1. Re: Control Panel - round to 3 decimal points
Grant H Jun 8, 2011 4:31 PM (in response to kalvin4599)are you using CS2 by any chance?
G
2. Re: Control Panel - round to 3 decimal points
Grant H Jun 8, 2011 5:12 PM (in response to kalvin4599)any way. if thats the case — Cs2 — then you cant change it. And if you had a Intel Mac then you get up to 15 or more... (was an issue till Cs2 update I think)
G
3. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 8, 2011 6:00 PM (in response to Grant H)I'm using CS4 on an Intel Based Mac.
4. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 8, 2011 6:01 PM (in response to Grant H)how do you set it?
5. Re: Control Panel - round to 3 decimal points
Grant H Jun 8, 2011 6:06 PM (in response to kalvin4599)hold on: you working in inches right? i forget that some times... inches in CS4 decimals = 4.... mm = 3...
Cant change dude.
G
6. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 8, 2011 6:41 PM (in response to Grant H)Yes, inches.
Somewhere, there has to be a programmer that can change this for me....
7. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 8, 2011 7:59 PM (in response to kalvin4599)kalvin4599 wrote:
Yes, inches.
I don't know about changing the actual Illustrator palette's decimal places, but there's hope...there's a project (that's been kind of on hold) that does something similar. Unfortunately, faulty Illustrator doesn't work as advertised and interactive palettes don't work.
http://forums.adobe.com/thread/805267
a working "always on top" window that resembles an AI palette can be programmed in Windows...so...I'm assuming it could be done on a mac too, but it might not.
8. Re: Control Panel - round to 3 decimal points
JETalmage Jun 9, 2011 8:01 PM (in response to kalvin4599)As to the difficulty of getting AI's scripting to generate a palette that works as expected:
For those unfamiliar, the issue is this: The whole purpose of a palette is to enable the dialog to remain on screen, and have its values update accordingly while program focus is changed to the document window (as when one has to change the selection). I, too, have never got this to work as advertised. But I'm not certain I'm not overlooking something.
Using a modal dialog (of which Illustrator is excruciatingly full), in a script prevents you from interacting with the page until the dialog is dismissed. So capturing the existing values of an object's position and size is fairly trivial (as is converting the values to the current ruler units). But you have to dismiss the dialog before you can select the object to which you then want to apply the values. Doing so ends the script, so the script no longer "remembers" the values it captured.
Nonetheless, a workaround is possible by using a temporary on-page object to contain the values (several of my own scripts resort to this), and run two scripts. For example, a pair of TransferValues scirpts could work thusly:
Script one:
Captures the values from the current selection.
Creates a textFrame somewhere.
Names the textFrame.
Sets the text of the textFrame to the values.
Ends.
The user then selects another object.
Script two:
Finds the textFrame by its name.
Grabs the values from the textFrame's content as variables.
Applies the variables to the current selection.
Ends.
Script two can either be made to delete the textFrame, or leave it be so that Script two can be run on as many other objects as desired. Best way depends on the specifics of the intended purpose.
Another workaround might be one script, run when multiple objects are selected:
First, the user makes sure the object from which the values are to be captured is either frontmost or rearmost.
Then, the user selects that object and all objects to which the values are to be applied.
The user invokes the script.
The script applies the values of the frontmost object of the current selection to all the other objects in the selection.
Many of the things a scripter would accomplish with a non-modal Palette could be accomplished by combining Action steps (to playback normal UI moves) with Javascripts run by the Action using the Insert Menu Command---if only Adobe would fix the 6-version-old bug which causes the script calling step to go vacant after a relaunch of the program.
JET
9. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 10, 2011 12:37 PM (in response to JETalmage)I don't think I need to generate a palette, but your response did give me an idea: is there a script or utility that would let me copy the information out of the control panel, round it to 3 decimils, and let me paste it?
10. Re: Control Panel - round to 3 decimal points
JETalmage Jun 10, 2011 2:17 PM (in response to kalvin4599)but your response did give me an idea
That's what I just described. I have not written the script, but my previous post describes two possible schemas for doing so. For anyone to write one that would work for your purpose would first require your carefully describing exactly what you want it to do. What values do you want to capture? Do you want to apply them to one other object, or multiple objects? If the other objects are in differing positions on the page, what exactly do you want to occur? And so on.
Scripting is very literal. The script will do exactly what you code it to do and nothing more. So you really have to think through the possible scenarios in which you would invoke it, and the caveats those scenarios may present.
