I have just migrated a project from Flash Builder 4.0 to 4.5 using the export/import feature provided by Flash Builder.
After importing the project the following compile error appear in auto generated classes generated from BlazeDS services _Super_XXXService.as.
The error is in this line:
_serviceControl.convertResultHandler = mx.data.TypeUtility.convertResultHandler;
Description Resource Path Location Type
1119: Access of possibly undefined property convertResultHandler through a reference with static type Class. _Super_CompanyService.as
The autocomplete feature finds a class with hame TypeUtility in a package different from mx.data, com.adobe.serializers.utility.TypeUtility.
Any idea what might be the source of this error?
Best regards,
Rodrigo
I ran into pretty much the same issue, but in my case I have trouble with the SystemManager:
Error: Interface method addPreloadedRSL in namespace mx.core:IFlexModuleFactory not implemented by class _... and about 13 more. This error only occurs if I include the latest cairngorm libs. I can build apps fine w/o cainrgorm.
Is there an ETA for cairngorm libs that support 4.5?
Is there an easy workaround (I'm not so keen on building cairngorm myself)
These are the ones I use:
<dependency>
<groupId>com.adobe.cairngorm</groupId>
<artifactId>integration</artifactId>
<version>0.17</version>
<type>swc</type>
</dependency>
<dependency>
<artifactId>integrationParsley</artifactId>
<type>swc</type>
</dependency>
<dependency>
<artifactId>observer</artifactId>
<version>1.15</version>
<type>swc</type>
</dependency>
Jacques
Hi Jacques,
Thanks for your response. In the project we are not using cairngorm. I guess this _Super_XXXService.as classes are generated by Flash Builder, so I deleted the services and created new ones in Flash Builder 4.5. But the error persist, it can not compile the classes it generates automatically.
A new version of BlazeDs is required to work with the new Flash Builder 4.5?
Rodrigo
Hello,
Same issue to me to, but that strange : i have the update of FlashBuiler 4.5 on 2PC, on with XP and other with WIN 7 the pbm occure only on XP !
Don't know the relation with the system. I have found that the path to change in _Super_XXXService.as classes is now : com.adobe.serializers.utility.TypeUtility._serviceControl.convertResultHandler
conflict for the SDK version ??.
it seam to me that i have now to a pbm withthe php file encodage in services en gateway.php.....but can't resolve it. !!
fbm
I am having the same problem on Mac Snow Leopard, but the class resolves a bit differently:
_serviceControl.convertResultHandler = com.adobe.serializers.utility.TypeUtility.convertResultHandler;
This looks like a bug in the BlazeDS code gen?
I've cross-posted to this thread to (1) document my Mac-specific workaround and (2) describe the other problem of the _Super classes for all Services getting clobbered if one Service is deleted/re-added: http://forums.adobe.com/thread/861396?tstart=0
Im glad that it is not only me with this error. I have mac os x snow leopard.
Rodrigo
There is a JIRA issue on this:
https://bugs.adobe.com/jira/browse/CGM-66
I'm wondering if this forum is the right place to post this kind of issues. Any ideas?
Rodrigo
Yes, this is the right place. However, this thread continued elsewhere:
Thanks, I could solve it with the provided solution.
See:
http://bugs.adobe.com/jira/browse/FB-31218
Rodrigo
