   mdworker
                                                  20:00:37  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   mdworker
                                                  20:00:37  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000021   mdworker
                                                  20:00:38  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   mdworker
                                                  20:00:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000023   mdworker
                                                  20:00:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   mdworker
                                                  20:00:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000015   mdworker
                                                  20:00:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb/.DS_Store         0.000007   mdworker
                                                  20:00:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   mdworker
                                                  20:00:42  stat64            -41DD-9740-41731897E8E5/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000015   mds
                                                  20:00:58  getattrlist       c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000095   backupd
                                                  20:00:58  open              c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000041   backupd
                                                  20:00:58  open              c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000200   mds
                                                  20:00:58  stat64            c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000075   mds
                                                  20:00:58  stat64            c Pro/2011-06-04-185319/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000043   mds
                                                  20:02:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000042   Adobe Photos
                                                  20:02:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000037   Adobe Photos
                                                  20:02:39  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000024   Adobe Photos
                                                  20:08:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000038   Adobe Photos
                                                  20:08:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  20:08:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  20:08:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  20:08:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  20:08:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  20:08:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  20:08:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  20:08:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  20:08:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  20:08:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000011   Adobe Photos
                                                  20:08:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.013742 W Adobe Photos
                                                  20:08:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000009   Adobe Photos
                                                  20:08:26  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.006348 W Adobe Photos
                                                  20:08:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000010   Adobe Photos
                                                  20:08:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000008   Adobe Photos
                                                  20:08:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000009   Adobe Photos
                                                  20:08:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000007   Adobe Photos
                                                  20:08:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000046   Adobe Photos
                                                  20:08:26  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.014562 W mds
                                                  20:08:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000014   Adobe Photos
                                                  20:08:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000012   Adobe Photos
                                                  20:08:26  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000012   Dropbox
                                                  20:08:26  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000013   Adobe Photos
                                                  20:08:26  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000029   Adobe Photos
                                                  20:08:26  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000022   Adobe Photos
                                                  20:13:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000033   Adobe Photos
                                                  20:13:05  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Photos
                                                  20:13:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  20:13:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000008   Adobe Photos
                                                  20:13:05  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000010   Adobe Photos
                                                  20:13:05  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  20:13:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  20:13:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  20:13:05  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000017   Adobe Photos
                                                  20:13:05  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000017   mds
                                                  20:13:05  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000036   dbfseventsd
                                                  20:13:05  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.000037   Dropbox
                                                  20:13:05  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.005657 W Adobe Photos
                                                  20:13:05  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603605115    0.022510 W Adobe Photos
                                                  20:13:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000029   Adobe Photos
                                                  20:13:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  20:13:05  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000015   Adobe Photos
                                                  20:13:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  20:13:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  20:13:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  20:13:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Bridge
                                                  20:13:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  20:13:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  20:13:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  20:13:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Bridge
                                                  20:13:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Bridge
                                                  20:13:06  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000016   Adobe Bridge
                                                  20:13:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Bridge
                                                  20:13:06  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000017   Adobe Bridge
                                                  20:13:06  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000017   Adobe Bridge
                                                  20:21:14  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  20:21:14  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  20:21:14  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  20:21:14  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  20:21:14  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  20:21:14  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  20:21:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000042   Adobe Photos
                                                  20:21:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000043   Adobe Photos
                                                  20:21:56  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000027   Adobe Photos
                                                  20:43:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000037   Adobe Photos
                                                  20:43:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  20:43:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  20:43:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  20:43:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  20:43:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000022   Adobe Photos
                                                  20:43:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  20:43:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  20:43:50  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  20:43:50  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000012   Adobe Photos
                                                  20:44:05  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311   14.416898 W Adobe Photos
                                                  20:44:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000018   Adobe Photos
                                                  20:44:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000009   Adobe Photos
                                                  20:44:05  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000152 W Adobe Photos