JET
11. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 10, 2011 2:27 PM (in response to JETalmage)Oh, I really didn't make that part clear. I need to be able to copy the height or width of an object, out of the control panel, then paste it as text into the illustrations. Literally, I select an object, copy it's width, hit escape (to clear out of the control panel) select a text object and paste the value as a label into the illustration. My client has asked me to label the drawing to the 3rd decimal point and I have rounded incorrectly a few times.
12. Re: Control Panel - round to 3 decimal points
JETalmage Jun 11, 2011 11:06 AM (in response to kalvin4599)So you just need a rudimentary dimension tool.
The script is dependent upon the presence of a couple of Graphic Styles and Paragraph Styles. So after installing the script, open the AI file named JET_DimensionStyles and follow the instructions to copy/paste the provided object.
After doing that, to use it, get the Line Tool and draw a path corresponding to the dimension you want, snapping to object bounds or anchorPoints (turn on SmartGuides). Then run the script.
Of course if you paste the object into your startup files or templates, you'll have it for any new documents.
JET
13. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 11, 2011 12:44 PM (in response to JETalmage)Close, very close, by dimention lines,arrow heads and text lable are already part of the illustration. I just need the part where it copys the width of the object, rounds that data to 3 decimil points and loads it into the pasteboard, so I can then paste the data into the lable.
14. Re: Control Panel - round to 3 decimal points
JETalmage Jun 11, 2011 1:38 PM (in response to kalvin4599)So just get the text tool, swipe across the text created by the script, copy, delete the group, and paste into your pre-existing textFrame. Pretty much the same thing you'd have to do if the script only drew the textframe object. (Either way seems alot of bother just to round a given value to thousanths.)
JET
15. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 14, 2011 9:00 AM (in response to JETalmage)Yes, too many steps. I'm looking to shave off seconds. I just need to find a script writer to write me a custom script.
16. Re: Control Panel - round to 3 decimal points
PrepressPro1 Jun 14, 2011 9:39 AM (in response to kalvin4599)Here is a link to the thread I put up to get a similar task completed. All you would need do is have the script reduce the number to 3 decimal places.
17. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 14, 2011 10:02 AM (in response to PrepressPro1)I know nothing about writing or editing scripts. If you, or anyone reading this, is willing to write me a custom script, I am willing to pay for it. I downloaded one of JET's scrips (.jsx file), and will able to install and run it, but that is the extent of my knowldedge of scrips.
18. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 14, 2011 12:48 PM (in response to kalvin4599)do you always need to label both, height and width? or sometimes H? sometimes W?
does the text box where you paste the dimmensions have other text, besides what you're pasting?
can you post a screen shot with actual selected object and text frame?
19. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 14, 2011 1:24 PM (in response to CarlosCanto) -
20. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 14, 2011 2:58 PM (in response to kalvin4599)cool, how about this
- select both, the text and the object
- run a script
the script will get the selected object's width (6.2112) and change the text frame accordingly (6.211).
would that work for you? the script would have to run once per pair (object, text frame) at a time
another option, if you already have all the text frames labeled correctly but with 4 decimals, we could select all text frames, and run a script to round to 3 decimals in one go.
21. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 14, 2011 3:04 PM (in response to CarlosCanto)The second option would be GREAT!! I created 450 drawings before the client changed their mind to go from 4 to 3 decimal places.
I don't know know to write scripts, so if you are willing to write, I will gladly pay you for it.
22. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 14, 2011 4:34 PM (in response to kalvin4599)I'll write one tonight after work
23. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 14, 2011 8:48 PM (in response to kalvin4599)here you go, select as many text Frames as you wish before running
#target Illustrator // script.name = roundSelectedFrames.jsx; // script description = rounds selected textFrames to 3 decimals; // script.required = select at least one text frame before running; // script.parent = CarlosCanto // 6/14/11; // script.elegant = false; var idoc = app.activeDocument; sel = idoc.selection; if (sel.length>0) { for (i=0 ; i<sel.length ; i++ ) { var iframe = sel[i]; iframe.contents = Number(iframe.contents).toFixed(3); } } else { alert("select at least one text frame before running"); } -
24. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 14, 2011 9:20 PM (in response to CarlosCanto)I know how to run a .jsx file through Illustrator, but I don't know how to make one from the text you sent.
25. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 14, 2011 9:47 PM (in response to kalvin4599)run the ExtendScript Toolkit, on Windows is in the Utilities Folder in the same folder where the other Adobe applications are. Copy the script from here and paste it into a blank document in the ESTK, save it, and you'll have your .jsx
26. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 15, 2011 6:52 AM (in response to CarlosCanto)I'm on a Mac.
27. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 15, 2011 7:37 AM (in response to kalvin4599)I know, if I had a mac, I would have told you where to find it...look for it
28. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 15, 2011 7:58 AM (in response to CarlosCanto)WOW! I had no idea that program was even on my machine. IT WORKED!!, but only on text frames that contain numbers only. It didn't occure to me, and I failed to mention that most of the text frames have more than just the measurement. Most look something like "8.5421, 4" D (+50%)".
Can we go back to option 1? Where I can copy what is circled in pink, trip a script, and paste it into the existing lable, rounded to 3 decimils.
Thanks for all your help!!
29. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 15, 2011 11:01 AM (in response to kalvin4599)try this one
#target Illustrator // script.name = roundSelectedFrames.jsx; // script description = rounds selected textFrames to 3 decimals; // script.required = select at least one text frame before running; // script.parent = CarlosCanto // 6/14/11; // script.elegant = false; var idoc = app.activeDocument; sel = idoc.selection; if (sel.length>0) { for (i=0 ; i<sel.length ; i++ ) { var iframe = sel[i]; var content = iframe.contents; var search4decimals = /\d.\d\d\d\d/; var decimals4 = content.match(search4decimals); var decimals3 = Number(decimals4).toFixed(3); var replace = content.replace(decimals4,decimals3); iframe.contents = replace; } } else { alert("select at least one text frame before running"); } -
30. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 15, 2011 5:57 PM (in response to CarlosCanto)Thank you!, Thank you!, Thank you!, Thank you!, Thank you!, Thank you!
It works great!
Can I pay you?
31. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 16, 2011 7:15 PM (in response to CarlosCanto)I have a hick-up.
Some times it does not round correctly.
See file http://www.kalgraphics.com/Error.eps.zip
1st line: 21.6675 should round to 21.668, but it rounds to 21.667
2nd line: 8.103, no rounding needed
3rd line: 17.5275 should round to 17.528, but it rounds to 17.527
4th line #1: 5.2462 should round to 5.246 and it does
4th line #2: 25.5075 should round to 25.508 and it does
4th line #3: 5.2462 should round to 5.246 and it does
32. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 17, 2011 4:26 PM (in response to kalvin4599)weird, nevermind I changed the line to something else, use this one, version 1.3
#target Illustrator // script.name = roundSelectedFrames1.3.jsx; // script.description = rounds selected textFrames to 3 decimals; // script.required = select at least one text frame before running; // script.parent = CarlosCanto // 6/17/11; // script.elegant = false; var idoc = app.activeDocument; sel = idoc.selection; if (sel.length>0) { for (i=0 ; i<sel.length ; i++ ) { var iframe = sel[i]; var content = iframe.contents; var search4decimals = /\d.\d\d\d\d/; var decimals4 = content.match(search4decimals); var decimals3 = Math.round((Number(decimals4)*1000))/1000; //var decimals3 = Number(decimals4).toFixed(3); var replace = content.replace(decimals4,decimals3); iframe.contents = replace; } } else { alert("select at least one text frame before running"); } -
33. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 20, 2011 1:47 PM (in response to CarlosCanto)this one seems to be working fine. THANKS AGAIN!!
34. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 29, 2011 11:49 AM (in response to CarlosCanto)It's working GREAT!
What are the chances you could get it to add any zeros to always make the numbers 3 digits after the decimal point?
So 5.25" would become 5.250"
35. Re: Control Panel - round to 3 decimal points
CarlosCanto Jun 29, 2011 3:12 PM (in response to kalvin4599)it searches for 4,3, or 2 digits only, here's 1.4
#target Illustrator // script.name = roundSelectedFrames1.4.jsx; // script description = rounds selected textFrames to 3 decimals; // script.required = select at least one text frame before running; // script.parent = CarlosCanto // 6/29/11; // script.elegant = false; var idoc = app.activeDocument; sel = idoc.selection; if (sel.length>0) { for (i=0 ; i<sel.length ; i++ ) { var iframe = sel[i]; var content = iframe.contents; var search4decimals = /\d.\d\d\d\d/; var decimals = content.match(search4decimals); if (decimals !=null) { //alert(decimals); var decimals3 = Math.round((Number(decimals)*1000))/1000; } else { var search3decimals = /\d.\d\d\d/; var decimals = content.match(search3decimals); if (decimals !=null) { var decimals3 = decimals; } else { var search2decimals = /\d.\d\d/; var decimals = content.match(search2decimals); var decimals3 = Number(decimals).toFixed(3); } } var replace = content.replace(decimals,decimals3); iframe.contents = replace; } } else { alert("select at least one text frame before running"); } -
36. Re: Control Panel - round to 3 decimal points
kalvin4599 Jun 29, 2011 4:06 PM (in response to CarlosCanto)PERFECT!!
