1. Re: Air for Android: Hardware accelerator
Peter Blazejewicz Jun 13, 2011 5:10 AM (in response to nidaSamurai)Hi Alberto,
I think you should update your project application descriptor to add Android specific configuration detail, see docs for explanation:
hth,
kind regards,
Peter
2. Re: Air for Android: Hardware accelerator
nidaSamurai Jun 13, 2011 7:55 AM (in response to Peter Blazejewicz)Hi Peter,
thank you for your answer!
Unfortunately I've tried what is explained in the link that you have posted, but when I try to install the Android SDK Tools it say that I don't have the JDK installed.
I've downloaded and installed also the JDK but the same message is shown and I can't finish the installation.
Do you have any suggestion?
3. Re: Air for Android: Hardware accelerator
Peter Blazejewicz Jun 14, 2011 1:42 AM (in response to nidaSamurai)Hi,
I assume you're on windows:
Did you know that there is outstanding bug in Android tools installer for Windows? see:
http://stackoverflow.com/questions/4382178/android-sdk-installation-doesnt-find-jdk
(when you get popup/error with that message use "Back" in installation wizard and then simply go "Next" again).
regards,
Peter
4. Re: Air for Android: Hardware accelerator
nidaSamurai Jun 14, 2011 7:20 AM (in response to Peter Blazejewicz)Hi Peter,
thank you very much for your answer.
With the operations you suggested I've installed correctly the Android SDK.
I've compiled my app with the command line and I've set the XML adding the hardware accelerated line, but unfortunately I view always the blank StageWebView without any document on it. I don't know why...
Thank you for your helpful answer.
Alberto