                                                  20:44:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000011   Adobe Photos
                                                  20:44:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000008   Adobe Photos
                                                  20:44:05  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000011   Adobe Photos
                                                  20:44:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000007   Adobe Photos
                                                  20:44:05  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000043   Adobe Photos
                                                  20:44:05  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.010137 W mds
                                                  20:44:05  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.009774 W Dropbox
                                                  20:44:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000026   Adobe Photos
                                                  20:44:05  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000012   Adobe Photos
                                                  20:44:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000032   Adobe Photos
                                                  20:44:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000006   Adobe Photos
                                                  20:44:05  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000024   Adobe Photos
                                                  20:49:09  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000032   Adobe Photos
                                                  20:49:09  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  20:49:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  20:49:09  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000007   Adobe Photos
                                                  20:49:09  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000007   Adobe Photos
                                                  20:49:09  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  20:49:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  20:49:09  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000015   Adobe Photos
                                                  20:49:09  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000038   mds
                                                  20:49:09  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000417 W Adobe Photos
                                                  20:49:09  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.027795 W Adobe Photos
                                                  20:49:09  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.010977 W dbfseventsd
                                                  20:49:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000067   Adobe Photos
                                                  20:49:09  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603738311    0.000012   Dropbox
                                                  20:49:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  20:49:09  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000023   Adobe Photos
                                                  20:49:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  20:49:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Photos
                                                  20:49:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000023   Adobe Photos
                                                  20:49:09  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  20:49:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  20:49:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Bridge
                                                  20:49:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  20:49:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Bridge
                                                  20:49:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Bridge
                                                  20:49:10  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000018   Adobe Bridge
                                                  20:49:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  20:49:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000037   Adobe Bridge
                                                  20:49:10  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000024   Adobe Bridge
                                                  fs_usage: buffer overrun, events generated too quickly: 472843
                                                  20:52:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000024   backupd
                                                  20:54:45  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  20:54:45  getattrlist       c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000083   backupd
                                                  20:54:45  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   backupd
                                                  20:54:45  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   backupd
                                                  20:54:45  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   backupd
                                                  20:54:45  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000057   backupd
                                                  20:54:45  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   backupd
                                                  20:54:45  open_extended     -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000104   backupd
                                                  20:54:45  getattrlist       -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000036   backupd
                                                  21:00:10  setattrlist       -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    8.508412 W backupd
                                                  21:00:10  stat              -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    6.887168 W dbfseventsd
                                                  21:00:10  setattrlist       -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.031328 W backupd
                                                  21:00:10  open              -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000050   backupd
                                                  21:00:10  stat64            -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000036   mds
                                                  21:00:10  stat64            /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   mds
                                                  21:00:10  getattrlist       c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000037   backupd
                                                  21:00:10  lstat64           /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000018   mdworker
                                                  21:00:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   mdworker
                                                  21:00:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000017   mdworker
                                                  21:00:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   mdworker
                                                  21:00:10  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000020   mdworker
                                                  21:00:10  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   mdworker
                                                  21:00:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000022   mdworker
                                                  21:00:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000016   mdworker
                                                  21:00:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000020   mdworker
                                                  21:00:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb/.DS_Store         0.000007   mdworker
                                                  21:00:10  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   mdworker
                                                  21:00:11  stat64            -41FF-97AD-E9798D17E83B/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000029   mds
                                                  21:00:24  getattrlist       c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000034   backupd
                                                  21:00:24  open              c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000026   backupd
                                                  21:00:24  open              c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000251 W mds
                                                  21:00:24  stat64            c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000075   mds
                                                  21:00:24  stat64            c Pro/2011-06-04-200201/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000014   mds
                                                  21:04:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000036   Adobe Photos
                                                  21:04:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:04:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:04:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  21:04:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  21:04:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  21:04:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:04:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:04:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:04:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  21:04:42  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000012   Adobe Photos
                                                  21:04:42  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.015315 W Adobe Photos
                                                  21:04:42  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000011   Adobe Photos
