Hello,
I created my own WebHelp-skin. From one day to another, there are no skins listed in my "skins" folder (not even "default"). when i try to import the (correctly) used skin from the !SkinSubFolder! RH sais: "This Skin-Name already exists in this project." That would be no problem, because the skin is used correctly. but i have to make some changes at my used skin and can't open the skin-editor, because the skin is not listed
What can I do? I'm using the German Version of RH9 (V9.0.1.232).
There's three thinks I can come up with:
<?xml version="1.0" encoding="utf-8"?>
<rhpml majorversion="3" minorversion="0">
<s
<skins>
<skin>
<filename>!SkinSubFolder!\XP_Blue\XP_Blue.skn</filename>
</skin>
<skin>
<filename>!SkinSubFolder!\Default\Default.skn</filename>
</skin>
</skins>
</rhpml>
Just add the links to the skins you need in the project. (You may need to delete the CPD before you see the changes reflected in your project.
Greet,
Willam
Hi W. van Weelden,
thank you very much! First option didn't work, but second did! Although the paths to Icons/Grafics were broken...took me just 5 minutes to reload.
