3 Replies Latest reply: Jun 14, 2011 6:41 AM by Stan Jones RSS
    Replace asset for a Premiere dynamic linked sequence
    Marcus Koch Community Member
      I linked Premiere sequences via Dynamic Link to Encore. I had trouble with Encore freezing during transcode. Therfore to make it quick I rendered the sequences to MPEG-2 from Premiere using AME. This worked. I tried to replace the assets, but when I click right on an imported sequence Replace Asset is greyed out. Even it is a sequence from Premiere it is an asset and should be able to be replaced. I can't remove the sequence asset from the timeline in Encore, because all the chapter markers and links are set already. It is an instructional DVD of 4 hours with 120 chapter markers and 12 menus. Nothing you want to do over again.
      I tried to use Locate Transcode instead. My thought is that I can point to the transcoded MPEG-2 files to have Encore "replace" the asset. I got an error that the length of the sequence and the transode file don't match. I don't know why this is since it is the same timeline that was just rendered from Premiere.
      Does anybody has any insight or know a proper way to replace a Dynamic Linked Sequence with the rendered MPEG-2 file?
      Marcus