                                                  21:04:42  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000008   Adobe Photos
                                                  21:04:42  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.005923 W Adobe Photos
                                                  21:04:42  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000025   Adobe Photos
                                                  21:04:42  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000006   Adobe Photos
                                                  21:04:42  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000017   Adobe Photos
                                                  21:04:42  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000009   Adobe Photos
                                                  21:04:42  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000067   Adobe Photos
                                                  21:04:42  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.016454 W mds
                                                  21:04:42  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.016131 W Dropbox
                                                  21:04:42  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000019   Adobe Photos
                                                  21:04:42  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000013   Adobe Photos
                                                  21:04:42  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000033   Adobe Photos
                                                  21:04:42  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000022   Adobe Photos
                                                  21:09:54  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000030   Adobe Photos
                                                  21:09:54  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  21:09:54  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000007   Adobe Photos
                                                  21:09:54  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000007   Adobe Photos
                                                  21:09:54  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:09:54  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000015   Adobe Photos
                                                  21:09:54  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000032   dbfseventsd
                                                  21:09:54  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000013   mds
                                                  21:09:54  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.000033   Dropbox
                                                  21:09:54  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.005709 W Adobe Photos
                                                  21:09:54  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603805099    0.022476 W Adobe Photos
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000045   Adobe Photos
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:09:54  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000015   Adobe Photos
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Bridge
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Bridge
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Bridge
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Bridge
                                                  21:09:54  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000014   Adobe Bridge
                                                  21:09:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000039   Adobe Bridge
                                                  21:09:54  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000025   Adobe Bridge
                                                  21:11:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000056   Adobe Photos
                                                  21:11:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:11:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:28:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000035   Adobe Photos
                                                  21:28:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:28:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:28:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  21:28:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  21:28:25  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000027   Adobe Photos
                                                  21:28:25  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  21:28:25  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:28:25  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:28:25  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  21:28:25  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000012   Adobe Photos
                                                  21:28:40  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058   14.382905 W Adobe Photos
                                                  21:28:40  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000028   Adobe Photos
                                                  21:28:40  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000010   Adobe Photos
                                                  21:28:40  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000103 W Adobe Photos
                                                  21:28:40  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000008   Adobe Photos
                                                  21:28:40  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000013   Adobe Photos
                                                  21:28:40  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000007   Adobe Photos
                                                  21:28:40  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000044   Adobe Photos
                                                  21:28:40  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000094 W mds
                                                  21:28:40  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000014   Adobe Photos
                                                  21:28:40  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000012   Adobe Photos
                                                  21:28:40  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000009   Adobe Photos
                                                  21:28:40  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000036   Dropbox
                                                  21:28:40  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000025   Adobe Photos
                                                  21:28:40  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000006   Adobe Photos
                                                  21:28:40  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000021   Adobe Photos
                                                  21:33:54  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000038   Adobe Photos
                                                  21:33:54  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000015   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  21:33:54  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000009   Adobe Photos
                                                  21:33:54  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000010   Adobe Photos
                                                  21:33:54  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:33:54  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000018   Adobe Photos
                                                  21:33:54  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000020   dbfseventsd
                                                  21:33:54  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000055   mds
                                                  21:33:54  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.000097   Dropbox
                                                  21:33:54  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.005644 W Adobe Photos
                                                  21:33:54  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603872058    0.014178 W Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000046   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  21:33:54  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000037   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000025   Adobe Photos
                                                  21:33:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000013   Adobe Photos
                                                  21:33:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  21:33:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Bridge
                                                  21:33:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Bridge
                                                  21:33:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  21:33:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Bridge
                                                  21:33:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  21:33:56  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000014   Adobe Bridge
                                                  21:33:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Bridge
                                                  21:33:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Bridge
                                                  21:33:56  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000017   Adobe Bridge
                                                  21:36:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000019   Adobe Photos
                                                  21:36:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:36:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:36:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  21:36:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000037   Adobe Photos
