Hello All
Does anybody know the right way to use flash.desktop.NativeApplication and not run into
1172: Definition flash.desktop:NativeApplication could not be found.
or
1120: Access of undefined property NativeApplication.
It works fine when the publish settings are set to iOS, but when I switch to publish a "normal" swf I get the error.
Best
Skeeto
Itz only work with AIR
Hello
Thank you.
Yes, I found out/know.
However, when you make a crossplatform app for both Flash/iOS/etc. it's necessary to have some parts of the code taking care of platform specific things.
It's not practial to have to comment out/in parts of your code whenever you change publishng target.
So far I have found out to use conditional compiling and use a CONFIG::CONST in actionscript settings.
It's a bit annoying to have to switch this/these const to true/false whenever you change platform in publish settings, but it's a lot better than changing the code.
/Skeeto
I didn't aware of CONFIG::CONST?
Hello
You can see here how it is done
You then go to your actionscript settings in Flash and enter your constant settings by clicking the "+".
/Skeeto