                                                  21:36:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:36:05  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:37:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000042   Adobe Photos
                                                  21:37:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:37:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Photos
                                                  21:37:08  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:48:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000036   Adobe Photos
                                                  21:48:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:48:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:48:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Photos
                                                  21:49:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  21:49:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:49:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:49:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  21:49:03  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000012   Adobe Photos
                                                  21:49:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832   14.365392 W Adobe Photos
                                                  21:49:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000026   Adobe Photos
                                                  21:49:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000010   Adobe Photos
                                                  21:49:17  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000093 W Adobe Photos
                                                  21:49:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000008   Adobe Photos
                                                  21:49:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000011   Adobe Photos
                                                  21:49:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000007   Adobe Photos
                                                  21:49:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000045   Adobe Photos
                                                  21:49:17  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.025809 W mds
                                                  21:49:17  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.019133 W Dropbox
                                                  21:49:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000012   Adobe Photos
                                                  21:49:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000012   Adobe Photos
                                                  21:49:17  open              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000013   Adobe Photos
                                                  21:49:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000032   Adobe Photos
                                                  21:49:17  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000006   Adobe Photos
                                                  21:49:17  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000022   Adobe Photos
                                                  21:53:05  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000009   backupd
                                                  21:53:07  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   backupd
                                                  21:55:02  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000046   Adobe Photos
                                                  21:55:02  access_extended   /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000019   Adobe Photos
                                                  21:55:02  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000011   Adobe Photos
                                                  21:55:02  getattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000008   Adobe Photos
                                                  21:55:02  listxattr         HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000009   Adobe Photos
                                                  21:55:02  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:55:02  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Photos
                                                  21:55:02  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000021   Adobe Photos
                                                  21:55:02  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000014   dbfseventsd
                                                  21:55:02  stat64            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000043   mds
                                                  21:55:02  stat              HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.000034   Dropbox
                                                  21:55:02  setattrlist       HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.005589 W Adobe Photos
                                                  21:55:02  rename            HD 3/.TemporaryItems/folders.501/TemporaryItems/nuptial_02.v6.psb940603938832    0.030839 W Adobe Photos
                                                  21:55:02  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000021   Adobe Photos
                                                  21:55:02  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Photos
                                                  21:55:02  setattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000014   Adobe Photos
                                                  21:55:02  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Photos
                                                  21:55:02  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Photos
                                                  21:55:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000007   Adobe Bridge
                                                  21:55:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Bridge
                                                  21:55:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000008   Adobe Bridge
                                                  21:55:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   Adobe Bridge
                                                  21:55:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   Adobe Bridge
                                                  21:55:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   Adobe Bridge
                                                  21:55:04  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000021   Adobe Bridge
                                                  21:55:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000012   Adobe Bridge
                                                  21:55:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000026   Adobe Bridge
                                                  21:55:04  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb>>>>>>>>>>>>>>     0.000020   Adobe Bridge
                                                  21:55:15  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  21:55:15  getattrlist       c Pro/2011-06-04-210127/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000088   backupd
                                                  21:55:15  listxattr         /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000009   backupd
                                                  21:55:15  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000005   backupd
                                                  21:55:15  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000004   backupd
                                                  21:55:15  getxattr          /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000173   backupd
                                                  21:55:15  open              /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000010   backupd
                                                  21:55:15  open_extended     -4311-B922-E59F9A3B8410/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000121   backupd
                                                  21:55:15  getattrlist       -4311-B922-E59F9A3B8410/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb    0.000046   backupd
                                                  21:56:41  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000041   Adobe Photos
                                                  21:56:41  getattrlist       /Volumes/Macintosh HD 3/Lendon/BC/nuptial 02/nuptial_02.v6.psb                   0.000006   Adobe Photos
                                                  ^C
                                                  Yes, the Dropbox calls are disturbing -- it is getting info on files that are nowhere near it's directories.
                                                  dbfseventsd also appears to be a Dropbox related service, and also getting info on files nowhere near the Dropbox directory.  (are you sure you didn't set Dropbox to use the whole disk by mistake?)
                                                  I am not sure what disk Dropbox uses and am trying to find out, but don't know how to do this. Dropbox is installed on the same internal drive as the OS and photoshop. The second internal drive is the scratch disk for photoshop and the third internal drive is where my files are stored. Attached below is a screenshot of Dropbox's advanced preferences. If I unlink this computer, will dropbox not use the whole disk? Also dropbox appears in my home folder.dropbox.jpg
                                                  • 62. Re: Your disk copy of image was changed since last opened or saved
                                                    Level 7
                                                    That's the Dropbox account settings, not advanced.  Under advanced it should show the location of the dropbox folder, which defaults to a folder inside your home account (~/Dropbox).
                                                    • 63. Re: Your disk copy of image was changed since last opened or saved
                                                      caligula1 Level 1
                                                      • 64. Re: Your disk copy of image was changed since last opened or saved
                                                        Level 7
                                                        According to that log, backupd (TimeMachine) is backing up and modifying the temporary files -- and it shouldn't go near /temp or /TemporaryItems.
                                                        In one case it starts reading a file *while* Photoshop is still saving that file.
                                                        In some cases, it is modifying the temporary file (setattrlist).
                                                        And there are several examples of Dropbox and dbfseventsd sniffing files that it shoudn't be (also in temp directories).
                                                        dbfseventsd also appears to be sniffing file changes on the Time Machine backup volume.  I double checked - it is part of Dropbox (/Library/DropboxHelperTools/...), not part of the OS - but it's monitoring every file written, everywhere.  That's really sloppy, and might be slowing down my system.  Ugh, I may have to uninstall Dropbox.
                                                        The players:   Photoshop, Bridge, Dropbox, Time Machine, Spotlight, Finder
                                                        Photoshop creates a temp file, writes to the temp file, and renames the temp to replace the original file, plus gets stat on the files.
                                                        Bridge only reads the file, and writes to it's database.
                                                        Finder gets attributes on the file in the normal folders.
                                                        Dropbox gets stat on the files from 2 different processes (Dropbox, dbfseventsd), even outside it's directory, even in temporary directories.
                                                        Spotlight (mdworker, mds) gets stat, and reads the files, even in temporary directories, sometimes while the file is still being written.
                                                        Time Machine (backupd) gets stats, reads the files, and sometimes sets attributes on the files, even in temporary directories.
                                                        Photoshop, Bridge and Finder are acting as expected.
                                                        While Dropbox and Spotlight are doing some excess work, they don't seem to cause file modifications.
                                                        But Time Machine is doing things wrong and causing file modifications, plus would fit with the "have the file open a long time" symptom.
                                                        • 65. Re: Your disk copy of image was changed since last opened or saved
                                                          Level 7
                                                          Not quite, I wanted the location of the top level Dropbox folder.
                                                          But on my own system I've confirmed that Dropbox and dbfseventsd will get stats on files outside the Dropbox folder.
                                                          Dropbox has some bugs to fix.
                                                          • 66. Re: Your disk copy of image was changed since last opened or saved
                                                            caligula1 Level 1
                                                            Thank you Chris. I will forward a link to what you have posted to Apple.
                                                            The top level dropbox folder, the one called "files for Michael" says in file > get info > where  that it is located in users> the name of the user > dropbox.
                                                            Is that what you want?
                                                            • 67. Re: Your disk copy of image was changed since last opened or saved
                                                              Level 4
                                                              How I long for the days of Panther's elegance and simplicity, before obnoxious, intrusive junk like Spotblight, Dashboard, Time Machine, Spaces, Exposé, etc. were introduced by Apple…
                                                              • 68. Re: Your disk copy of image was changed since last opened or saved
        caligula1 Level 1
        I did experience the issue when Apple had me turn off time machine entirely for about a two week period. At another time Apple had me turn off dropbox entirely although it was not uninstalled. I don't remember how they had me turn it off, but the issue still occurred. The issue also occurred before I ever installed dropbox. I am not sure however if time machine and dropbox were both disabled at the same time.
        I am going to test whether the issue occurs with dropbox uninstalled, time machine turned off and spotlight disabled all at the same time.
        • 69. Re: Your disk copy of image was changed since last opened or saved
        Level 7
        Yeah, that's what I wanted, it's in your user directory.
        But, again, I already tested it on my system and found it monitors ALL file IO, regardless of location.
        Looks like someone took a brute force approach to making Dropbox work.
        • 70. Re: Your disk copy of image was changed since last opened or saved
        MuggeGHQ Level 1
        Hi.
        I also have Dropbox installed but it never runs. I only start it when needed at quits it after.
        But as i remember it it happen before installing Dropbox and i never use Time Machine or Spotlight.
        Both are turned completely of with Cocktail ?
        But i will give it a try and uninstall Dropbox totally and see if that helps. But i dough it because as
        i remember it, it also happen before un-installing Dropbox.
        • 71. Re: Your disk copy of image was changed since last opened or saved
        Level 7
        Well, the only way to find out what is modifying the files is to use fs_usage on the command line while working in Photoshop.
        But the results are not an easy thing to read (as you can see above).
        • 72. Re: Your disk copy of image was changed since last opened or saved
        MuggeGHQ Level 1
        Alright.
        Last night i uninstalled Dropbox completely on the computer where all the files are stored on.
        No effect. Still the same so i guess Dropbox is out of the discussion ?
        Ofcause restarted and did a total maintance with Cocktail after
        I think the biggest problem with this is when the message comes if you just press "Ok" to safe anyway.
        The latest stuff made on the pictures is not always saved since last saving ! Thats my problem.
        Sometimes it saves everything and sometimes it doesn't and all the stuff you made since last save will be lost
        Thats why i mostly do a "save as" and then saves it to another location when the message comes just to be 100%
        and then after copying to the right location at the end. Lots of extra work.
        • 73. Re: Your disk copy of image was changed since last opened or saved
        Level 7
        Yeah, I don't think dropbox is the problem.
        But I haven't been able to reproduce the pattern of file access you see from backupd on my 10.5.8 or 10.6.7 machines.
        When you save, Photoshop is saving what you have in memory at that time.  And unless the save fails (and gives you an error), that is what should be in the file.  If something is lost, then it was most likely a problem with the file system outside of Photoshop.
        • 74. Re: Your disk copy of image was changed since last opened or saved
        caligula1 Level 1
        Chris, I choose in system preferences to prevented spotlight from searching the internal hard drive where my files are stored and saved to. I also choose to exclude that hard drive from time machine backups. I dragged dropbox out of my applications folder and put it on my desktop. I worked for a few days in photoshop without receiving a message about the disk copy being changed, but eventually I got that message. I then checked in utilities and saw that a folder was there called dropbox helper tools. I dragged that folder to the desktop as well. Could that be the reason that the disk copy was changed?
        • 75. Re: Your disk copy of image was changed since last opened or saved
        Level 7
        It's possible, but without reproduceable steps (or a file access log), I can't be sure.
        • 76. Re: Your disk copy of image was changed since last opened or saved
        MuggeGHQ Level 1
        Hi.
        I really don't think its Dropbox because one week back when i saw your where talking about Dropbox i deleted everything from Dropbox and i still
        have the error sometimes. Its funny because yesterday i tried to active the "auto-update open documents" i preferences an since then i haven't had
        the error yet. Crossed finger, only one day have passed. But then after i activated the auto-update i out of luck saw in my history pane "updated from file"
        so that means something touched my file and then PS updated it i guess ? So now i'm a little afraid of using the auto-update thing if i´m not 100% sure
        of whats going on. The worst thing that could happen is stuff i make on my pictures is not saved. As i said earlier, i ones had a situation where edits i
        did on pictures was not always saved ? really strange.
        But i also think the hole thing is strange because i don't have a lot of extra stuff running on my working Mac. Logmein, Dropbox (not anymore) and the
        free virus app "ClamXav" thats it. And yes Suitcase Fusion 3.
        But as i also said earlier. Its even more strange because all this stuff started happen after i installed Snow Leopard. I had used 10.5.8 for a long time
        and then one day "2 month ago" i installed SL on all our Studio computers and then it started. I never had the situation when 10.5.8 was installed.
        First after 10.6.x came on. I updated the perfect running 10.5.8 to 10.6.3 from retail installer DVD and then upgraded to 10.6.6 and now all this.
        Would it be safe to use the auto-update open documents. Because i don't get the warning when this is turned on ? please advice.
        • 77. Re: Your disk copy of image was changed since last opened or saved
        MichaelBrunsfeld Level 1
        I started having this problem a few months ago. Now, we have this same thread going in the NAPP forum, and folks there are equally stumped.
        I don't think this is a small isolated problem, as I am hearing about it from a number of sources.
        • 78. Re: Your disk copy of image was changed since last opened or saved
        Level 7
        We're only hearing it from a few people.
        And it may not be isolated, but on a clean OS install it doesn't happen, nor does it happen to most users.
        There is some factor involved that hasn't been discovered yet.
        But we are pretty sure that either something outside Photoshop changes the file, or that something in the OS is confused about the modification time of the file.
        • 79. Re: Your disk copy of image was changed since last opened or saved
        caligula1 Level 1
        Chris,
        I have turned off time machine. I am also not allowing spotlight to search the internal hard drive on which my files are saved. Dropbox has been thrown in the trash. I am still receiving the message about the disk copy being changed.
        Do you mind looking at another terminal log for a file I tracked? I received the message about the disk copy being changed at around 20:40.
        I don't see any applications on the list except photoshop and finder. (Microsoft which appears at the end of the list is probably there because I went to Microsoft word to look at my instructions for using the terminal command after getting the message about the disk copy being changed.
        Thanks a lot.
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000037   Adobe Photos
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000022   Adobe Photos
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000016   Adobe Photos
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        17:30:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        17:30:38  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        17:30:38  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000009   Adobe Photos
        17:31:00  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000031   Adobe Photos
        17:31:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000035   Adobe Photos
        17:31:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        17:31:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        17:31:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        17:35:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000037   Adobe Photos
        17:35:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000014   Adobe Photos
        17:35:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        17:35:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        17:35:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        17:35:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        17:35:19  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000019   Adobe Photos
        17:35:19  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        17:35:19  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        17:35:19  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        17:35:36  access_extended   /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        17:35:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        17:35:36  listxattr         /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        17:35:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        17:35:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        17:35:36  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000015   Adobe Photos
        17:35:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000053   Adobe Photos
        17:35:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Adobe Photos
        17:35:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        17:35:36  setattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000023   Adobe Photos
        17:35:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        17:35:36  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        17:35:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000013   Finder
        17:35:38  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000014   Finder
        17:35:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000035   Finder
        17:35:38  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000023   Finder
        17:35:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Finder
        17:35:38  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000008   Finder
        18:11:45  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000039   Adobe Photos
        18:11:45  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        18:11:45  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        18:11:45  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:11:45  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Adobe Photos
        18:11:46  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000019   Adobe Photos
        18:11:46  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:11:46  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:11:46  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:12:42  access_extended   /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000013   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000022   Adobe Photos
        18:12:42  listxattr         /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:12:42  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000015   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000033   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:12:42  setattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000026   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Finder
        18:12:42  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000015   Finder
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000035   Finder
        18:12:42  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000023   Finder
        18:12:42  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Finder
        18:12:42  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000008   Finder
        18:23:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000037   Adobe Photos
        18:23:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:23:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        18:23:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        18:23:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:23:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000021   Adobe Photos
        18:23:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        18:23:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        18:23:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:23:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:23:53  access_extended   /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000013   Adobe Photos
        18:23:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        18:23:53  listxattr         /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        18:23:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Adobe Photos
        18:23:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:23:53  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000017   Adobe Photos
        18:23:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000043   Adobe Photos
        18:23:53  setattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000021   Adobe Photos
        18:23:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:23:53  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:23:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Finder
        18:23:54  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000013   Finder
        18:23:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000036   Finder
        18:23:54  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000025   Finder
        18:23:54  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Finder
        18:23:54  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000010   Finder
        18:26:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000044   Adobe Photos
        18:26:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        18:26:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        18:26:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:26:16  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        18:26:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000020   Adobe Photos
        18:26:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:26:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:26:18  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:26:38  access_extended   /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000014   Adobe Photos
        18:26:38  listxattr         /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:26:38  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000014   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000047   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Adobe Photos
        18:26:38  setattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000021   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000013   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        18:26:38  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:26:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Finder
        18:26:39  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000011   Finder
        18:26:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000034   Finder
        18:26:39  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000021   Finder
        18:26:39  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Finder
        18:26:39  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000008   Finder
        18:34:33  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000038   Adobe Photos
        18:34:33  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:34:33  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:34:33  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:34:33  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        18:34:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000019   Adobe Photos
        18:34:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:34:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:34:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:34:47  access_extended   /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000016   Adobe Photos
        18:34:47  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Adobe Photos
        18:34:47  listxattr         /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:34:47  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:34:47  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000017   Adobe Photos
        18:34:47  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000046   Adobe Photos
        18:34:47  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:34:47  setattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000020   Adobe Photos
        18:34:47  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        18:34:47  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        18:34:47  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:34:48  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Finder
        18:34:48  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000012   Finder
        18:34:48  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000019   Finder
        18:34:48  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000021   Finder
        18:34:48  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Finder
        18:34:48  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000008   Finder
        18:57:31  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000035   Adobe Photos
        18:57:31  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:57:31  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:57:31  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        18:57:31  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:57:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000019   Adobe Photos
        18:57:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:57:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:57:34  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:57:56  access_extended   /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        18:57:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        18:57:56  listxattr         /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        18:57:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        18:57:56  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000015   Adobe Photos
        18:57:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000044   Adobe Photos
        18:57:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Adobe Photos
        18:57:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        18:57:56  setattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000016   Adobe Photos
        18:57:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        18:57:56  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        18:57:57  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000016   Finder
        18:57:57  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000014   Finder
        18:57:57  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000041   Finder
        18:57:57  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000024   Finder
        18:57:57  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Finder
        18:57:57  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000008   Finder
        fs_usage: buffer overrun, events generated too quickly: 466603
        fs_usage: buffer overrun, events generated too quickly: 472312
        20:21:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000072   Adobe Photos
        20:21:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        20:21:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        20:21:03  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        20:21:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000019   Adobe Photos
        20:21:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        20:21:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        20:21:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        20:21:04  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        20:21:26  access_extended   /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        20:21:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        20:21:26  listxattr         /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        20:21:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        20:21:26  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000015   Adobe Photos
        20:21:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000018   Adobe Photos
        20:21:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        20:21:26  setattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Adobe Photos
        20:21:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        20:21:26  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        20:21:27  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000020   Finder
        20:21:27  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000014   Finder
        20:21:27  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000037   Finder
        20:21:27  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000023   Finder
        20:21:27  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Finder
        20:21:27  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000008   Finder
        20:31:59  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000040   Adobe Photos
        20:31:59  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        20:31:59  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        20:31:59  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        20:31:59  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000012   Adobe Photos
        20:32:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000019   Adobe Photos
        20:32:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        20:32:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        20:32:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        20:32:01  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000005   Adobe Photos
        20:32:23  access_extended   /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000016   Adobe Photos
        20:32:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000010   Adobe Photos
        20:32:23  listxattr         /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        20:32:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        20:32:23  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000015   Adobe Photos
        20:32:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000019   Adobe Photos
        20:32:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000009   Adobe Photos
        20:32:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Adobe Photos
        20:32:23  setattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000013   Adobe Photos
        20:32:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000011   Adobe Photos
        20:32:23  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000006   Adobe Photos
        20:32:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000013   Finder
        20:32:24  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000014   Finder
        20:32:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000035   Finder
        20:32:24  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000024   Finder
        20:32:24  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Finder
        20:32:24  open              /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd>>>                     0.000008   Finder
        20:40:02  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000037   Adobe Photos
        20:40:02  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000007   Adobe Photos
        mdls 20:42:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000025   Microsoft Wo
        20:42:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000017   Microsoft Wo
        20:42:44  getattrlist       /Volumes/Macintosh HD 3/Lendon/Heineken/Heineken_fin3.psd                        0.000008   Microsoft Wo
        /Volumes/Macintosh\ HD\ 3/Lendon/Heineken/Heineken_fin3.psd
        1 2 3 4 Previous Next
